Manual Tacoma Aftermarket Lockers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dkarr13, Mar 9, 2021.
  1. Mar 9, 2021 at 9:07 AM
    Dkarr13
    Dkarr13 [OP] IG: Tonya_Tacoma
    Ohio
    2016 Sport MT ACLB MGM
    Too much to name for this little space
    I have a 2016 Sport ACLB MT 4x4... which means no locker. I was trying to find do research on here about another thread or anything about the different lockers but only the air locker from ARB comes up. What other aftermarket lockers are there and does anyone have experiences with them? This could include manual, electronic, or air lockers... and I would only get the rear.
    I also have 275/70R18 with a 4inch Zone lift so I may end up regearing in the future - likely just go up to the 4.88 because I won't go any higher than this size tire. If I did regear in the future, I would need a slightly larger differential so how would that effect the aftermarket locker as well? I figured while I have a professional shop regearing for me, they could also install the locker. Let me know any info you guys have about lockers, regearing, and doing it all at once. Thanks.
    EDIT: Nitro Gear allows you to pick what gear set you want (4.88 or 5.29) and allows you to pick what lockers you want (front and/or rear). For MT 8.75 diff, only ARB rear air locker is available but the front air locker can be ARB, Harrop, or Eaton from this site https://www.nitro-gear.com/Toyota-Tacoma-Nitro-Gear-Package-p/gptaco2016-8.75-select.htm although most people only go with rear locker unless they are doing heavy rock crawling
    EDIT: ECGS also makes a similar kit but still utilizes the ARB air locker
  2. Mar 9, 2021 at 9:20 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    ARB is the only one for your 8.75" rear
    whatstcp and Dkarr13[QUOTED][OP] like this.
  3. Mar 9, 2021 at 9:25 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    https://www.youtube.com/watch?v=x40WGUtdaLI&t=749s
  4. Mar 9, 2021 at 9:27 AM
    Grossomotto
    2017 4WDV6LB6MT
    Forgot to add there's ARB air and Harrop electric for the front.
  5. Mar 9, 2021 at 9:30 AM
    Grossomotto
    2017 4WDV6LB6MT
    @Pablo8 has ARB in the front and rear and he says all is working great, no leaks.
    whatstcp and Dkarr13[OP] like this.
  6. Mar 9, 2021 at 9:36 AM
    Dkarr13
    Ohio
    @Pablo8 that kind of brings the question then.. is both front and rear necessary? In other words, would I get by with just a rear locker? I do not plan to be absolutely rock crawling on a mountainside ever. I just figured I could add in the rear locker while they're in there regearing anyways
  7. Mar 9, 2021 at 9:39 AM
    Grossomotto
    2017 4WDV6LB6MT
    If you're regearing it'll definitely save you money putting it in the same time. You'll have to get a compressor, they're fairly easy to install yourself. Just be sure you get a place that's done air locker installs before, there's a few things that can get messed up especially during install.
  8. Mar 9, 2021 at 9:42 AM
    eon_blue
    Azusa, CA
    Rear only then, you'll never see a need for a front..be a waste of money.
    Mark77 and Grossomotto like this.
  9. Mar 9, 2021 at 9:48 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Great question.
    Does everyone absolutely need a front locker? No. No way. I certainly don't rock crawl. Nor do I go on nasty trails often, frankly. The problem with locking - even the center - ya can't turn!!
    I have used the front locker 3 times. All involved steep hill ice when the locked rear was not getting it done. Compressor was already energized, SWITCH ON. Zip right up. I guess lucky one of the front was catching some traction - didn't know that from the 4WD alone engaged. IF NO wheels are getting traction, you are still screwing the pooch, but seems like with 4 locked, two wheels are not just digging holes, IMHO.
  10. Mar 9, 2021 at 9:53 AM
    Dkarr13
    Ohio
    Makes sense. I will also have a winch in my rear bumper so if it's so bad that I need TWO lockers then the winch will likely be the safer bet anyways.
    Thank you for your help everyone! It's something that's on the radar, just need life to figure some stuff out then I'll be locking with the best of you
  11. Mar 9, 2021 at 9:59 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
  12. Mar 9, 2021 at 10:00 AM
    Grossomotto
    2017 4WDV6LB6MT
    If you're going in sand/mud/offroad quite a bit MaxTrax are always good to have whichever setup you have.
  13. Mar 9, 2021 at 10:02 AM
    Dkarr13
    Ohio
    I actually have a pair of "Bunker Industries Traction Boards" which are over half the price of MaxTrax because I watched Ronny Dahl on Youtube showing off the cheap version vs the MaxTrax and they held up great. But that's a good note
    Grossomotto[QUOTED] likes this.
  14. Mar 9, 2021 at 10:05 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    I'd like to know the answer here too, since I'm pretty much in the same boat as OP.
  15. Mar 9, 2021 at 10:06 AM
    Dkarr13
    Ohio
    Checkout my edit I made in the first post. Looks like we have one option for the rear locker and 3 options for the front if that's what you want
  16. Mar 9, 2021 at 10:07 AM
    Dkarr13
    Ohio
    Went on the site, found the 8.75 manual locker needed, clicked "Buy Now" and an error appeared on the screen lol
  17. Mar 9, 2021 at 10:15 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    ECGS, always.
    Why hasn't anyone already mentioned this?
    luka4600 likes this.
  18. Mar 9, 2021 at 10:16 AM
    Dkarr13
    Ohio
    ECGS uses the ARB air lockers in their kits
  19. Mar 9, 2021 at 10:24 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    This may be a dumb question but if you install a rear manual locker does that affect your electronic limited slip when in 4wd H and the locker is not engaged. In other words do you still have E limited slip?
  20. Mar 9, 2021 at 10:25 AM
    dirty deeds
    Nick
    Eastern KY
    No, they only suggest a selectable locker (air or electronic). Mind you, I'm speaking from a 2nd gen 8.4 rear diff perspective.
    They didn't recommend a manual lunchbox locker for my mostly DD truck, but they didn't tell me to not buy it either.
    I had a mishap with a secondhand 3rd member that had a PowerTrax LockRight drop its pins and springs into the ring/pinion. I got 33s and wanted a regear, it was the best decision at the time to get used. Lucked into it really. Worked great until it grenaded.
    Since they weren't mine and well beyond warranty dates and miles, I went to them again when I was ready to buy. Got a fresh set of 4.88s and a new LockRight installed because my budget didn't want a selectable lol.
