manual ON, backup lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, May 14, 2023.
  1. May 14, 2023 at 1:02 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    SD CA
    Anyone done this? What’s the best way to wire in Toggle ON (manual)?
    I reached out to DD and am awaiting a reply
    I have their aux backup lights that claim the switch can turn them on stand-alone, but mine never has. Not sure if the relay came bad or something. I don’t think there’s much that can be messed up following the instructions.
    would be great if I could figure out how to make the truck thing reverse is on, without actually being in reverse
    To occasionally make use of the aux backup pods to light up a campsite etc
  2. May 14, 2023 at 1:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. May 14, 2023 at 3:07 PM
    TacoTuesday1
    SD CA
    yes. Ssc1 version. But for whatever reason manual override doesn’t do anything
    it’s pretty weird
    Above says put in I
    I makes them red and not white in reverse
    says put in II for manual override
    which doesn’t
    They’re red then white in reverse in II
    So I leave it in II
  4. May 14, 2023 at 3:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    Suggest contacting @memario1214 from Hotshot Offroad
    He is a vendor that handles DD products and I'm sure would be willing to give guidance.
    memario1214 likes this.
  5. May 14, 2023 at 5:18 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    You'll want either a SPDT switch, or a SPDT relay with your choice of whatever switch (opens up availability for switches that fit the factory switch blanks)
    Power out to the lights goes to the Common terminal (which is usually used for power in, but you're wanting to switch between power supplies, not switch power supply to different devices) Power from the backup light switch goes to the NC terminal. Then add a (fused) power supply to the NO terminal, either constant or ignition-on, depending if you want to be able to use them without the key on.
  6. May 14, 2023 at 11:10 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I wired mine to a SPST switch center off. Factory set to one input and center off all the time and third position is manual over ride
    TnShooter likes this.
  7. May 15, 2023 at 9:54 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Did you use the vehicle specific harness that taps in behind the tail light?
  8. May 15, 2023 at 11:39 AM
    TacoTuesday1
    SD CA
    yes
