Manual 6 speed 2016 Tacoma low end problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mattmec, Mar 23, 2021.
  1. Mar 23, 2021 at 7:49 AM
    Mattmec
    Mattmec [OP] Member
    2016 Tacoma
    My Tacoma has no power on the bottom end. Is there a fix?
  2. Mar 23, 2021 at 7:49 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
  3. Mar 23, 2021 at 7:50 AM
    bzzr2
    bzzr2 Well-Known Member
    Colorado diesel or Ranger.
    nathan298 and RedWings44 like this.
  4. Mar 23, 2021 at 7:53 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Yes, rev up to 4k and dump clutch
  5. Mar 23, 2021 at 7:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The vF Tunes fix that perfectly.
    Also, be sure that you get the latest TSB flash to 04B14. Big improvements there also.
  6. Mar 23, 2021 at 12:02 PM
    POW HOUND
    POW HOUND No friends on a powder day
    Idaho
    2020 Manual Trans Silver Sky
    They're designed to run a higher RPM like a 4 cylinder. My 6 speed challenger would run at 1500 RPM on the freeway with tons of power left, I could pull hills without downshifting from my Idaho to Wyoming drives still with more left (420ft lbs and 375 hp). Our 6 speed tacos run at like what 2300 RPM highway (265ft lbs and 278hp) with little power left stomping on the pedal at that RPM. Not only is the truck heavier, but torque is HOW MUCH work the engine can produce and horsepower is HOW FAST it can do that. You'll hurt your truck under reving way before over reving, it's designed for high RPM, keep it around 3K at least when you're looking for power.
    Gasguy and Kev250R like this.
  7. Mar 23, 2021 at 12:09 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    This for the win. 5 years later I still don't know how to drive it lol. Race car or grandpa . No in-between
    wolf2600 and Tacowin1013[QUOTED] like this.
  8. Mar 23, 2021 at 12:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    Did you buy this new, or is it just new to you?
    Stock size tires (or close) or jumbos all the cool kids want?
  9. Mar 23, 2021 at 12:15 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    You can get the Tacoma with a 6 speed and 4.0 motor. Solves this issue.
    TacomaUSA likes this.
  10. Mar 23, 2021 at 1:26 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    It's a beast. You get to the same torgue 400rpm faster.
    Junkhead, shakerhood and hiPSI like this.
  11. Mar 23, 2021 at 2:06 PM
    Mattmec
    Mattmec [OP] Member
    2016 Tacoma
    Bought it new since day one first gear has no power. Going down hill in first gear 18 to 20 mph before engine holds you back.
  12. Mar 23, 2021 at 2:17 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The latest tunes have a DFCO fix in 2nd through 6th where the injectors don't come back on until near idle. 1st is being addressed on a future update that will be similar. Currently, it has been lowered a bit and is a noticeable improvement.
  13. Mar 23, 2021 at 2:17 PM
    ToyoTaco25
    North Carolina
    OP pmd and said he thinks going down hill in first gear, giving no gas, it goes too fast and should engine brake him down to 8 mph. But instead engine braking allows him to get to to 18 mph.
    I don’t think there is a real problem here.
    VTCAL likes this.
  14. Mar 23, 2021 at 2:21 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Geez. I don't even understand that logic.
  15. Mar 23, 2021 at 2:25 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Agreed. On the Stock tune, DFCO can be unpredictable. Much more consistent on the tune.
    18mph in 1st is about 3,500rpm. From my experience, unless on relatively flat ground, the Taco won't slow from 18 to 8 by engine breaking alone. It will hold a speed nicely though.
  16. Mar 23, 2021 at 2:31 PM
    Mattmec
    Mattmec [OP] Member
    2016 Tacoma
    Well guys idk but in first gear starting on a hill in the snow or mud it will stall out if you dont put the pedal to the floor and then you just creep for a while then it takes off
    MOC221_ likes this.
  17. Mar 23, 2021 at 2:33 PM
    ToyoTaco25
    North Carolina
    Good luck!
    tonered likes this.
  18. Mar 23, 2021 at 2:34 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. That is the weaksauce stock tune that Toyota stuck us with. There is a bit more power and driveability to be had with the TSBs, if you have never been updated. The OV Tune will double down there with about 50ft-lb more in the low end.
    Junkhead and G8R_Taco like this.
  19. Mar 23, 2021 at 2:34 PM
    Mattmec
    Mattmec [OP] Member
    2016 Tacoma
    My Dakota was a 5 speed and all kinds of power never would stall out
  20. Mar 23, 2021 at 2:37 PM
    Mattmec
    Mattmec [OP] Member
    2016 Tacoma
    And first gear never went over 10 mph idle down hill.
