Manual or automatic?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tcBob, Aug 16, 2022.
  1. Aug 17, 2022 at 7:54 AM
    #41
    Servingko
    Servingko Well-Known Member
    2022 DCSB OR MT
    I like the simplicity of the 6MT and the potential longevity over an automatic. I have replaced a couple of auto transmissions over the years, one before 100k and another at 225k, but have driven a few MT vehicles to 300k+ and not had an issue with the manual trans. In fairness, they got a little notchy towards the end and could be stubborn at times, but they never let me down.
    I also like the fact an MT vehicle can be towed without worries, bump started if need be, easier to work on, and cheaper to maintain. I have only replaced 1 clutch in 48 years of driving and that was at 275k miles on a Mitsubishi Montero.
    With respect to the Tacoma, the auto will cost at least $1,800 more (if you can find one without additional packages that seem to come with autos), and if you believe everything you read on TW :), it will require an ECU reflash ($400-500) to make it run/shift correctly, and then need a regear (5.29's if you are "serious" ($2250 -$2,500) so you can sit at a better RPM for more torque and efficiency and something closer to the stock MT gearing.
    If you tow or hard core wheel, then the auto has some advantages but the above listed mods then become more important. Everything's a compromise and every buyer/use case is a bit different. In the end it's your rig that you drive and are responsible for so take all our comments with a grain of salt - just coat that frame early so no salt can get to it and enjoy your choice. :cheers:
    Irons, BurlyJim, Junkhead and 2 others like this.
  2. Aug 17, 2022 at 7:57 AM
    #42
    FreidasBoss
    FreidasBoss Well-Known Member
    PA
    2020 TRD Sport 4x4 DCLB
    I’m in the “manuals are fun but unnecessary” camp.
    BSFord and TacoTime55 like this.
  3. Aug 17, 2022 at 7:59 AM
    #43
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Been all over the east coast with my camper and 6 speed I hate a transmission that can't make up it's mind. Much better towing control. Parking, low range great control first gear. I would fall asleep with an automatic! You haven't lived until you have driven a Mack triplex!
  4. Aug 17, 2022 at 8:04 AM
    #44
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    ^this^. He's posted this same post, almost verbatim, in the last couple of manual vs auto threads here.
    GBR, Irons, BurlyJim and 4 others like this.
  5. Aug 17, 2022 at 8:06 AM
    #45
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    I wouldn't be driving a tacoma if it didn't come in manual.
    GBR, 54_96, 33yrsoftoys and 10 others like this.
  6. Aug 17, 2022 at 8:07 AM
    #46
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Manual cars and manual trucks are two different things. I think its a valid query as they drive much different and you don't often tow with a manual car.
  7. Aug 17, 2022 at 8:15 AM
    #47
    CalcityRenegade
    2023 T4R ORP KDSS
    If the RC series manual transmission was designed for sports cars why was it never used in one? They've been exclusively used in their trucks and SUV's (Tacoma, Hilux, HiAce and Furtuner). Many industries have switched to automatic due to having to attract employees, many of which cannot drive manual. What does old trucks with manual locking hubs have to do with the 3rd gen 2LO mod? Your post is nothing but opinion and misinformation. Perhaps you should co-host with Scotty Kilmer! :rofl:
    GBR, BmTaco91, RicerRabbit and 3 others like this.
  8. Aug 17, 2022 at 8:20 AM
    #48
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I mean, he’s not wrong and does have a point about the hubs. Going into 4LO with hubs unlocked will allow the same amount of carnage as one can do with our 2LOW mod. But people who are dedicated enough to do the 2LM probably are capable of also understanding the risk and acting accordingly. But, he isn’t wrong about the risk, should someone somehow not understand that risk.
    I don’t agree with a single thing he said about automatics being better or the way to go. I will never understand that line of thinking, ever. An automatic can be beneficial offroad so you aren’t working a clutch on rocks in tight situations. Otherwise, there is nothing on the road an auto really does better than anything else. The only reason modern manuals suck is because the manufacturers want them to.
    GBR, oconnor, RicerRabbit and 5 others like this.
  9. Aug 17, 2022 at 8:26 AM
    #49
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I’m not sitting in Bay Area traffic with an MT.
