manual hubs, what happens now?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bino9905, Jun 9, 2014.
  1. Jun 10, 2014 at 12:03 PM
    BamaToy1997
    Bill
    Navarre, FL
    Agreed. Best thing to do is remove the hub, clean and inspect. It is not uncommon for a spring to break though.
  2. Jun 24, 2014 at 8:51 AM
    Bino9905
    Bino9905 [OP] Well-Known Member
    TX
    99 ExtCab 4X4 V-6 TRD
    I took the hub apart and it looked brand new, no issues....but i couldnt get it to work....
    but what did the trick was to just rotate it over one or two bolts....
    I took it out, and tried to put it back in without compressing the spring
    I kept doing it until it finally slipped in.....i put two bolts in to hold it in place then moved it....i felt it engage and i tested the rotation of the CV joints.....
    everything worked and both sides operated in the same manner....now I can go test it this weekend on a muddy ditch somewhere.....
    Thanks for your responses.....
  3. Jun 24, 2014 at 9:33 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    ^Nice! Sounds like you got everything figured out.
  4. Jun 24, 2014 at 5:31 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Good ending! Have fun.
