Manual Hub Conversion for the 1st Gen Tacoma & 3rd Gen 4Runner
Discussion in '1st Gen. Tacomas (1995-2004)' started by DJB1, Nov 12, 2016.
  1. Jan 22, 2018 at 3:49 PM
    #81
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Without complete details about your truck nobody can tell you with certainty.
  2. Jan 22, 2018 at 3:50 PM
    #82
    tony2018
    tony2018 Well-Known Member
    j shifter transfer case...dont have much else to say..not install?:confused:
  3. Jan 22, 2018 at 3:54 PM
    #83
    License2Ill
    Ian
    I don't understand.
    Okay. Put it this way. If you installed that TC in your truck, what would be the complete details of your truck?
  4. Jan 22, 2018 at 3:56 PM
    #84
    PJL
    PJL Well-Known Member
    Baltimore, MD
    2003 xcab Tacoma 4x4
    Stock
    So to sum up...I can do the manual hub conversion using my current ADD diff with it's intermediate shaft as long as I do the hose clamp mod and disconnect the actuator motor. I will of course have to get the locking hubs which I can then install on my current spindles/axles? If this is correct then what is the advantage of the OP changing out the axles and intermediate shaft? Was this to just eliminate the actuator and sliding shaft/gear? Will I still gain the shift on the fly capability(with the hubs locked)? Just trying to wrap my head around this.
  5. Jan 22, 2018 at 3:57 PM
    #85
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I made a custom gauge cluster that indicates 4HI, 4LO, and N. That's what the three sensors detect. Usually they go to the 4WD computer to prevent the driver from activating the RR DIFF LOCK in 4LO, but I didn't bother hooking the computer up so I made them light up on the dash instead.
  6. Jan 22, 2018 at 3:59 PM
    #86
    BartMaster1234
    Tyler
    Flux Capacitor
    All A/T transmission trucks had the three plugs on the transfer case, only the M/T trucks didn't have it.
  7. Jan 22, 2018 at 3:59 PM
    #87
    tony2018
    ok, make sense. it just completes a circuit. unfortunately on spot is already taken by the rr locker.
  8. Jan 22, 2018 at 3:59 PM
    #88
    License2Ill
    Ian
    You don't have to hose clamp the shaft. I have ADD w/ manual hubs, and I haven't done it.
    digitalferg likes this.
  9. Jan 22, 2018 at 4:02 PM
    #89
    PJL
    Baltimore, MD
    Stock
    But you disconnected the actuator with it in the 4WD position, right? And I can install the manual hubs on my axles?
  10. Jan 22, 2018 at 4:03 PM
    #90
    tony2018
    dont have disable anything
  11. Jan 22, 2018 at 4:05 PM
    #91
    License2Ill
    Ian
    Nope. Mines still plugged in. Rather get rid of it though.
  12. Jan 22, 2018 at 4:07 PM
    #92
    PJL
    Baltimore, MD
    Stock
    So basically you're leaving everything as is except you're adding the ability to allow the wheels to spin free from the axle until it's locked. Sounds simple. What are the hubs that I get for my 2003? And can you shift on the fly?
  13. Jan 22, 2018 at 4:08 PM
    #93
    License2Ill
    Ian
    Yep. Gotta be stopped for 4lo.
  14. Jan 22, 2018 at 4:11 PM
    #94
    License2Ill
    Ian
    You can convert you ADD spindles using manual hubs and bearings. What hubs do you get? The lockouts? Not sure what you're asking...
  15. Jan 22, 2018 at 4:11 PM
    #95
    PJL
    Baltimore, MD
    Stock
    And you would rather get rid of it in order to simplify everything, i.e. no electronics required to engage 4WD?
  16. Jan 22, 2018 at 4:13 PM
    #96
    License2Ill
    Ian
    Exactly.
    If you don't lock the passenger stub, and the actuator fails only one axle can turn. I have a truetrac so if that happens I'm only 2wd.
  17. Jan 22, 2018 at 4:13 PM
    #97
    PJL
    Baltimore, MD
    Stock
    What is required for the spindle conversion? Do you know Part #'s?
  18. Jan 22, 2018 at 4:15 PM
    #98
    PJL
    Baltimore, MD
    Stock
    So the hose clamp solves that problem.
  19. Jan 22, 2018 at 4:16 PM
    #99
    License2Ill
    Ian
    It was so long ago, I don't remember. By now I'm sure there's tons of info out there.
  20. Jan 22, 2018 at 4:19 PM
    #100
    License2Ill
    Ian
    Basically. But you won't have the indicator light. So wiring will be needing to be done.
    But this is all for a j+shift transfer case. If it's pushbutton, I'm guessing more will have to go into it.
