Manifold caked with filth
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rat_Bastard, Nov 19, 2023.
  1. Nov 20, 2023 at 3:13 AM
    #41
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    they offer it because they make a shit ton of money off them. It’s a marketing scheme. It’s what some people want. They don’t make money off warranties they make money off servicing vehicles. Think about it it’s all about the Benjamins
  2. Nov 20, 2023 at 4:44 AM
    #42
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Ermergerd, OEM!!!!!!
    :duh:
    Dude, stahhhhhhhhp.
    TS4x4 likes this.
  3. Nov 20, 2023 at 4:49 AM
    #43
    Hairless_Ape
    South Jersey
    2021 F150
    Everyone is so focused on the K&N that they skipped over this. This right here is your problem. Should have taken the intake off and cleaned it out way back whenever that happened.
  4. Nov 20, 2023 at 4:50 AM
    #44
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    That's not from a K and N lol.
    But that motors fucked.
    33yrsoftoys likes this.
  5. Nov 20, 2023 at 5:39 AM
    #45
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    This is true. The generational debate over paper vs oil is irrelevant in the OP's case now. My advice to OP, pull the intake apart and clean it. Change the oil and send a sample to Blackstone, if there's a real reason to have oil tested, this is it. Change the plugs and do a compression test, bishop84 is probably onto something with scoring cylinders.
    Put a paper filter in it, a nylon over your snorkel, and stay the hell out of the mud. Good luck OP.
    Jesse H, NoOne and 02Duck like this.
  6. Nov 20, 2023 at 5:56 AM
    #46
    Sungod
    Sungod Well-Known Member
    St Augustine
    I think it is hard to say that isn't from the K&N. I have see that happen with other K&Ns, but never with a paper filter.
    The question is what is bad. Is that build up causing any harm? Probably not. Does dust get by the paper filter? I'm pretty sure it does, but without the sticky oil, it sails on by the injectors and into the combustion chamber. Is that bad? I'm sure over 1,000,000 miles, it might contribute to failure, but with all the other things going on like types of motor oil, top tier gasoline, octane, etc. There are a lot of other things to argue about.
    SR-71A likes this.
  7. Nov 20, 2023 at 5:59 AM
    #47
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Agreed. Reading comprehension is not a strong point on this forum lol.
  8. Nov 20, 2023 at 6:17 AM
    #48
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Might be understandable for you but that's quite excessive for any vehicle's intake manifold. AZ intake manifold shouldn't be noticeably worse then a truck from FL. They're called air filter's for a reason. OP has a chassis w/ 140K and an engine with 300K.
  9. Nov 20, 2023 at 6:25 AM
    #49
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    As soon as I saw that pic I knew he ran a K&N :oops:
    TartanEagle likes this.
  10. Nov 20, 2023 at 6:46 AM
    #50
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The K+N crew has entered the chat
    That doesn't look like mud from "several years ago", it looks like fine dust that has been accumulating over time. Mud would have chunks and rocks in it.
    Thanks for clarifying
    tinker_troy, SR-71A and SwollenGoat like this.
  11. Nov 20, 2023 at 6:58 AM
    #51
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Lived in AZ for 20 years, have family in FL, huge difference in off-road terrain. One is mainly the dust/silt in AZ, that stuff gets into everything.
    Could be from mud ingest. Think we could all agree it is from neglect. Hey it happens, pulling the TB off inspecting and cleaning is often overlooked.
    b_r_o[QUOTED] and eurowner like this.
  12. Nov 20, 2023 at 7:35 AM
    #52
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    K&N creates a vicious cycle.
    Dirt enters the airstream. Dierks scores the cylinder walls. Dirt wears the rings. This increases blowby. The blowby gets reingested , coating the intake. The oil residue in the intake adheres the dust.
    SwollenGoat likes this.
  13. Nov 20, 2023 at 7:38 AM
    #53
    eurowner
    eurowner Duke Sky
    Scoty
    Where did @Rat_Bastard say his engine has 300k on it?
  14. Nov 20, 2023 at 8:00 AM
    #54
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    OP serious question… do you change the oil every 5k? Or are you a 10k guy? Reason I ask is because. From the looks of things you fall in the severe conditions category.
  15. Nov 20, 2023 at 8:25 AM
    #55
    pastoreater
    pastoreater doesn't know
    M
    5g 4runner
    Stock airbox @Rat_Bastard ?
  16. Nov 20, 2023 at 9:13 AM
    #56
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I was a “believer” in k&n for many years, boy was I wrong.
    I ran TRD filter (same as K&N) in my taco and after I discovered a layer of dust in my intake tube, that piece of shit of a filter went straight in the garbage.
    Never again will I be using oiled filters, OEM paper for me from now on.
  17. Nov 20, 2023 at 9:24 AM
    #57
    Rat_Bastard
    Rat_Bastard [OP] Well-Known Member
    Brian
    Tucson AZ
    2016 OR
    5k miles, Castrol synthetic always
  18. Nov 20, 2023 at 9:26 AM
    #58
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    Yeah, I've watched videos of some people having tested K and N versus OEM and OEM out performed significantly. It's time for me to go back to OEM.
    Junkhead[QUOTED] and Gfenza89 like this.
  19. Nov 20, 2023 at 9:27 AM
    #59
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    Yes. Stock.
  20. Nov 20, 2023 at 9:27 AM
    #60
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    140k
