Manual tranny
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aman1, Jan 22, 2021.
  1. Jan 22, 2021 at 7:46 PM
    summithightacoma22
    summithightacoma22 Well-Known Member
    michael
    denver
    2013 grey tacoma trd sport
    front +2 allpro long travel with kings. Marlin crawler lca reinforcements, alpine design cab mount. All pro spindle and upper control arm reinforcements. Willwood 6 piston front calipers and 2 piece rotors. rear 7 pack expedition soa, 12 2.5s, archive garage shock relocation kit. Archive garage shackle flip kit. wheels 285/75/17 geolander g0003 on 17x9 with a zero offset. engine bay. antigravity atx hd-20 lithium battery arb high capacity air compressor. 3* exhaust cam timing. intake spacer custom stuff custom made sliders, custom bed rack system, custom drawer and bed system, modified mounts for arawak awning. Fiberglass/lexan cap door. Boxed out frame in spots I could reach. soon to be a chopped bed at the rear axle interior -lathewerks co polymer stainless shift knob, modified from a wrx to fit. -pioneer mid and treble speaker replacement. -future mods -4.56 gears arb front and rear lockers -traction bar for the rear. -full carbon front clip. -supercharger eventually.
    i have a 2013 I bought with 50 miles on it brand new from the dealer. I am at 101,000 miles still on the stock clutch and it seems to be just starting to slip when trying to pull something more than the tacoma. Stock driving around my truck on roads is fine, but if throw on a trailer or try to do stupid stuff in 4low i can smell it burn and feel it slip.
  2. Jan 22, 2021 at 8:05 PM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Love mine with two caveats: can't stand the clutch feel with the accumulator/valve on there. Popular simple mod is to delete/bypass it for a more tactile clutch feel.
    Also, gotta admit the 6speed gearing is a bit funky. First is a tad low but good for towing, but its a pretty steep jump to second. I feel those two ratios should be a bit closer together and took me a while to get used to. The rest aren't bad at all once you gain some speed. Reverse is geared rather high as well but never really been a problem for me personally.
    All in all I'm happy with mine. 120k so far on the original clutch, no slipping as far as I can tell. Shifts smoothly and the 3rd-6th ratios seem to work well whether loaded, towing, or empty.
  3. Jan 22, 2021 at 8:06 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I had an 08 and a 15 6MT, both felt just fine.
  4. Jan 22, 2021 at 9:06 PM
    TacoTuesday1
    SD CA
    6spd manual trans throwout bearing system was designed by a potato
    vtown, Marc70 and spencermarkd like this.
  5. Jan 22, 2021 at 9:51 PM
    Jbuck88
    Jbuck88 New Member
    12 trd OR
    Have 120k miles on the ODO and still on the original clutch. I am waiting for it to go out as I've smoked it pulling trailers and teaching my kid how to drive it.
    OTOH I just replaced the stock brake pads at 120k miles.
  6. Jan 22, 2021 at 9:58 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Well the 5spd is a r155 trans, and everything I've read about them says they're solid until 700 hp when they start leaking out the rear seal. But if you're not pushing 700 hp... it will definitely take a beating and keep working just fine.
  7. Jan 23, 2021 at 7:22 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I've driven both MT & auto's forever. First Taco I owned was a "98" 4 cyl. MT, loved it for appx. 10 yrs with no problems. At 65 yr. old I decided I was old & wore out enough to quit the shifting. I traded for a 2013 Taco 4 cyl. auto., one of the worst decisions I ever made. For a 4 cyl. definitely a MT.
    Marc70 likes this.
  8. Jan 23, 2021 at 7:29 AM
    AdamM
    AdamM Semi-pro aardvark wrangler
    Adam
    Edmonton, AB
    14 DCSB base 6MT 4x4
    I have a 14 6sp, I've owned since new. It has around 160,000km on it. The throwout bearing started to squeak around 100,000km. Still have the original clutch. The constant squeak from the throw throwout bearing is pretty annoying, but hasn't caused any issues.
    Marc70 likes this.
  9. Jan 23, 2021 at 7:41 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    My 2014 is just about to roll over 108,000 miles and I bought it when it was a year old with just under 12,000 miles on it. Stock clutch is still solid and doesn't give me any trouble. I rarely tow.
    The only time I've regretted it was the few times I was stuck in traffic for extended periods.
    If I ordered a new truck today, it would be a manual transmission. My wife's Corolla is a six speed manual and she likes it. She hates driving my truck because she thinks the clutch is too stiff.
  10. Jan 24, 2021 at 5:42 AM
    Sailor_Nick
    Sailor_Nick Well-Known Member
    Massachusetts
    2011 Tacoma TRD-OR DCSB 6-speed
    My 2011 DCSB 6MT is at 314k miles now and is driving better than ever. Clutch lasted 273k before replacement.
    Change the fluid regularly like said before.
    Mods NEEDED to decrease the clunkiness when releasing the clutch are:
    • Delete the Clutch Delay Valve (CDV Delete)
    • Drill, tap, and install a grease zerk into the rear driveshaft slip joint and grease it with molybdenum grease.
    • proper U-Bolt torque
    Marc70 likes this.
  11. Jan 28, 2021 at 7:23 PM
    SixFifty
    SixFifty Member
    Pac NW
    2006 - started dropping reverse 2 150K (only under load), first clutch 310k, totaled 346k)
    2015 - running smoothly
  12. Jan 29, 2021 at 9:04 AM
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
    When I test drove my truck, the shift pattern was totally worn off so I had to Google how to get it into reverse lol
    spencermarkd[QUOTED] likes this.
  13. Jan 29, 2021 at 6:03 PM
    jakezna
    jakezna Well-Known Member
    I can add a little to the bum knee post above. That's great advice for anyone with a bad shifting leg because Tacoma clutches shift like 60's dump trucks for sure. I have a 06 MT that I bought, well, back in 06. The clutch went out I think at about or a little after 100K miles. I also have a bad clutch leg so driving in long stop and go traffic, or driving in a big busy city will deff hurt.
    I've been trying to find a 09ish automatic 4runner because of my leg issues. I've given up on automatic Tacomas because they're just too expensive for my preference.
    Hope this helps in some way.
  14. Jan 30, 2021 at 6:31 AM
    thegreatga
    thegreatga Member
    wyatt
    lancaster ohio
    15' dbl cab v6 6spd TRD PRO
    TRD Pro
    I have a 2015 TRD Pro 6mt double cab with 135,000 miles no issues (purchased new). Original brakes, clutch, and all fluids, and put new tires on @ 100k. I tow my 16' utility trailer and heavy stuff very often, and typically at max capacity of the truck. Just this week I decided to change the front brakes and change all the fluids. The only problem I've had, is a squeaky clutch pedal and the trans does have some very slight gear whine at highway speed. I do agree, first gear is dump truck gear, but its great for towing. As long as you understand it's a truck, not a sports car, they are solid transmissions.
    sgage likes this.
  15. Jan 30, 2021 at 8:20 AM
    #35
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    WHAT KIND OF TIRES??? I'd love to have some 100K tires, mine definitely won't do near that much.
  16. Jan 30, 2021 at 11:14 AM
    #36
    thegreatga
    thegreatga Member
    wyatt
    lancaster ohio
    TRD Pro
    Factory installed bfgoodrich all-terain KO. Loved them!
    Marc70 likes this.
