Manual side view mirror swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaes843, Nov 13, 2015.
  1. Nov 13, 2015 at 7:45 AM
    tacomaes843
    tacomaes843 [OP] Well-Known Member
    03 Prerunner SR5
    3.5' lift in the front w/ Bilstein 5100 Shocks & Eibach Coils, 1.5' in the back with blocks & billies. Tinted windows. Tinted Tail-lights. Blacked out corner lights. Uws tool box. Whip Antenna. 2nd gen 16' wheels. Flowmaster 40 dual exhaust. 1.25' Wheel spacers all around.
    Hey guys,
    I was wondering if any of y'all swapped those crappy non folding manual mirrors to the taller, folding, power mirrors. On my old truck I had the taller power ones, but on my current taco, I have the manual ones and really prefer the other ones.
    Thanks guys!
  2. Nov 13, 2015 at 8:29 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I swapped from the small, non-folding manuals to large, folding manuals. Love it. Don't need powered.
    If you swap in power ones, I don't know how you would make them powered. Might be a lot of work unless its all pre-wired at the door and console.
  3. Nov 13, 2015 at 8:39 AM
    tacomaes843
    03 Prerunner SR5
    That's perfect man. Where did you get your large folding manual ones?
  4. Nov 13, 2015 at 9:11 AM
    tan4x4
    Rick
    Folsom, CA
    After many trips to the local wreckers (they never had them), I finally ended up getting aftermarket ones from RockAuto.com .
    The quality is not up to OEM standards, though, but acceptable. I got K-SOURCE brand (part numbers 70042T and 70041T), about $50 each.
  5. Nov 13, 2015 at 9:16 AM
    tacomaes843
    03 Prerunner SR5
    I really appreciate that that helps me out tremendously I think I'll probably go with those too.
  6. Nov 13, 2015 at 9:36 AM
    tacomaes843
    03 Prerunner SR5
    How hard was it to swap them out?
  7. Nov 13, 2015 at 11:42 AM
    tan4x4
    Rick
    Folsom, CA
    Very easy.
    The small triangular-shaped trim piece on the inside of the door just pops out .
    Be sure to gently pry FROM THE TOP. If you pry at the bottom, you may break off the lower plastic tab.
    On my '99, the mirror was attached with 3 bolts, but the new one attached with 3 nuts. Your 2003 might be different.
