Manual Parking Question! Truck walking forward slowly while in gear without parking brake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomanrandysavage, May 7, 2024.
  1. May 7, 2024 at 5:43 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Always use 1st or reverse. It will easily roll in higher gears. And if the hill is steep enough it will still roll in 1st.
    Chew and OldSchlPunk like this.
  2. May 7, 2024 at 5:51 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I haven’t tried it, but I’m surprised a newish taco would creep in 3rd gear. How steep was the incline?
    I learned at a young age to use the parking brake. My 4 cyl jalopies didn’t have enough compression to keep the truck stationary on even the smallest of inclines.
    Chew likes this.
  3. May 7, 2024 at 5:56 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Nope, you want a lower gear so if it moves, it moves much less.
    OP, totally normal. When not running and without the parking brake, engine compression is all that's holding the truck in place. Over time, the compression of each cylinder will bleed off through the rings, allowing the crankshaft to move until the next cylinder compresses and then slowly bleeds off, repeat.
    Chew and ThreeBeers like this.
  4. May 7, 2024 at 6:00 PM
    bbal
    bbal Well-Known Member
    ‘23 CSM DCSB 6spd
    I was taught to put it in first when the truck is pointing uphill, reverse when pointing downhill. Supposedly that gives the greatest resistance. Not sure if this is true.
  5. May 7, 2024 at 11:21 PM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    Supposedly the reason is so the engine wouldn’t crank if you left the ignition switch on and drive on down the road. The engine would spin backwards if it started to roll. I imagine if that ever happened alcohol was involved or it was an old VW Beatle.
  6. May 7, 2024 at 11:39 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Happened to me with my 1993 pickup-truck. But I was in a parking lot and on the way back to the truck saw it rolling backwards -
    I literally dove through the window and pulled the brake - stupid thing for me to do with a child nearby but I caught it in time.
    I believe someone reached into the open window and dropped the brake just for kicks. Even to this day I ALWAYS engage that brake even in my automatic trans.
    In fact I 'bout burnt up my sisters brake on her 2006 Corolla last month after I borrowed it and set the brake, she never uses it and couldn't figure out why it was so sluggish...
  7. May 8, 2024 at 12:17 AM
    Foggygoogles
    Foggygoogles Active Member
    PNW
    Army Green 2022 TRD Sport 4WD MT
    you just answered your own question and never really had a problem. Just put it in first and parking brake. Done. No more rolling. Not sure how this is so complicated
    Cetacean Sensation likes this.
  8. May 8, 2024 at 1:07 AM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Most people saying first or reverse but, for clarity, you want to pick the shortest gear available to you when parking. On a 3rd gen V6 Tacoma, that’s 1st gear at a ratio of 3.98:1 vs reverse which is 3.39:1.
    So you should always park it in 1st.
    Chew and doublethebass like this.
  9. May 8, 2024 at 4:18 AM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    If facing downhill use reverse, if facing uphill use 1st. Most mechanical resistance + reverse rotation.
    Only time to not use brake is in a long term storage situation when the shoes can stick.
    Only time not to leave in gear is when vehicle is being trailered to avoid repeated pounding on the ring and pinion and other components.
    doublethebass likes this.
  10. May 8, 2024 at 8:11 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    There was a time when I was a teenager that proper driver's license tests were done where I live. You actually had to know how to drive well in order to pass. Most took the test with a manual transmission. If you didn't park in 1st with the park brake on before turning off ignition it was an automatic fail.
    MagicToolbox and STEELeR43 like this.
  11. May 8, 2024 at 9:18 AM
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    Try first gear. The lower the gear the harder it is to turn the engine.
  12. May 8, 2024 at 9:30 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I always parked in R or L if the transmission had one.
  13. May 8, 2024 at 5:11 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    fun fact, many Saab manual transmissions would only allow key removal when the vehicle was placed in reverse.
    also, 3.98:1 vs 3.39:1 is still plenty of resistance either way...
  14. May 8, 2024 at 7:54 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    This, ladies and gentlemen... is how we end-up with Automatic transmissions.
    :nuclear:
    Self-Driving-cars maybe a good thing in the not too distant future!
    MagicToolbox and doublethebass like this.
  15. May 8, 2024 at 8:18 PM
    #35
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Automatic transmissions don’t help. My first job ever was making booze deliveries for a local liquor store in my hometown. I was 17 and had a pretty new driver’s license. I was driving their crappy Chevy Luv pickup and that truck had a lot of issues. There was a problem with a seal between the transmission and crank case where ATF could seep in every once in a while and the truck would blow a very thick white smoke screen out the back. One day while making a delivery, I was driving up a steep hill and the truck started blowing another smoke screen. It was very thick, and I could just make out a blinking red light shining through the smoke, so I pulled over, put it in Park and pulled the parking brake. Well being a dumb teenager, I got out and went back to meet up with the cop but luckily he didn’t mind. We started chatting about what was wrong with my boss’s truck when all of the sudden there was a ratcheting noise that was speeding up coming from uphill behind me. The cop jumped in his car and started backing up, and I tried opening the truck door but forgot the handle gets stuck so I jumped through the window and tried to tighten up the parking brake but it didn’t work and the truck was coasting backwards even faster with my legs dangling outside of the window. I grabbed the wheel and turned it into the curb and the truck finally stopped. When I got out, I walked back to the cop and all he said was “good, now let’s start that over again”.
    Well, I was pretty mad at my boss by then for making me drive such a crappy truck for work that I helped the cop make a list of all the broken things to be included on his fix it ticket.
    Brie, soundman98 and doublethebass like this.
  16. May 9, 2024 at 12:30 PM
    #36
    Cetacean Sensation
    PNW
    Not saying it isn't. But if you're gonna do it, you may as well do it in the best way you can.
    Also 1st will theoretically be a little nicer to the return spring and the shifter bushings in the long term than reverse.
  17. May 9, 2024 at 12:43 PM
    #37
    81shark
    81shark Well-Known Member
    i suspect this parking space isn't as flat as you make it out to be.
    I'm an R guy in all situations.
    only time i use the parking brake is when i park on a slope.
