Manual 2nd gen Regear
Discussion in '5 Lug' started by Bowers86, Nov 20, 2017.
  1. Dec 6, 2017 at 9:02 PM
    Bowers86
    Bowers86 [OP] Well-Known Member
    Vancouver, WA
    2013 RC 2WD 5-speed
    Access Cab Buckets, OE backup cam, AFE Air Filter/Secondary filter removed/Fender Elbow removed, Magnaflow 11225, XII springs/4x4 leafs/XR Bilsteins, Prodigy P3 brake controller, 3.73 Third, Undercover Tonneau, Koomus CD slot iPhone mount, Paint matched rear bumper, Drag 18x9 et20 wheels, 3rd Gen Airdam.
    So it's in! Just did a quick drive around the block since the RTV only had around 5-6 hours to dry. With the colder temperatures, I want to make sure it is set before using it for any additional length of time.
    Overall though, I like the initial feel and gearing change. Would obviously be happier with something like a 4.10 for around town driving, but the 3.73's will be much more appropriate for highway use.
  2. Dec 6, 2017 at 9:06 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Sorry - quick scan of messages doesn't show what tire size you are running on those 18x9's?
  3. Dec 6, 2017 at 9:09 PM
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    255/45/18 right now (factory X-Runner size).
  4. Dec 6, 2017 at 9:18 PM
    HackD
    William
    You are at 27" in tire diameter, over OEM 26.9" original? Am i figuring those numbers right?
    You are technically over-geared at this time, you can easily keep the rims and go up in tire profile, if higher profile are available, next tire change.
  5. Dec 6, 2017 at 9:42 PM
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    Haha, actually I really wanted to go lower profile, but wasn’t sure how it would look with the mild drop I currently have. Yeah I know I’m kinda backwards from many on here who are lifting/going bigger diameter.
    HackD likes this.
  6. Dec 6, 2017 at 9:49 PM
    HackD
    William
    I would just stick with the 3.73's then - you REALLY don't need to go higher at this time ;)
    You should notice an improvement in off the line acceleration.
    Bowers86[QUOTED][OP] likes this.
  7. Dec 6, 2017 at 9:52 PM
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    lol I know, but I love short gearing. My Miata is a hoot with 5th gear being a 1:1 and having a 4.3 rear end. I love how I can shift into third by the time I get through a normal intersection. Screams on the highway but rowing the close ratio gears is a blast.
    HackD likes this.
  8. Mar 23, 2018 at 10:17 AM
    00black5lug
    00black5lug DCSSM18
    Dalton
    2018 DC Sr5
    So I know this is an older thread but would anyone know if an entire rear axle from a second gen 5 lug with the 3.73 would fit under the first gen? I know the leaf spring configuration is different but I was just curious...
