manual clutch skipping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by h2o's taco, May 5, 2011.
  1. May 5, 2011 at 8:48 AM
    h2o's taco
    h2o's taco [OP] Active Member
    Kurtis
    Sacramento
    2010 Tacoma TRD off road 4X4
    Undercover tonneau cover, Westin side steps w/ Line X coating, MANY more to come.
    I have been having problems with my clutch not engaging at times. I have a steep driveway and it seems to happen more often when I park in my driveway. When I pull out the clutch after rolling out of my driveway the engine almost stalls and the whole vehicle shakes. I don't know if the fuel isn't getting to the injectors or if it is just a simple clutch adjustment that is needed. Has anyone else had this problem? I only have 19,000 miles on the truck. I had a 1994 Toyota before with a five speed. It had 50,000 before I sold it and I never adjusted the clutch nor did I have this issue with the vehicle shaking unless I stalled the vehicle.
  2. May 5, 2011 at 9:03 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    My 08 Pre runner has been doing this since new. I have taken it to the dealer who told me everything is fine & it is because they can't use asbestos in the clutch linings anymore. They said once warmed up the shudder goes away. Mine seems to be worse on cold mornings, then goes away when warmed up. It's a real PITA when you are in a hurry & trying to shoot a gap from a stop sign.
  3. May 5, 2011 at 9:09 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    That's interesting. I've had a similar experience with my first gen (2001). Every vehicle I've ever had was manual, and I bought this truck used with 100k.
    I have the same symptoms on level ground when cold. After it warms up, no problem. I was puzzled. It sucks trying to get across a busy street one block from my house in the morning.
    So when did they stop putting asbestos in?
  4. May 5, 2011 at 9:26 AM
    charles08tacoma
    Santa Cruz, CA
    I was told environmental & health regulations stopped the use of asbestos in clutch & brake lining several years ago.
  5. May 5, 2011 at 9:37 AM
    vierzwanzig
    vierzwanzig Well-Known Member
    Moreno Valley, CA
    '11 SW 4x4AC/MT 2.7l
    the list is growing
    That was the first thing that came to my mind. I have had no slippage issues that were not driver related. (only 2500mi on my 5 speed.)
  6. May 5, 2011 at 11:39 AM
    h2o's taco
    Kurtis
    Sacramento
    I don't "think" it is operator error. I think charles08tacoma summed it up for me. It seems to only happen when the vehicle engine is cold. Primarily it happens in the morning or when I let it sit for a day or two.
  7. May 5, 2011 at 12:00 PM
    vierzwanzig
    Moreno Valley, CA
    the list is growing
    what kinda temps are you guys talking about? I live in so cal and took delivery of the truck in mild weather.
  8. May 5, 2011 at 12:12 PM
    h2o's taco
    Kurtis
    Sacramento
    Mine happens in the morning time when I first start it up. It doesn't matter what the temp is. I live in norcal so our temps are almost as nice as yours.
  9. May 5, 2011 at 12:13 PM
    vierzwanzig
    Moreno Valley, CA
    the list is growing
    hmm... maybe I need to put more miles through it?
  10. May 5, 2011 at 12:16 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The problem I usually have is from the drive by wire lag. Having a cable throttle on a manual trans eliminates this problem.
    Try using the parking brake to hold you while working the clutch and skinny pedal.
  11. May 15, 2011 at 11:48 AM
    david55838
    david55838 Member
    Sacramento, CA
    99 SR5 Xtra Cab 4x4
    My 1st Gen does the same thing - and I'm in Sacto too.
  12. May 15, 2011 at 4:49 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Brakes work fine with no asbestos in them why would a clutch be any different.
  13. May 15, 2011 at 6:58 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Ya that doesn't sound at all like your clutch is slipping. If it is dragging the motor down and almost stalling it, it sounds like you need a bit more gas. That or the tranny isn't going into the right gear somehow. Thats just how the enigne behaves if you try starting in 2nd (The ratio for second is a bit long in this truck for stats). You are putting it up and left to start right? :D
