Manifold spacer interest feeler 2.7L *CLOSED*
Discussion in '4 Cylinder' started by TacoTacoma97, Nov 10, 2017.
  1. Nov 12, 2017 at 6:21 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    https://www.tacomaworld.com/threads/tooter-2-7-intake-manifold-spacer.286076/
    If you read through this thread it might help you understand
    The spacer makes the separate intake runners longer. Having longer runners on an intake help out with off idle and mid range torque shorter runner are better for top end breathing. Toyota probably designed it to have somewhere in the middle so adding length will help it on the low end. A pretty good example is to look at how a tuned port or tpi Chevy is designed and check out pictures of its intake and then check out some Dyno sheets from them compared to traditional performance v8 it would have the same really long intake runners and really good off idle and mid range torque but run out of steam past 5000 rpm. An excellent truck motor that came in Camaros and Corvettes.
  2. Nov 12, 2017 at 6:22 PM
    TacoTacoma97
    TacoTacoma97 [OP] Eagle Scout
    Scott
    Waco TX
    I think it's a Tacoma, let me go check again...
    *Cracks knuckles* Where do I begin?
    The list has been updated as I have neglected this thread. Am I missing anyone?
  3. Nov 12, 2017 at 6:36 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    I can confirm that the LCE header has a distinct effect in dropping the torque curve. My intake side of the equation, to date, is stock.
    One note of concern that i had in this am's brief reading of Tooter's install, was that it spaced out the rest of the intake assembly on the horizontal (the intake is mounted vertically on the side of the head) to the point that he was bending mounting studs to make things work. I'm not real fond of Mickey-mousing stuff like that, and need to do a re-read.. gotta be a better solution than that.
    Ritchie and TacoTacoma97[OP] like this.
  4. Nov 12, 2017 at 8:41 PM
    TacoTacoma97
    Scott
    Waco TX
    Look guys. Everyone just read this. You all have questions and all but this is an interest post. Not a FAQ, nothing has been made but if a manifold spacer were to be in production.... would you be interested? There are no more details than what I have listed and don't expect any till we get 15-20 people.
    This isn't a group buy, it's a feeler. I want to see if there is enough interest available to have something made. Adding your name to the list has no commitment whatsoever. Meaning, if we get 20 people and only 5 people buy then that's fine. We just need to show the manufacturer that there is enough interest out there to make him produce a manifold spacer.
  5. Nov 12, 2017 at 8:43 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Interested
    TacoTacoma97[OP] likes this.
  6. Nov 13, 2017 at 7:41 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I’d be interested in a flange with 2.5” spacer, so I can weld up a proper intake for a turbo.
    SamGoingHam and 5 Lug Fury like this.
  7. Nov 13, 2017 at 8:51 PM
    TacoTacoma97
    Scott
    Waco TX
    Do you want me to mark you down or no? You're not exactly answering the main question. I'm not making a feeler for a flange 2.5" spacer..... I'm making a feeler for a manifold spacer.
  8. Nov 13, 2017 at 8:57 PM
    05Taco4x4
    2TR-FE Enthusiast
    Yes, interested. Wouldn't really need a flange, if it matches the profile of the OE intake as Tooter's did, if I did a two piece intake.
  9. Nov 13, 2017 at 9:09 PM
    TacoTacoma97
    Scott
    Waco TX
    So this thread has been up since Friday. If we don't get 15-20 people to show interest by Sunday the 19th then I'm going to close this.
  10. Nov 13, 2017 at 10:48 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Ditto me too but I would need 1.5" max
  11. Nov 17, 2017 at 5:56 AM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    I've got a brand new, never installed tooter spacer I'll sell for $250.
  12. Nov 17, 2017 at 7:43 AM
    05Taco4x4
    2TR-FE Enthusiast
    Pm on its way
  13. Nov 17, 2017 at 10:40 AM
    TireFire
    Olympic Peninsula
    Is it made out of ABS plastic or metal?
  14. Nov 17, 2017 at 10:42 AM
    TireFire
    Olympic Peninsula
    Thanks for adding me. I still haven't seen a reply as to what material will be used for this thing and what thickness?
    Did I overlook it or is that still left TBD?
  15. Nov 17, 2017 at 11:08 AM
    #35
    GDT
    Plastic, not sure if it's abs though
  16. Nov 17, 2017 at 11:42 AM
    #36
    TireFire
    Olympic Peninsula
    You're not the OP so how would you know? Was it posted somewhere in this thread?
  17. Nov 17, 2017 at 12:54 PM
    #37
    GDT
    I know because I own it. I can look at it and touch it.
  18. Nov 17, 2017 at 12:57 PM
    #38
    TireFire
    Olympic Peninsula
    Are you talking about the tooter spacer or this proposed one? Didn't know there was a prototype yet...
  19. Nov 17, 2017 at 1:04 PM
    #39
    HackD
    William
    The tooter spacer, it's a machined delrin plastic spacer.
    5 Lug Fury likes this.
  20. Nov 17, 2017 at 1:10 PM
    #40
    TireFire
    Olympic Peninsula
    Okay, I don't have any use for that. I need one made from steel.
    Hopping that whoever manufactures the one that this thread is about can make me one
