Manual or Automatic
Discussion in '1st Gen. Tacomas (1995-2004)' started by VixTacom, Aug 22, 2009.
Which do you like better?
Poll closed Nov 20, 2009.
  1. Manual
    58.1%
  2. Automatic
    43.6%
  1. Nov 16, 2014 at 5:21 PM
    #101
    keakar
    keakar Well-Known Member
    karl
    louisiana
    if it were just a daily driver and I never towed with it then the a manual would be ok, but get stuck in bumper to bumper traffic on a hill or going up a bridge pulling a trailer and you WILL burn up your clutch or back into the car behind you and at a boat ramp you will roll back into the water at some point with a manual. not to mention the acquired learned skill of pressing on the brake and gas at the same time letting out on the e-brake without stalling or lurching forward into the car in front of you.
  2. Mar 3, 2018 at 5:59 PM
    #102
    RRRon
    RRRon Well-Known Member
    Ron
    2001 Tacoma
    None
    I would prefer stick, but my daughter refuses to drive stick. That's when the auto came in.
  3. Oct 28, 2024 at 9:01 AM
    #103
    Bergi
    Bergi New Member
    01 Tacoma Base/RegCab 2.4L 2wd 5speed
    IMO if you're buying an older used small truck, with automatics you'll have no idea how it was abused, but in a manual if the clutch doesn't slip and the gears shift up and down without grinding, you're in good shape. When driven properly a manual will last longer with less maintenance needed. Manual for me.
