Manual to Power Windows Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomathunder, Jun 18, 2012.
  1. Jun 18, 2012 at 12:45 PM
    tacomathunder
    tacomathunder [OP] Well-Known Member
    Florida
    07 4 cyl reg cab
    pop-a-lock on tailgate, tailgate damper by ez down, extang platinum snap tonneau cover, rampage LED light bar, etrailer wiring harness, black led tail lights, tsi clutter catcher center console, griffin itrip ipod player,BHLM,35W DDM Tuning hid's 5000K, Day Time Running Light Mod, New Sony Stereo
    I really would like to put power windows in my reg cab tacoma...anyone know of a step by step guide i could follow? also where could i get the needed motors and switches and such??? and last question, if i did put in power windows- could i put the buttons to open the windows on the unused button area to the bottom left of the steering wheel? i would only need two switches, it doesn't matter to me that there wouldn't be a button for the passenger to use, just as long as i can operate the window...
    ps, what would i do with the manual window operation handle if i did put in power windows?
  2. Jun 18, 2012 at 12:48 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    I'm sure someone will chime in with some websites. I'm wondering if you can go to Toyota and get the parts, although who knows what that would cost. Maybe you could go to a junk yard and get some parts cheap
  3. Jun 18, 2012 at 12:48 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  4. Jun 18, 2012 at 2:09 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    bump..anyone?
  5. Jun 18, 2012 at 5:29 PM
    Pugga
    Massachusetts
    You're better off getting new door panels and have the switches mounted where they're supposed to be. You would then not have to worry about the holes in the old door panels where the handles mount. Just my $0.02 but if I were you I'd start raiding local junk yards for parts or find someone local who gutted their truck and is parting it out.
  6. Jun 18, 2012 at 9:10 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Since regular cab trucks aren't offered with power windows and locks, the first question to ask is if the doors will even accept the parts from an access or double cab truck. They may be totally different. Time to make friendly with the dealership parts guys.
    I agree that it would be cleanest to find all the factory parts to swap over off a wrecked truck.
    Someone here did a writeup awhile back on adding power windows (and I think locks too) to a regular cab. He used universal stuff though. It turned out good, but didn't quite look factory. He sounded like he was happy with it.
    Edit: Not the writeup I was thinking of, but the same type of parts used: http://www.tacomaworld.com/forum/2nd-gen-tacomas/210568-added-power-locks-windows-2012-a.html
  7. Jun 18, 2012 at 9:38 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    nice! i want to do exactly that but put the window buttons on the unused button areas to the left of the steering wheel
  8. Jun 18, 2012 at 9:43 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I looked into this on a previous truck, most of these kits come without switches, you have to order a switch kit in addition to the motors and hardware. If I remember correctly there was a two switch kit designed to be mounted in the center console, like in a lot of european cars. You could order that. Might have to extend a few wires to reach the passenger side door.
  9. Jun 19, 2012 at 10:53 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    looks like the one mentioned in the thread above has switches, for the windows at least
  10. Jun 19, 2012 at 11:08 PM
    joes06tacoma
    Joe
    Central Coast, CA
    http://www.a1electric.com/catalog/cat_spalacc.htm
    Check that out. It lists the different kits and switches available.
    Edit: I don't see the center console/ one set of switches only option there.
    You could just mount the driver's side switches in the dash and leave the passenger switch ziptied behind the dash or inside the passenger door. Or modify the harness and remove the passenger's door switch.
  11. Jun 21, 2012 at 1:12 AM
    tacomathunder
    Florida
    07 4 cyl reg cab
    just found this website with these things to do this kinda OE.... would these work?
    http://www.autopartsdeal.com/catalo...5+11782+4294962950&y=2007&mk=Toyota&md=Tacoma
    http://www.autopartsdeal.com/catalog/?N=1725+11782+4294962950+9331
    with the window regulator with motor...that means i wouldn't have to buy the motor to roll the window up and down correct? or is that a different motor?
    also, i was wondering if the base reg cabs are pre wired to just plug and play this stuff? i did that for the intermittent wiper and cruise control, so i was wondering if this would be similar?
  12. Jun 21, 2012 at 9:30 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
  13. Jun 21, 2012 at 10:01 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Regular cab trucks don't come with power windows. Not unless it's new in the last couple years. So I doubt there is any wiring there to run them.
    Regulator with motor would be all you need to raise the window. No other motor needed. Just a way to power it up.
  14. Jun 22, 2012 at 3:18 AM
    tacomathunder
    Florida
    07 4 cyl reg cab
    what if i just got the motor without the regulator, because I'm guessing there is already a regulator on the window, but for the manual operation... would just the motor work?
    ps, the wiring shouldn't be too hard if i have to wire it myself, id just need some directions on how to do it, I'm good at doing the wiring as long as i have some direction to go in
  15. Jun 22, 2012 at 5:25 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I don't think it works that way with factory stuff. Again, I would make friends with the parts guy at the dealership. They could tell you if just the regulator is the same from manual to power.
    The wiring is very simple if you don't need a switch on the passenger's door. If you do want a switch on their door, then you need a switch made for that specific application. Otherwise, you can use any momentary DPDT that you can fit in the dash.
  16. Jun 22, 2012 at 7:06 PM
    tacomathunder
    Florida
    07 4 cyl reg cab
    alright cool, i really have to start looking in to what i actually have to do...and I'm fine with just a switch for the drivers side and a switch for the passengers side on the drivers side of the car, i don't need to have a separate switch so the passenger can operate the window
