Manual Tranny Gear Oil recommendations
Discussion in 'Technical Chat' started by srsupertrap, Jan 13, 2010.
  1. Jan 13, 2010 at 8:23 PM
    srsupertrap
    srsupertrap [OP] Well-Known Member
    Erie, CO
    2001 Tacoma SR5 V-6 TRD 4 X 4
    Bilstein 5100s, Borla 14945 S/S Exhaust, Fram Air Hog Filter, Diff Breather Mod & NGK Wires
    Goinging to change out all the manual trans & Differential gear oil on my 2001 Tacoma TRD 4X4 which has 112K on it and rear differential lock. The Service manual specifies the following grades & quantities
    Transmission: API GL-4 or GL-5 75W-90 (2.6 Quarts)
    Transfer Case: API GL-4 or GL-5 75W-90 (1.1 Quarts)
    Front Differential: Hypoid API GL-5 75W-90 (1.2 Quarts)
    Rear Differential: Hypoid API GL-5 80W-90 (3.2 Quarts)
    What do you guys recommend? Looks like I need 2 gallons so the synthetic route would be pretty expensive considering Mobil 75W-90 is about $10 quart.
    TIA
  2. Jan 13, 2010 at 8:30 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I used Mobil 1 for the rear end. Royal purple for the trans. I am RWD, so no transfer case.
  3. Jan 13, 2010 at 8:44 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I would stick with good old conventional for the transmission. If you read around, you'll notice a lot of people having issues with 1-2 shifts after changing out the trans oil to synthetic.
    Personally, I changed the oil in mine about 2k back and went from the conv. toyota gear oil to Valvoline SynPower. It is a great oil, and has all the certifications you could ask for... API MT-1, API GL-5, MIL-PRF-2105E < Mil-Spec, SAE J2360, and Mack GO-J but still performs like shit in these transmissions. The 1-2 shift just feels terrible. On a cold morning, it will take a good two seconds to even drop into second gear, while many times getting a little grind to it.
    Bottom line is, if you change you oil out on any kind of a regular basis, there is absolutely no advantage to synthetic over conventional oil other than in the most extreme of conditions. Even there, you have a high probability of that transmission outliving the rest of your ride.
  4. Jan 13, 2010 at 9:01 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    I would stick with the OEM toyota oil. We all know it works well.
  5. Jan 14, 2010 at 5:53 AM
    srsupertrap
    Erie, CO
    Well I guess we share the same symptom of the 1-2 shift is notchy at best and just plain crappy most of the time. I was thinking synthetic might make that symptom go away.
    Thanks for the back ground and edmucation :)
  6. Jan 14, 2010 at 6:02 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I had good luck with the synthetics making the shifts a little smoother.
  7. Jan 14, 2010 at 6:04 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    Amsoil or Mobil 1. I used Amsoil in my 98 without issue. I have heard good things (no negative) about Mobil 1 also.
  8. Jan 15, 2010 at 8:22 PM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    I used Royal Purple and have the typical problems (1-2 shifts, notchy) but only when really cold and it goes away after truck warms up.
  9. Jan 15, 2010 at 8:24 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
