Manual Hub 1st Gen Wheel Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by PappyMcKee, Mar 7, 2024.
  1. Mar 7, 2024 at 3:21 PM
    PappyMcKee
    PappyMcKee [OP] New Member
    Trent
    1995 Black Tacoma XtraCab V6 4WD
    Hello fellow Taco lovers,
    I’m at the point where I need new tires for my black ‘95 Tacoma xtracab and I’m thinking about some new wheels as well. I’ve pretty much narrowed it down to either the SCS F5’s or Method 305NV’s but can’t decide on a size and color. If my forum searching is correct I shouldn’t have any issues with my manual locking hubs with either of these wheels? Also please drop some pics if you’re running either of these wheels. Bonus points if your truck is black. Would love to see some black and bronze too!
  2. Mar 8, 2024 at 6:25 AM
    hucklebarry
    hucklebarry Well-Known Member
    casey
    02 tacoma
    arb bumper, warn 8000 winch, arb air pump, arb front locker, and old man emu lift
    Both of the wheels you referenced will work on your truck. Assuming it’s a 6 lug. The rest is preference. I would get your tire size chosen first, then choose your offset/backspacing backed off of that.
    PappyMcKee[OP] likes this.
  3. Mar 8, 2024 at 10:38 AM
    PappyMcKee
    Trent
    Thanks @hucklebarry
    I’m running stock suspension and ride height for now and my truck is 6 lug. I’d most likely run a 265/70R16. That being said, I think I would go with the 0mm offset in the F5’s without rubbing since they have 3.5” backspacing.
  4. Mar 8, 2024 at 7:34 PM
    hucklebarry
    casey
    02 tacoma
    Should be fine. At most you might have to fold the pinch weld..
