Manual Hub Conversion?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DustStorm4x4, Oct 10, 2015.
  1. Oct 11, 2015 at 7:00 PM
    DustStorm4x4
    DustStorm4x4 [OP] BBC 2020
    U S A
    04 Jeep LJ
    Does the dash light specifically say ABS? I just went outside and put the keys in and there definitely no ABS light.
  2. Oct 11, 2015 at 7:44 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Yeah it does. Right in the bottom middle of my dash on my 4Runner. If you put the locker in the abs shuts off so it's the easiest to tell besides looking at the side of your spindle for the plug.
  3. Oct 11, 2015 at 8:24 PM
    AmericanInfidel
    AmericanInfidel Well-Known Member
    Yes it is , thinking about it myself. I heard you get a little better mpg ??? Less moving parts so less wear on the front end ??? What I heard , looking into it.
  4. Oct 11, 2015 at 8:42 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Oh shit, completely skipped the first gen part, haha
    Adventurer_Alex likes this.
  5. Oct 11, 2015 at 8:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    It is a common misconception that the hubs on ADD truck lock and unlock. They don't actually. ADD represent Automatic Disconnect Differential. This is what locks and unlocks, not the actual hubs like on a manual hub setup.
    If you are experiencing difficulties with the front wheels engaging when you shift into 4WD, it is likely the mechanism the engages the diff. @DJB1 made reference to the "ADD motor" in post #4 of this thread.
    https://www.tacomaworld.com/threads/manual-hub-conversion.395229/#post-10922797
  6. Oct 11, 2015 at 8:53 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Well shucks. I guess that I'll have to check on that. Thanks for the tip!
  7. Oct 11, 2015 at 10:02 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I was somewhat wrong on that, the fork stays attached to the ADD actuator motor, and it's a sliding collar that you have to lock into place with a hose clamp. These threads show what it looks like when you remove the ADD actuator:
    http://www.4x4wire.com/toyota/tech/add/
    http://www.fjcruiserforums.com/foru...differential-actuator-repair-replacement.html
  8. Oct 11, 2015 at 10:35 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Not to mention forgetting you were slumming in the first-gen forum. :crazy:
  9. Oct 12, 2015 at 12:55 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Dont know about better mpg's, but prolly a little since all that shit isn't spinning constantly and using up component's that dont spin on manual hub models (until 4wd is engaged). The biggie i think is the cv boots! Seems the guys with fairly big lifts can sometimes really have problems eating them up because of the constant rotation. With manual hubs those axles are rarely spinning and when they are spinning its usually at slower speeds. When i was looking for my trucks getting manual hubs was high on the list because of this issue and the reliability end of things too(not relying on a switch for 4wd), less electronics the better as far as im concerned plus ya get the j style transfer shifter...(with factory configured manual hubs of course)
    tan4x4 and DustStorm4x4[OP] like this.
  10. Oct 12, 2015 at 6:38 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    I miss my first gen and still roam through. Should have kept that truck
  11. Oct 12, 2015 at 6:58 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Haha 1st gen, best gen
    Kens04Taco and AmericanInfidel like this.
  12. Oct 12, 2015 at 10:33 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Narrower, had a metal bed, better built, and for some reason I loved that little grill.
  13. Oct 12, 2015 at 9:17 PM
    4thone04
    4thone04 Well-Known Member
    jcl
    west END of hwy2
    new at 155,000
    If you have abs I would keep it. I found the manual fronts off a "low milage" rig but figured new bearings would be good, so I got extra abs spindles and did a rebuild/convert to manual including tundra back splash plates with abs. With a press it was straightforward. Glad I did because the low mile manual hub bearings were tost.
    I swapped on my 94 and milage jumped 2mpg. I have been keeping track on my 04 so when I swap it to manual I will know, but I'm sure it will jump up 1-2mpg. If it makes a difference on a f350 it should also work on the tacoma
    AmericanInfidel likes this.
  14. Oct 13, 2015 at 5:08 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    I have 4x4 Warn manual hubs on my 2000 Tacoma. I have been considering ditching my whole front 4x4 driveline them along with my Total Chaos LT kit and extended axles to make the truck 2wd. I have gusseted spindles as well. The bearings are new as are the extended wheel studs. Is anyone interested in something like that?
  15. Oct 13, 2015 at 6:20 AM
    #35
    DJB1
    Dave
    SLC, UT
    I'm sure you would sell that stuff in no time at all if you put it in the 1st gen classifieds.
    06HAOLE likes this.
  16. Oct 13, 2015 at 7:12 AM
    #36
    DustStorm4x4
    U S A
    04 Jeep LJ
    Sell it and make someone desperate for 4WD lucky!! It's hard to find a decent 4wd Tacoma. Just sell yours for a PreRunner if you don't want 4wd.
  17. Oct 13, 2015 at 7:28 AM
    #37
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    I have way too much fabrication work into my truck into my truck to do that. I will probably throw a feeler thread up in the 1st Gen classifieds.
  18. Oct 13, 2015 at 9:05 AM
    #38
    SPOTSONTROUT
    SPOTSONTROUT Well-Known Member
    ROB
    SOUTHERN ONTARIO CANADA
    03 TRD Stolen
    OME 882,DAKAR LEAF PAC WITH ADDA LEAF,285 TOYO OPEN COUNTRY MT,RACELINE RENAGADES,DECK PLATE MOD, MANUAL HUB CONVERSION
    When I swiched mine to manual hubs , I also put it all into the ABS spindles. The abs is disabled although . It's there for future use I guess. I left the add axle intact ,so I could turn the 4x4 on and off in the truck when the hubs are locked. I don't notice any better mpg though. If your rig has a 3"+ lift you'll save a bundle on cv axles for sure .
  19. Oct 16, 2015 at 8:38 PM
    #39
    AmericanInfidel
    Thanks , sooner or later. cv boots, ha fun! Drop down spacer and it seems to have stretched the life span out a bit.
