Manifold caked with filth
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rat_Bastard, Nov 19, 2023.
  1. Nov 22, 2023 at 10:15 PM
    #161
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I won't bother. High chances to mess them up. The nozzle doesn't look bad.
  2. Nov 23, 2023 at 4:54 PM
    #162
    tollster64
    tollster64 Well-Known Member
    Pennsyltucky
    2019 TRD DCSB
    What’s the filter look like, and the inside of the filter box? Pretty sure if it was blowing by the filter, the filter box downstream of the filter would look about the same.
    Jerry311SD likes this.
  3. Nov 23, 2023 at 5:35 PM
    #163
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    If you have Harbor freight nearby, a few packs of these swab assortments would be handy. Some of them are pretty large, they work well and are cheap enough. Best wishes OP
    Rat_Bastard[OP] likes this.
  4. Nov 28, 2023 at 5:11 PM
    #164
    Rat_Bastard
    Rat_Bastard [OP] Well-Known Member
    Brian
    Tucson AZ
    2016 OR
    do I need to pull a relay first before cranking engine for compression test? This is to close valves to clean and then gauge leaking.
  5. Nov 28, 2023 at 6:16 PM
    #165
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    Yes to that. I have tried 3 other air filters, Fram and 2 others I forget but all brand name.
    I drive steep highway grades every week during the summer, climbing 5,000 foot over an 18 mile stretch, doing 70mph up that. With all of the other 3 filters, my Taco was struggling big time. All because of the air filter. Each new air filter was used on one trip only as the performance was so bad. They were restricting air flow. I still have them somewhere in my garage, giveaway...
    Put a new OEM filter in the next trip, and performance up hill was back to normal. Nothing else changed, these were 4 trips over 4 weeks, and only the filter changed each time.
    Now, you could not pay me to use an aftermarket air filter in my Tacoma. You can't pry my OEM air filter from my cold dead paws, or whatever the fuck Heston said...
    On the flats no difference was noticed, only on those steep climbs and it was a huge loss of power from just an air filter.
  6. Nov 28, 2023 at 8:30 PM
    #166
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    So for the cleaning, it's easier to turn the engine over by hand than crank.
    For the compression test I don't know which fuse/ relay you would pull. It would most likely be a fuel pump relay/fuse. On most all vehicles I either jumper the starter or just put my foot to the floor on the accelerator and hold before and while cranking. Most vehicles I know of except Mazdas will kill the injectors when you crank with the accelerator floored
  7. Nov 28, 2023 at 8:32 PM
    #167
    joba27n
    Nolan
    Alberta
    You know, I felt that too when I changed my filter but just lived with it because I fixed the fuel economy is the same and it to me meant it was filtering better. Maybe next filter I'll go oem again
    Steves104x4 likes this.
  8. Nov 29, 2023 at 11:22 AM
    #168
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    that's what I meant, crank by hand by turning the pulley
    joba27n[QUOTED] likes this.
  9. Nov 30, 2023 at 2:38 PM
    #169
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    UPDATE: After doing a leak test, it seems that my 5th cylinder is not pressurizing. The other cylinders tested fine.
    My next move is to see if I can determine the source of the leak. I am using this Timmy the Toolman video as a reference to determine a possible leak source.
    After a failed leak test he recommends checking for an audible leak from the following areas. The engine oil fill spout, dipstick tube, throttle body intake valve seat. For an exhaust valve leak, Exhaust (remove the O2 sensor near the Cat). Head gasket or cracked head, listen in the area of the radiator fill spout.
    If I take into consideration the possibility that heavy debris got into the cylinders, I am guessing the above list of items to check would not account for damage to piston rings/cylinder walls.
    33yrsoftoys likes this.
  10. Nov 30, 2023 at 3:19 PM
    #170
    Vlady
    Issy, WA
    Set that cylinder to TDC. I used paddle board pump to pressurize the cylinder. Most likely you have burnt exhaust valve.
  11. Nov 30, 2023 at 3:21 PM
    #171
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    I second the valve. If not burnt you may have some debris from that mess you’re dealing with become heat fused to either the sealing lip on either the valve or the head.
    If it turns out to be a head issue or cracked or the such, check out monkey wrench racing for heads. You name it they do it to the 3.5 heads. And cheaper than a new one from the dealer.
  12. Nov 30, 2023 at 3:35 PM
    #172
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    99% sure it was set to TDC. I was able to successfully test the other cylinders using the same method
  13. Nov 30, 2023 at 3:38 PM
    #173
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    If it's the piston, rings, or cylinder walls, a pressurized cylinder will push air out of the dipstick tube or oil fill tube.
  14. Nov 30, 2023 at 3:44 PM
    #174
    Vlady
    Issy, WA
    Cool, now pump some air into that cylinder. If air coming out exhaust - exhaust valve(s). If the air coming from intake ports for that bank, intake valves.
    Big tall dave likes this.
  15. Nov 30, 2023 at 3:45 PM
    #175
    MGMDesertTaco
    Not to drop a turd in the punch bowl, but I wonder about the lower end of the motor after all this work. Like the piston rod bearings and such.
  16. Dec 1, 2023 at 12:49 PM
    #176
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    UPDATE: I assembled everything (upper and lower plenum, throttle body, airbox, etc.) and cranked the motor on and I now have smoke or exhaust (white) exiting near the exhaust manifold, more concentrated near the 5th cylinder. This is the cylinder that was throwing a misfire code and failed the leak test. I did not see smoke before removing parts. The only changes that I made were cleaning everything up, adding a new OEM air filter, adding new plugs and I switched coils with the 5th and 1st cylinders.
  17. Dec 1, 2023 at 12:51 PM
    #177
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Didn't you post yesterday that cyl 5 has low compression? What were the compression numbers?
  18. Dec 1, 2023 at 1:01 PM
    #178
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    White smoke is usually a water or coolant leak no? Maybe a blown head gasket?
    Assuming it isn't condensation getting burned out of your exhaust which most cars have upon cold starup
  19. Dec 1, 2023 at 1:03 PM
    #179
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    The cylinder did not hold any air. The gauge did not register a reading and during the leak test, I heard the air passing through the cylinder.
  20. Dec 1, 2023 at 1:06 PM
    #180
    Vlady
    Issy, WA
    On initial startup, the engine runs on direct injectors for about 20-25 seconds. It would explain the white smoke.
