manual tranny wont shift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sbentley, Apr 15, 2015.
  1. Apr 15, 2015 at 6:51 PM
    sbentley
    sbentley [OP] Member
    shane
    Washington
    06 tacoma sr5
    06 tacoma sr5 2.7 L 5speed. Kinda noticed what seemed like axle rap when I took off went to investigate when I got home noticed nothing. Went to go move my truck and wouldnt go into gear. Turned my truck off and put into gear then started. It was acting like the clutch aint disingagin. No fluid on slave cylinder rod nothing.. im lost.
  2. Apr 15, 2015 at 7:21 PM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Bad clutch or pilot bearing seized.
  3. Apr 15, 2015 at 7:23 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Check your clutch cyl as well
  4. Apr 15, 2015 at 7:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't agree with the Pilot Bearing having anything to do with it.
  5. Apr 15, 2015 at 7:47 PM
    sbentley
    shane
    Washington
    06 tacoma sr5
    Im goin with like a broke spring in the clutch disk maybe. Whenbyou get it into gear its almost like a axle rap but can also feel the clutch not all the depressing still grabs
  6. Apr 15, 2015 at 7:59 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    I'd lean toward master or slave cylinder issue, or the line. Springs won't cause the clutch to lock or hang, they just help with smooth engagement. Does the clutch pedal feel like it has the normal resistance or does it seem very light?
  7. Apr 15, 2015 at 8:04 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    when you start it in gear does it want to move on you?
  8. Apr 15, 2015 at 8:08 PM
    RobertHyatt
    Robert
    Birmingham AL
    Can you actually do that? Or does it have a safety switch requiring it to be in neutral?
  9. Apr 15, 2015 at 8:11 PM
    high n mighty
    Oshawa Ontario
    01 camo taco
    Its a clutch position switch on a manual, just wants to see if the clutch is pushed in or not, so yeah itll start in gear with the clutch pushed in
  10. Apr 15, 2015 at 8:12 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Wrong. Damper springs that break or come out of the disc will most certainly cause a clutch to not release. They will jam up on the flywheel bolts, or within the springs and levers of the clutch cover, and drive the disc even without any plate load
    While not as common of a failure in automotive clutches, it is by far the most common failure in a heavy duty truck clutch, and fixing them is my world 40+ hours per week.
    I'd still check that the hydraulic portion of the clutch system is working properly before removing the transmission though, for obvious reasons.
  11. Apr 15, 2015 at 8:12 PM
    sbentley
    shane
    Washington
    06 tacoma sr5
    Yes it moves when I start it in gear
  12. Apr 15, 2015 at 8:14 PM
    sbentley
    shane
    Washington
    06 tacoma sr5
    Pedal does feel light and looked at my slave and the fork moves but dont look like it moves much
  13. Apr 15, 2015 at 8:20 PM
    high n mighty
    Oshawa Ontario
    01 camo taco
    if the peal is soft and there is no leak then its either your slave or you master cylinder
  14. Apr 15, 2015 at 8:23 PM
    sbentley
    shane
    Washington
    06 tacoma sr5
    Question. Im not smart on cars but im also not dumb. I cant find the clutch master. I followed the line from the slave it goes up and into the firewall that goes to my clutch pedal. . Then from my break master a bigger hoes goes threw firewall and bottom of pedal also. Is my clutch ran off my break master?
  15. Apr 15, 2015 at 8:25 PM
    high n mighty
    Oshawa Ontario
    01 camo taco
    sounds like it
  16. Apr 15, 2015 at 8:30 PM
    sbentley
    shane
    Washington
    06 tacoma sr5
    If it is ran off my break master dam I hope it aint that. Im gonna go cheap and easy first and replace the slave tomorrow.
  17. Apr 15, 2015 at 8:32 PM
    high n mighty
    Oshawa Ontario
    01 camo taco
    Sounds like a plan
  18. Apr 16, 2015 at 1:35 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Your brake system is separate from the clutch with the exception of the fluid reservoir which they share ( large hose ). The clutch master cylinder is at the other end of the hose from the brake master cylinder. Follow the hose from the brake
    master cylinder through the firewall and it will lead you to the clutch Master cylinder.
    Sounds like a worn out Master / slave cylinder or both and or air in the system.
  19. Apr 16, 2015 at 4:18 AM
    gearcruncher
    Canadain bumper technician
  20. Apr 16, 2015 at 7:48 AM
    sbentley
    shane
    Washington
    06 tacoma sr5
    Ok ya after pondering on it all night kinda figured thats what was goin on. Clutch master is under the pedal and they just share reservoirs. Now that I know that I will try and blead It or just change slave and go from there.
