manual tranny leaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by matthew5olson, Mar 18, 2010.
  1. Mar 18, 2010 at 8:19 PM
    matthew5olson
    matthew5olson [OP] Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    my manual tranny is leaking where it meets up with the transfer case. (5speed mounted to a 3.4L) I looked into removing the transfer case and putting a new gasket on it but the instructions (haynes) said to only drain the transfer case fluid. I thought maybe there was not supposed to be any fluid in between them. Maybe I have a rear tranny seal that went bad? anyone taken them apart and know whats inside?