  10. Aug 17, 2022 at 8:30 AM
    #50
    33yrsoftoys
    joel
    mid Michigan
    My first 3 Toyota trucks had manual hubs and transfer case. 2lo wasn't a mod back then, it was a factory option.:thumbsup:
  11. Aug 17, 2022 at 8:30 AM
    #51
    BLtheP
    Plano, TX
    I will never understand the line of thinking that says that there is no reason to choose a manual except a sports car, autos are better, yada yada. Why? Tell me exactly why? What is better? Isn’t that an opinion? The ONLY place I see where autos are the “way to go” is on super tough rock crawling and even that can be mitigated with super deep gearing on a manual.
    As for towing or general daily driving, why is an auto better? Autos like to be in the highest possible gear at any given moment and with modern programming they refuse to downshift until I floor the gas pedal or at least go to 60% throttle or so. Then because I’m using the throttle so much, it wants to haul ass up to a higher speed when all I really wanted it to do was drop a gear and speed up moderately instead of just lugging in the gear I was in. What part of any of that experience is good? The people who like autos are the ones who don’t care how the drive goes. And that is fine, but that doesn’t make them a no brainer choice to buy or the “go to” transmission.
    Traffic is a poor argument to me as well. Traffic sucks, but your right leg is still busy with an auto. And I hate having to hold the brake to not creep. Traffic just sucks regardless of transmission.
    It comes down to personal preference, plain and simple. There is nothing that makes a manual “only for sports cars”. That is just a personal opinion like any other. Personally I think autos are “only for lazies or disableds”, but I don’t go around touting that as fact. Get what you want, but it’s all a preference and opinion thing, not fact. Manuals are fine and if it’s what you want, get it. If you want the automatic, get it. If undecided, drive both and compare specs. Just the gear ratios of the Tacoma automatic make it an absolute no-go for me. Add in the fact that it’s an automatic and I dislike them and it’s not even on the table as an option for me, at all.
    GBR, 6MTPro, OZ TRD and 6 others like this.
  12. Aug 17, 2022 at 8:31 AM
    #52
    BLtheP
    Plano, TX
    Yep, I wish those days came back. I’m going to convert my Jeep to hubs Within the next year. Mainly to stop some front driveline vibes on the road at high speed but a big benefit will be the 2Low capability.
    33yrsoftoys[QUOTED] likes this.
  13. Aug 17, 2022 at 8:31 AM
    #53
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I understand that but if traffic is moving at all I still fine with idling speed. I'm also so glad I live in the boones of western Maine!
    Irons, jayuu and SilverBulletII like this.
  14. Aug 17, 2022 at 8:32 AM
    #54
    BLtheP
    Plano, TX
    My solution for traffic is gear it low and creep in my low 1st as long as possible.
    RicerRabbit likes this.
  15. Aug 17, 2022 at 8:33 AM
    #55
    33yrsoftoys
    joel
    mid Michigan
    ^^this^^!!!
  16. Aug 17, 2022 at 8:47 AM
    #56
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Nah, you just put it in your descriptor. Like meeting someone from California. You always know they are from California, because they tell you in the first 2 minutes of conversation.
    BLtheP likes this.
  17. Aug 17, 2022 at 8:51 AM
    #57
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yep.
  18. Aug 17, 2022 at 8:52 AM
    #58
    era86
    era86 Well-Known Member
    2021 TRD Off-Road 6MT
    My 2021 is a 6MT, and wouldn't want it any other way. My only gripes are:
    1. It only comes with a short bed
    2. That shift into second gear is super jumpy (probably just the way I drive it)
  19. Aug 17, 2022 at 8:54 AM
    #59
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Any risk running 2low in any combination depending on configuration is no different then the risk of running a selectable 4wd truck in 2wd. There are cog locked to the engine/tranny output fractions of a millimeter from another cog that is locked to the driveline. The potential for false engagement is always there, whether it is a module glitch or accidentally bumping a shift knob. If the system is truly understood, then you would know there is inherent risk just getting into your vehicle... why start worrying about the 2low mod... life is too short. Enjoy your vehicle, risks and all...
  20. Aug 17, 2022 at 8:56 AM
    #60
    BLtheP
    Plano, TX
    I agree completely. The risk is no reason to shy away, it’s just a reason to use some common sense and caution. The 2LM is great and one of the most useful changes you can make.
    Junkhead and Speedfreak[QUOTED] like this.
