Manual to Auto Tranny Swap???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blankman25, Jan 24, 2011.
  1. Jan 24, 2011 at 4:59 PM
    Blankman25
    Blankman25 [OP] New Member
    Brandon
    Dodge City KS
    01 sr5 taco trd supercharged
    As of Right now i have a 01 manual tranny in my truck i am looking to swap in a auto tranny. What all will i need to replace? i have a second truck with an auto and was looking to just swap the tranny.
  2. Jan 25, 2011 at 4:17 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
  3. Jan 26, 2011 at 8:40 AM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    Dibs on your center console/cupholder/gear shift trim
    Please
  4. Jan 28, 2011 at 8:51 AM
    Blankman25
    Brandon
    Dodge City KS
    well the thing is that my friend has the other truck which is auto. he wants a stick so we planned on just swaping trannys cause i dont want to do a total engine swap because i like the engine in the truck now.
  5. Jan 28, 2011 at 11:07 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    ^^^ what he said!
  6. Jan 28, 2011 at 11:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You'll have to swap the ECM along with the tranny, and drive shafts (the 2 are different length), other than that, it should be a straight swap. If you have the time, and patience, its not too bad.
  7. Jan 30, 2011 at 2:55 PM
    The Munster
    The Munster I like turtles!!!
    Lance
    Moody AFB, GA
    what he said. but you also can't forget about the little things. the auto will need a kick down cable for the trans. plus you might need a new radiator if yours doesn't already have the tranny cooler lines
  8. Jan 30, 2011 at 3:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The auto is all electronic control, and the throttle is a throttle by wire assembly. No cable needed, and the radiator has connection ports for the auto tranny fluid.
  9. Jan 30, 2011 at 3:59 PM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    No drive by wire on my 04 cable.
  10. Jan 30, 2011 at 4:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....I thought the OP was talking about the second genners. :eek:
