Manual Clutch Difficult Engaging TSB (T-SB-0385-09)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Jan 17, 2010.
  1. Jan 17, 2010 at 3:39 PM
    BSP4x4
    BSP4x4 [OP] Guest
    T-SB-0385-09.pdf
    I have been getting a lot of rattling while hitting ruff road or bumps out of gear (in N) could i need this tsb? Also noticed the shifting is a bit ruff.
    anyone get this tsb done? did it help?
  2. Jan 17, 2010 at 5:01 PM
    BSP4x4
    BSP4x4 [OP] Guest
    anyone?
  3. Jan 17, 2010 at 5:23 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    could be the problem for the rough shift
  4. Jan 17, 2010 at 5:36 PM
    BSP4x4
    BSP4x4 [OP] Guest
    what about the noise. The TSB mentions:
    Some customers of manual transmission equipped, V6 FJ Cruiser and Tacoma vehicles may
    experience a slipping feeling in all forward gears and reverse. The center section of the clutch disk
    may have separated from the friction material section of the clutch disk. Installation of a new clutch
    disk and clutch cover (pressure plate) is required to repair the vehicle. Follow the repair procedure
    in this bulletin to address customer concerns.
    Could the "seperation " of material be causing a loose part that rattles?
  5. Jan 17, 2010 at 6:03 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Is your truck still under warranty? If so take your truck into a Toyota dealership and explain your issue.
  6. Jan 18, 2010 at 5:26 AM
    BSP4x4
    BSP4x4 [OP] Guest
    I did, they said it was "normal" but that seems to be standard procedure at dealerships...any thoughts?
  7. Jan 19, 2010 at 8:08 AM
    BSP4x4
    BSP4x4 [OP] Guest
    any have this TSB done? if so what do you think?
  8. Mar 1, 2010 at 9:47 AM
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
  9. Mar 1, 2010 at 11:20 AM
    TOYOTA 09
    Maine
    when you say the exact same thing...do you mean what the OP mentioned? (noise in neutral) or what the TSB says?
  10. Mar 1, 2010 at 1:19 PM
    superminsoo
    superminsoo Well-Known Member
    Dont remember what the problem with mine was but at about 25,000 miles i wasnt able to shift gears easily. Coudnt engage first at all with the engine on and 2-6 were really tough. The day before i took it to the dealer it got so bad that i had to turn off the engine, engage first and turn the car back on and take it from there. And on the day i took it in, i had to drive it in 1st all the way to the dealer with my emergency light on lol. Hope that helps... havent had a problem with it since. Not so sure about the neutral thing cause mine still does that, it doesnt bother me though just dont put it in neutral when going over bumps.
  11. Apr 19, 2010 at 10:48 PM
    rawman2
    rawman2 Member
    Ricky
    Mountain View, Ca
    09 off-road 4wd 6sp double cab
    trd intake
    I have a clutch disc that has completely separated from the inner hub. toyota has argued with me about replacing the clutch, calling it wear and tear. the clutch didn't feel weird, just made a loud popping sound when it went, there was no warning or anything that i felt.
    thanks for that tsb up there, they'll smile when i show them this one.
  12. Apr 19, 2010 at 11:38 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Yep, or find a new dealer that can use the search function.
  13. Nov 20, 2010 at 7:12 PM
    4x4Tacoma
    4x4Tacoma Well-Known Member
    Ben
    Fresno, ca.
    08' Tacoma, RR lock 295/75/16 MT 3" level kit
    3" leveling kit by Hell Bent Steel, 295/75/16R mud tires
    did you ever get a answer on your cluthc mine went ou also [​IMG]
  14. Nov 21, 2010 at 8:30 AM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I always felt like my clutch was weak, but I haven't really felt slipping once the pedal is released and the clutch is fully engaged.
    I have just over another 4000 miles before I hit 60k. If it's going to go, I wish it would just go now.
  15. Nov 22, 2010 at 6:43 PM
    4x4Tacoma
    Ben
    Fresno, ca.
    Guess what I talked to Toyota today and they say the TSB PDF that is on here and 10 other sites is wrong and that this exact clutch problem is NOT covered under the 60 month 60,000 mile warranty But by the comprehensive warranty 36 month or 36,000 mile. I honestly believe either someone at Toyota fucked up and I was informed it was amended march 12, 2010. I am furious and feel there will be a law suite coming
  16. Nov 23, 2010 at 12:47 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Yea.. I can't say I've ever seen a clutch do that. If they have a TSB for it I would think it would get covered since its a very odd failure. (in my experience anyway). Seems to be obviously a fault.. That being said, what corporate says goes.. Your dealer can't do it for free; you or corporate has to pay. Consult corporate and if you can find others, get a group to sue them(saves money).
  17. Nov 23, 2010 at 6:42 AM
    4x4Tacoma
    Ben
    Fresno, ca.
    I think it's funny they have changed it 7 mo ago to a lesser covered warranty.? If anything should be the other way round
  18. Nov 24, 2010 at 6:43 PM
    4x4Tacoma
    Ben
    Fresno, ca.
    Just an update I took it to anoter Toyota dealership the service manager says he sees no signs of abuse blue glazing or burning pad he says it's exactly what the TSB lists and shows because the TSB t-sb-0385-09 shows a picture on it!! It is exactly what the tsb says and shows and I can't believe I get stuck with the bill I got a mortgage payment and a 550$ truck payment and even paid for extended 7yr 100,000 mile warranty. And this is rediculouse. I'll keep y'all informed. Just be careful driving y'all it gave out just shifting luckily I wasn't towing my boat up the mountain
  19. Nov 24, 2010 at 9:37 PM
    BarefootBandit
    BarefootBandit Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    My truck does this all the time. When I'm in neutral going over bumps it sounds like all the gears are rattling.
    Shifting into 1st over 10mph is very difficult, but not impossible. You need to really push it hard to get the gears to grab. Shifting into second is also rough sometimes, but with enough practice you can get it perfect. You need to get used to the clutch engaging really high. My shifts now are always smooth, but the first 2 months of owning it I was always clanking and chirping and revving like crazy.
  20. Nov 29, 2010 at 1:30 PM
    4x4Tacoma
    Ben
    Fresno, ca.
    Hey The rattling isn't what this TSB is for u would no if this tsb happened as u would be dead in the water with no drive like if you had spun a axle or broke a u joint Where is the rattling coming from? Is it when your off road and put the breaks on hard? And as for shifting down to first from a higher gear would be difficult because it's kinda a safety feature so u can't shift from 40 mph to first and blow your engine the truck has amazing Low gears that's why it jerks when starting on first from gearing and torque also provides great granny lo. Or equivalent in 2nd gear in low and it climbs like a tank. That's why I love it. I had shaking and had a bad u joint right up at the first drivline which I got replaced for free and it made a huge difference I'd check that if you have shaking when starting out in first gear
