Manual 4 cylinder hard shifting?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2010Tacoma2.7, Jun 23, 2013.
  1. Jun 23, 2013 at 6:43 PM
    2010Tacoma2.7
    2010Tacoma2.7 [OP] Member
    Jeff
    Ohio
    2010 Tacoma SR5
    Lifted, brush guard, and bed extender.
    I recently bought a 2010 Tacoma SR5, 2.7 liter manual engine, 14k miles. Although I've only ever owned manual vehicles and am experienced driving them, it seems as though it shifts rather hard. So here's my question; Is this just me getting used to a new clutch, or is there anything I can do to make it a little smoother?
  2. Jun 23, 2013 at 7:59 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    I can't speak for the 4 cyl crowd, but my 6 speed is also hard to shift. Spirited driving leads to grinding when forced into the next gate.
    I point the finger at 3 things:
    Not enough mileage on it yet to have loosened up (my truck only has 9000 miles on it)
    Clutch disc is very heavy so it takes a moment to match speed
    Laggy throttle response makes it an exercise in "practice makes permenant" to achieve smooth shifts
    So, to answer your question... I think we just need to get used to it!:rolleyes:
  3. Jun 23, 2013 at 8:06 PM
    EricTheRed
    EricTheRed Damn dirty Swede
    Eric Sven
    Kelowna, BC
    Five lugs of might and fury
    BHLM, General Grabber A/T2 235/75R15 on stockers, Magnaflow 11225, Tonneau cover, Pop 'n Lock, Lots of dog hair...
    Definitely not the smoothest shifting stick I've driven. It's pretty well known that it takes a special sort of "finesse" to shift a Taco...
  4. Jun 24, 2013 at 4:13 AM
    2010Tacoma2.7
    Jeff
    Ohio
    2010 Tacoma SR5
    At the very least 1-3 is noticeably rough.
  5. Jun 24, 2013 at 5:31 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Since new 1-2 are "rough" for me even with swap to redline synthetic. 3-5 are smooth. 32,000 on the clock now. It is normal per the design of this type of transmission. There are no linkages and bushings like in other designs to cushion the shift. You will feel every gear change a lot more.
  6. Jun 24, 2013 at 7:02 AM
    81shark
    81shark Well-Known Member
    define hard shifting and rought...
    i'd say mine shifts pretty smooth without much effort. clutch takes more effort to press than most other manuals that i have driven and the throttle by wire lag takes a little getting used to.
  7. Jun 24, 2013 at 7:44 AM
    2010Tacoma2.7
    Jeff
    Ohio
    2010 Tacoma SR5
    When I refer to rough shifting I would compare it to if you just let go of your clutch how you feel the gear change and your vehicle will surge forward. It feels like that even though I am releasing the clutch slowly and giving an ample amount of gas so that it should be an easier transition in my opinion. By the way I appreciate all the replies.
  8. Jun 24, 2013 at 8:40 AM
    jassco
    NH
    2023 TRD Offroad
    You are referring to the clutch grabbing hard and causing the small surge. Mine does this right at the top of the pedal position no matter what I do for starting off in 1st gear. It did it on the 3 trucks I tried before buying mine. Starting to seem normal given my experience with them. I have the new tsb clutch too and it is the same as the original.
    The gears aren't changing when you let out the clutch technically. You already changed gears, so just to clarify this isn't hard shifting.
