Manual Tacoma Slip?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 19Tacomas, May 31, 2024.
  1. May 31, 2024 at 11:59 AM
    19Tacomas
    19Tacomas [OP] Member
    TRD Sport
    Question for Manual Tacoma owners:
    I recently purchased a 2019 Manual Tacoma and it has been amazing so far. I noticed something while driving that I'm hoping is normal. Sometimes when I'm accelerating in first or second gear I can feel some slip. It normally happens when I'm turning while accelerating. It also definitely feels way more like it's traction control related instead of clutch slip. It could also be an issue of me letting out the clutch a little too early and getting some lurch.
    Have any of you long time 3rd gen tacoma owners noticed this?
    Thanks!
  2. May 31, 2024 at 12:42 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The rear end is light. If you tap a little harder, you would likely see the TCS light flashing.
    Most times, you are more likely to see clutches slipping in the top gears, 5th and 6th, under full load.
  3. May 31, 2024 at 5:36 PM
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    I've experienced something similar in both of my 2nd and now in my 3rd gen when they're not quite completely warmed up. There's a particular stop sign a few minutes from my house that I will often notice some "slip" pulling away from. Always chalked it up to the truck not being warm enough for my usual clutch drop. That's the closest thing I've ever noticed, might be what you're describing. Seems perfectly normal at this point, put 350k on 2 different stock 2nd gen clutches. My 3rd gen has almost 40k, the clutch still feels brand new.
    doublethebass likes this.
  4. Jun 1, 2024 at 11:18 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    What is mileage of your 2019 Tacoma? Did check out condition of transmission gear oil, or change it out? Suppose to be GL-4, SAE 75w-90 synthetic gear oil, if you going to replace it.:D
