Manual Tacoma Aftermarket Lockers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dkarr13, Mar 9, 2021.
  1. Mar 9, 2021 at 10:27 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    A manual locker will likely override it since they're designed to lock the axles when one wheel slips. How much slip? Idk, ask the enginerds that made it :)
  2. Mar 9, 2021 at 10:41 AM
    stacksmasher
    stacksmasher Well-Known Member
    Look on Amazon. Lots of pics of busted boards...
  3. Mar 9, 2021 at 11:22 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Thank you for your reply. Let me (hopefully) clarify. With my 2009 when in 4H I have automatic limited slip (not open axles). This combination of traction gets me through 95% of the places I take my truck. I’m just wondering if by installing a rear locker if I would still have limited slip when the locker is not locked. Secondly I’m wondering if when in 4H and locked would the limited be trying to work and screw things up. (I believe 2009 and 2010 are the only years Tacos when in 4H the truck automatically applies electronic limited slip. When in 4L no limited slip, open axles unless I do a certain mod)
  4. Mar 9, 2021 at 12:40 PM
    Dkarr13
    Dkarr13 [OP] IG: Tonya_Tacoma
    Ohio
    2016 Sport MT ACLB MGM
    Too much to name for this little space
    Not advocating for the one's I bought, just advocating that MaxTrax aren't THAT much better than the el cheapo ones
    stacksmasher[QUOTED] likes this.
  5. Mar 9, 2021 at 12:42 PM
    Dkarr13
    Ohio
    It's to my understanding that limited slip is overridden as soon as the locker is turned on. The locker makes it so the wheels move in unison with equal power and having limited slip engaged during this defeats the purpose of the locker. Again, this is to my understanding. I'm sure there are way more qualified people to speak on that
    dirty deeds likes this.
  6. Mar 9, 2021 at 1:05 PM
    dirty deeds
    Nick
    Eastern KY
    This would be an instance where a selectable locker would be used. No matter which 4x4 setting you're in. I was open/open, and locked the rear, it's even locked in 2hi (when heavier on the throttle to engage it) for maximum rainy day funsies and snowy butt-pucker moments. However, best my interneting has netted me, the existing limited slip anything is removed and replaced with the locker.
    If you're asking, can I have both? That answer is no.
    Ah, you're referring to the "4LO mod" gray wire/yellow wire write-ups?
    b3itz likes this.
