Manifold Spacer - Andersson Engineering Solutions in Manual Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AndrewInCanada, Apr 12, 2023.
  1. Apr 12, 2023 at 10:20 AM
    AndrewInCanada
    AndrewInCanada [OP] Active Member
    Stumbled upon these the other day;
    https://www.aesinnovate.com/product-page/2016-2022-toyota-tacoma-v6-3-5l-intake-runner-kits
    The claims of peak torque hitting at 1000rpm lower seems too good to be true.
    I'm in a 2020 Sport, Manual Transmission, running 265/70/17 tyres on a 2" lift, and am not regeared.
    I can't help but think that the claimed gains of a the manifold spacer (if true) make this very appealing and a much more efficient route than a regear, especially given DIY install looks pretty achievable.
    Any one in a manual with first hand experience of these?
    I'm hesitant to pull the trigger given what you find after a google of generic 'manifold spacers' in general, so would love some first hand input.
    Junkhead likes this.
  2. Apr 12, 2023 at 10:27 AM
    erok81
    erok81 Well-Known Member
    Imposter
  3. Apr 12, 2023 at 10:35 AM
    AndrewInCanada
    thanks! woops, I didn't find that via search. I'll go chime in over there.
    Junkhead and erok81 like this.
  4. Apr 13, 2023 at 9:55 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    Snake oil save your money.
  5. Apr 13, 2023 at 11:39 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Increasing intake runner volume does indeed move the torque curve. How much on our engine can only be answered with a true dyno test. I will withhold the snake oil judgement until it’s proven or disproven as such.
  6. Apr 13, 2023 at 11:49 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You feel like regear is necessary with 31s?
  7. Apr 13, 2023 at 11:58 AM
    PTSDTherapy
    22 SR5 DCSB
    I’m running 32s in LT235/85/16. Tires are 48 lbs. increase in 1.5 inches and stock tires were 31 lbs. A less than .5 mpg drop is all I’ve seen. No difference in acceleration or braking. No changes to transmission shifting.
  8. Apr 13, 2023 at 12:00 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    With 265/70/17, I felt like my truck was overgeared. 4.30 gears stock. That’s why I was asking.
    With 33s, it’s great for the most part. 1st and 2nd could be a hair lower but not a big deal at all. I think 4.88s would be absolutely perfect with 33s on my truck.
    erok81 likes this.
  9. Apr 13, 2023 at 12:31 PM
    erok81
    Imposter
    Gears are 100% subjective. Just go with what you like.
    When I had 285’s (I’m an auto) the gearing was fine. 35’s kind of sucked with stock gears. 4.88’s and 35’s I almost felt like it was too low. But that’s probably because I was used to stock and 35’s. Now I have 38’s and 4.88’s and I think it drives fine.
    But it’s easier to have mismatched gears in an auto though. I’d probably want at least 5.13’s if mine was a manual.
  10. Apr 13, 2023 at 1:17 PM
    Fredk
    Fred
    Dark grey 2020
    If you want to spend your money and time for 18 ft. lbs knock your self out. I went through this in the 90's and if you can feel the difference you have a sensitive but.
