Manual Tacoma, noticing some things. Are they normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CHess192, Jan 28, 2020.
  1. Jan 28, 2020 at 10:04 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    That feature helps you get out of a hairy situation, it allows you to ride the starter out in gear.
    tonered and ryan760 like this.
  2. Jan 28, 2020 at 10:17 PM
    CHess192
    CHess192 [OP] Member
    2017 Tacoma TRD Sport (Manual)
    None
    Yes sorry mixed up stop and cancel, the original comment said "hill start feature". So I was taking that as starting the truck.
    Junkhead[QUOTED] likes this.
  3. Jan 28, 2020 at 10:25 PM
    shakerhood
    Southern Ohio
    "Hill Start Assist" is what is on the Sport and Manual SR's, it hold the brakes for a few seconds.
    tonered and MOC221_ like this.
  4. Jan 29, 2020 at 5:27 AM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    I have significant experience with MT's but it took me a couple weeks to get used to my OR MT.
  5. Jan 29, 2020 at 5:34 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yep, I like this feature. 2 second hold, or apply throttle to release brakes (whichever comes first).
    I found I was working against the brakes a bit when I first got this 19, but that was just a footwork issue.
  6. Jan 29, 2020 at 5:40 AM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    You engage the hill start feature simply by pushing the brake down farther than you normally need to.
    CHess192[QUOTED][OP] and MOC221_ like this.
  7. Jan 29, 2020 at 5:43 AM
    MOC221_
    Frank
    My RAV4 A/T worked like that...
    Is that in the owner's manual?
    I don't recall reading that... hmm
  8. Jan 29, 2020 at 6:03 AM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    The salesman told me about that.
  9. Jan 29, 2020 at 7:41 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Mine will hold the brakes with even a short push of the pedal if on the slope that it triggers on.
    It has become a minor PITA with the 2LM since almost no throttle is needed, so I am fighting the brakes a bit or playing the guessing game for when it releases.
  10. Jan 29, 2020 at 7:43 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    I've noticed the slight jerk on my 2nd gen too, I think it's just me moving too quickly to get to where I know the clutch starts to engage. It doesn't happen if I go slowly, only if I go somewhat quickly to where it catches.
  11. Jan 29, 2020 at 7:49 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    2nd Gens have the accumulator also. It slows engagements, so that might be your issue? There were a few different accumulator arrangements on the 2nd Gen. One has enough line slack where you can just bend the lines and install a coupler.
    This was posted in the 2nd Gen forum and was what kicked off my research:
  12. Jan 29, 2020 at 7:56 AM
    Taruuk
    Taruuk Well-Known Member
    2017 Tacoma OR MT AC
    I have a very similar situation. 2017 Taco OR MT SB LB, 69k. Like many other drivers, I've stalled in reverse. When I try to turn the engine over again it takes ~4 seconds to catch. I've put a multimeter across the battery while starting and had a max voltage of 13.8V and min of 10.3V.
    Not likely to take it back to the dealer at this point but definitely glad to see this thread. Sub'd!
    CHess192[OP] and Junkhead like this.
  13. Jan 29, 2020 at 8:15 AM
    Aspen Thicket
    Aspen Thicket Well-Known Member
    Da U.P. of Michigan
    I have a 2019 MT and I occasionally get the slight jerk from time to time and from what I read, the accumulator causes most of it.
    Still dealing with a buzz in my clutch pedal over 3000 RPMS if anyone wants to chime in :)
  14. Jan 29, 2020 at 8:20 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Sometimes my starter makes a high pitched noise when I stall or turn engine off and back on quickly.
  15. Jan 29, 2020 at 8:25 AM
    #35
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I bought a 2017 MT brand new and now have 50K miles. What your describing is exactly what experienced until I reflashed the ECU with the new factory tuning.
    there’s a big thread on this.
    I now have OVTune, and now I don’t experience any of this anymore.
    Junkhead likes this.
  16. Jan 29, 2020 at 1:22 PM
    #36
    sublime1996525
    sublime1996525 Well-Known Member
    SL,UT
    I thought I saw on Toyota's website it is on the OR? And I've read of certain OR trucks having this feature. Weird.
  17. Jan 29, 2020 at 1:25 PM
    #37
    shakerhood
    Southern Ohio
    Off Road and Pro Automatic, no MT Off Road or Pro have it..
    doublethebass, tonered and Junkhead like this.
  18. Jan 29, 2020 at 1:32 PM
    #38
    sublime1996525
    SL,UT
    Ah. Good to know. Thanks! :cheers:
    shakerhood[QUOTED] and Junkhead like this.
  19. Jan 29, 2020 at 1:33 PM
    #39
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I shouldve been more clear, i was referring to MTs only.
  20. Jan 29, 2020 at 1:33 PM
    #40
    cludwig
    cludwig Well-Known Member
    2019 TRD Off Road DCSB MT Barcelona Red (fastest color)
    Alu-Cab Explorer Canopy, 23 Zero 72" RTT, Rhino Rack Batwing Awning, ARB Suspension, 235/85R16 K02 tires, Hondo radio knobs, Taco Garage DMM...
    Yup, I am still jerky with it after a year because of that. As to resetting the computer after a stall to get a successful start, that too has happened a couple ties to me.
