Manual/ECT question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbybreach, Sep 27, 2015.
  1. Sep 27, 2015 at 4:05 PM
    bobbybreach
    bobbybreach [OP] Well-Known Member
    bobby
    westchester NY
    09 TRD
    So i keep reading that when ECT is engaged the truck has more power. The manual transmission doesn't have ECT right? So it's like it always has more power?
  2. Sep 27, 2015 at 4:07 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    ect controls shift points only I thought? So no need in manual? Shift later in rpm?
  3. Sep 27, 2015 at 4:08 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Isn't it just changing shift points?
    Beaten to it.
    Justus likes this.
  4. Sep 27, 2015 at 4:08 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    VTEC makes the Honda make a lot more power, too
  5. Sep 27, 2015 at 4:53 PM
    tubesock
    tubesock Well-Known Member
    ECT means electronically controlled transmission. This is a holdover acronym from when it was first introduced into toyotas in the 90s or something and transmissions had a lot of hydraulic controls. Modern transmissions are electronically controlled already so turning on electronically controlled transmission is redundant, but that's not to say the button does nothing. Pressing ECT causes the transmission to always anticipate that the driver is about to accelerate rapidly. This is in contrast to normal operation which is to assume that once the vehicle is up to speed any accelerations will be gradual. Thus it can stay in a higher gear to save fuel. It doesn't create any more power in the engine, it makes the transmission more responsive to throttle inputs so it feels more powerful.
    Ultimately you as the driver have to ask politely for your transmission controller to shift so that you can accelerate and it gets around to it eventually, probably. With ECT on it gets around to it sooner than it otherwise would be bothered.
    None of that is required in a manual because the driver controls the transmission with a big caveman-esque lever and usually the driver knows when they are going to accelerate.
    CartoTaco and m3bassman like this.
  6. Sep 27, 2015 at 4:57 PM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    Ok great. Thank you
  7. Sep 27, 2015 at 5:02 PM
    CartoTaco
    CartoTaco TAKO
    Alaska
    2016 AC TRD Sport Manual Trans, MGM
    Ha ha, caveman-esque lever. :thumbsup:
