Manual switched lighting + switched circuits?
Discussion in 'Lighting' started by jsackspot, Mar 29, 2022.
  1. Mar 29, 2022 at 1:10 PM
    jsackspot
    jsackspot [OP] Well-Known Member
    Trying to figure out if this is possible, but is there a switch that can be manually operated (always on/off) in the rear bed/topper and has the ability to be activated by a switched circuit (Switchpros, SPOD, Powerswitch, etc.)? OR a similar solution? Sacrifice always on vs. switchable/is one use case mutually exclusive from the other?
    Envision: overhead glass topper work light.
    Thanks!
  2. Mar 30, 2022 at 6:07 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Might want to fill in the info of what you're situation of use is. And an example of exactly what you're looking to accomplish.
    Switches & relays are basic. If you need something more complicated than a specialized controller would be up your alley.
    And it might be helpful if you describe the ability of the switch you want to use, :
    • SPST (Single Pole Single throw)
    • SPDT (single pole double throw)
    • DPST (double pole, single throw)
    • DPDT (double pole double throw)
  3. Mar 30, 2022 at 6:18 PM
    RDW59565
    RDW59565 Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
    You need a relay with 5 prongs.
    Prong 85 - Ground
    Prong 86 - Power FROM your switch pro or dash switch.
    Prong 87 - 12V positive
    Prong 87a - Power FROM the switch inside your bed. Must be able to carry enough current to illuminate your bed lamp.
    Prong 30 - Power TO your light
    If your switch pro or dash switch is off, then prong 87a will be connected to pin 30. In this condition if your bed switch is off, the light will be off; if the bed switch is on, it will provide power through the relay to the light. If your switch pro or dash switch is on, then prong 87 will be connected to pin 30 and the light will get power from the 12v positive source connected to pin 87.
