Manual locking hubs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by fed454, Jul 16, 2007.
  1. Jul 16, 2007 at 1:38 AM
    fed454
    fed454 [OP] New Member
    I own a 1991 toyota pickup and am looking to upgrade to a 2000-2003 tacoma. Did toyota make any trucks with manual locking hubs in these years? Any feedback or comments welcome, thanks
  2. Jul 16, 2007 at 8:30 AM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    no the 95.5-97 Tacoma's has locking hubs but 98- present is all on the fly
    robssol likes this.
  3. Jul 17, 2007 at 1:25 AM
    fed454
    Thanks for the info, I guess I'll look into the Downey manual hub conversion.
  4. Jul 27, 2007 at 8:44 AM
    DakotaTacoma
    DakotaTacoma Well-Known Member
    So. California
    1996, 2.7, 4x4, 5-speed, extra cab
    3" Downey lift, K and N FIPK, NWOR Try Y header, 31x10.5 BFG KOs
    Get ready to shell out alot of $$$. The Downey kit is expensive.
    I
  5. Aug 11, 2007 at 9:15 AM
    Dave
    Dave Well-Known Member
    RI/Vt
    08 4x4 Xtra Cab
    Wrong, I have a 00 and it has manual locking hubs.
  6. Aug 19, 2007 at 6:45 PM
    navyat
    navyat New Member
    Brunswick, Maine
    SR5.
    K&N Fuel Injection Performance Kit. Cat-Back.
    No, thats not true. I have a 2000 SR5 and it has Manual locking hubs.
    Matic and Wyoming09 like this.
  7. Aug 19, 2007 at 8:24 PM
    MarkC
    Mark
    99 4x4 SR5
    well it looks like you guys made a lier out of me!!!! my 99 is shift on the fly. I wish i had manual hubs
  8. Sep 9, 2007 at 11:33 AM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    I just bought a shift-on-the-fly 00 (2.7, 5sp man, SR5,TRD, locking rear) and I was impressed with the utility of the ability to shift in and out of 4wd while moving. Why do you prefer manual locking hubs?
    Running Board Man likes this.
  9. Sep 9, 2007 at 1:26 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Manual locking hubs are generally prefered by the hard core off road set as it is possible to lift the truck higher without having to do a front diff drop or damaging the cv joints in the front. I believe it is because with unlocked hubs the front diff and cv joints do not spin so are not damaged by the high angle driveline, where as with a shift on the fly set-up those parts are spinning when the truck is moving, and there is a series of automatic clutches that put power to them when you engage the 4wd system. Just my theory though so don't take it as fact unless someone else confirms it.
    TacomaJunkie8691 likes this.
  10. Sep 9, 2007 at 11:07 PM
    thenrie
    Stafford, VA
    I wonder what effect manual locking hubs has on gas mileage compared to shift-on-the-fly. Anybody know?
  11. Sep 10, 2007 at 7:09 AM
    DakotaTacoma
    So. California
    You get slightly better mileage with manual hubs....as you are not having to always spin the front end components.
    Plus, lots less wear and tear on the CV joints when having a 3"+ lift.
  12. Sep 10, 2007 at 10:28 AM
    Dave
    RI/Vt
    08 4x4 Xtra Cab
    I bought my 00 because it had the locking hubs.
    I average 27 mpg on highway.
    It's like having a 2 wheel drive until I need the 4 x 4.
    Which is only in winter in the heavy snow when have here.
  13. Sep 10, 2007 at 10:57 AM
    thenrie
    Stafford, VA
    followup question: About how much is a kit to convert to manual hubs? Most of my driving is going to be highway miles. I'm looking at all possible tweaks to eek out another mpg or two.
  14. Sep 23, 2007 at 7:18 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    i had a 96 V6 with ADD lol...my gf's dad has a 2000 with manuals... btw its best to actually have the add truck then convert to manual...since you will still have the bearings in axles instead of bushings like a factory manual hub truck... (last longer and better fuel enconomy in 4wd)
  15. Mar 12, 2018 at 10:09 PM
    1998purplepickup
    1998purplepickup Well-Known Member
    St. Michaels, MD
    1998 4wd 2.7L Tacoma
    warn vr 8-s winch welded rack and canopy LED bars front and rear Front and rear diff breather ext. lift
    where is the shift-on-the-fly switch on the manual tacoma? (i don't have one) i have manual locking.
  16. Mar 12, 2018 at 10:30 PM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Here is my Jackass analysis of the manual locking hub debate.
    Manual hubs allow the front axle of a four wheel drive to be locked or unlocked manually. They are an old four wheel drive engineering design, which is almost extinct in new vehicles. There are very few manufacturers that still make manual hub style front axles. I think the larger Ford Pick-ups are the only ones that still use this system.
    Americans, as we all know, are very into convenience, and manual hubs are not very convenient to use, which is why they are almost completely extinct. They do, however, have some major advantages over the current modern convenient automatic everything four wheel drive systems. They age much better since the C/V axles or axle, and the front gear shaft does not spin when the hubs are disengaged. They also have much less electronics so there is less to go wrong with their electronics.
    This is the very simplest way of explaining manual hub four wheel drive systems. Tacoma World subscribers please don't rip me a new one for not going into a long detailed explanation of manual hubs. I did not want to bore this subscriber to death with a lengthy explanation. From the sounds of it, it sounds like this person is just starting to research four wheel drive engineering.
    Take it easy,
    Paul
    ArtP likes this.
  17. Mar 12, 2018 at 10:35 PM
    eon_blue
    Azusa, CA
    It was a rare option on later model 1st gens, most are ADD. It's preferred in the same way that manual windows and locks are preferred by some...one less electronic thing to have to worry about breaking on you or just not working at some point. I get the appeal but ADD isn't all that bad, I think it's proven to be fairly reliable. I'd like to have manual hubs but I don't think I'd ever go to the trouble to convert. Doing it for MPGs is silly, if there's any difference it's gotta be close to negligible. I'd do it just for the added reliability and less overall wear on the front axles.
  18. Mar 12, 2018 at 11:54 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Last reply to this thread was on September 23rd, 2007 - lol!
    You wouldn't have a switch for shift on the fly on a manual locking hub Tacoma. You either have manual hubs or push-button 4WD - you can't have both as far as I know.
  19. Mar 13, 2018 at 4:22 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Sad thing is most of the original posters have faded off. :(
  20. Mar 13, 2018 at 5:21 AM
    Dave
    RI/Vt
    08 4x4 Xtra Cab
    Nah.
    Been here since Day 1.
