Manual Trans: Do All of Our Toyota Clutches Squeak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plannerman99, Jan 24, 2010.
Do All Of Our Clutches Squeak?
  1. I have a manual trans and its squeaks.
    60.5%
  2. I hava manual trans and it has never squeaked.
    27.2%
  3. I have an automatic and I don't have to worry about this.
    12.4%
  1. Jul 26, 2012 at 12:20 PM
    #141
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    My 09 clutch pedal started creaking (more of a creak than a squek haha) at around 18000 miles and its pretty annoying, havnt gotten around to trying to fix the issue tho. Its real bad when its hot and it seems worse when its hot a very humid like today.
  2. Jul 28, 2012 at 9:41 AM
    #142
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    09 with 45k just started squeaking :(
  3. Jul 28, 2012 at 11:14 PM
    #143
    Copperdoc1
    Copperdoc1 Capt Caveman
    Justin
    Ohio
    Total chaos UCAs, 265/75-16s, BAK rollback tonneau, custom lights and rack.
    2009 2.7 5 speed, 30000 miles just started squeaking. Judging by everyones replys, it seems there is no permanent fix. How about rebuilding it with a steel arm with spherical rod ends? I haven't really got under it yet but that my plan. More to follow . . . .
  4. Aug 15, 2012 at 2:13 PM
    #144
    evanmb31
    evan
    connecticut
    09 trd off road
    The spin the rod mod worked for me haha, suprisingly it hasnt squeked for 3 weeks now.
  5. Aug 15, 2012 at 3:24 PM
    #145
    As4Anger
    As4Anger Member
    TX Pro
    TRD short throw
    Had a 99 TRD Tacoma that creaked for over a decade. Problem was a plastic bearing that wore out about every 10-15k miles. Lost count how many times I replaced it. I would live with it for a while until I wanted to drive my truck off a cliff then I would replace it. Heard about the spin the rod fix back then but it never fixed the problem. Just bought a new Tacoma in a MT. Glad to hear Gen 2 Tacos still have this problem.... At least if my new one starts the creaks I will know why. :facepalm:
  6. Aug 17, 2012 at 7:53 AM
    #146
    cameron172
    cameron172 Well-Known Member
    VA
    2017 Super White TRD Sport MT
    2009 4 cly with 65k. Darn thing started squeaking only days after I drove it off the dealership lot with 59k on it. Seems like everyone with the squeak has a different part of the clutch assembly causing it. From the pedal to the actual transmission. Quite annoying.
  7. Aug 19, 2012 at 6:52 AM
    #147
    Chris24
    Greensboro, NC
    annoying and embarrassing! i hate when people riding with me ask "what is that noise!?" and i think oh it's just my $30,000 truck with a defective clutch pedal...
  8. Aug 21, 2012 at 1:46 PM
    #148
    daleyswanson
    daleyswanson Active Member
    Enterprise, AL
    6spd 05 DCSB 4X4
    Got rid of the Dungflops. Lift to come.
    05 w/ 71k on the clock squeaks all the time. The dealership informed me of the TSB, but also said they have replaced the throwout bearings only to have the same truck come back in the next week with the same problem. Ug. :(
  9. Aug 22, 2012 at 1:53 AM
    #149
    oneshot808
    oneshot808 Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    63,000 miles and it went from soft squeak to very annoying squeak. If I drive next to cars that reflect the noise and I have my windows down....kinda sounds like a bunch of crickets under the carriage...
  10. Aug 22, 2012 at 8:51 AM
    #150
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    This is really the only thing that annoys me about the Tacoma. I have a 2010 Off Road with only 16,000 miles. Especially when it is warm outside, the damn clutch squeaks and it is even worse when it is hotter.
  11. Aug 22, 2012 at 6:33 PM
    #151
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  12. Aug 23, 2012 at 9:21 AM
    #152
    Oengus1963
    Oengus1963 Member
    Michael
    Cleveland
    Tacoma 2WD Base
    NONE
    I had a 1992 and it had a metal clutch pedal and never made a sound, the next vehicle I own is the current 2004 at has similar shape clutch arm as the 1992 except its plastic and it squeaks.
    I test road a 2010 with 12k on it, its pedal is plastic and a different design it creaked, under closer scrutiny it also had lateral movement, not a lot but some the 2004 has no lateral movement. A clutch pedal should not move at all from side to side.
    I have seen and heard that others have the same problems, the later models have in some instances a terrible lateral movement.
    I was wondering if I can install a earlier model assembly that is metal on my 2004? I may but finding one may be difficult or expensive. What was the last model year for a metal assembly. I wish I had two to compare.
  13. Aug 23, 2012 at 12:36 PM
    #153
    shemp
    shemp Well-Known Member
    It doesn't matter what material the pedal itself is made out of, the problem here is that both the seat (pedal) and the rod cap are made of plastic, and there is nothing present to make sure that fresh grease is continually pushed into the point of contact. When the plastic gets dry, it begins to stick and creak.
    Putting in a nice big blob of lithium grease (which is what appears to be in there from factory) should keep the noise at bay for quite a while. In fact, I think that you can fix it permanently like this;
    The first step would be to eliminate most of the slack in the pedal between when it starts moving and when it finally contacts the rod end. Not only will this make the clutch feel 1000x better, it is necessary in order to prevent the grease from being pushed out later. At the top up where it is very difficult to get your hand into, the clutch stopper / cruise cancel switch is threaded and adjustable. Adjust to eliminate most (not all) slack, not all because you don't want to leave any pressure on it.
    Use lithium grease, and pack it into the cup. Lots of it. Try not to make any air bubbles in it.
    My hope is that when the rod moves, rather than pushing grease out of the joint, the excess grease will create a vacuum and draw grease into the void behind the point of contact. If that happens, the contact point will remain lubricated permanently. If not, a blob of lithium grease will fall on your shoe.
    A much more complex solution would be to replace the two connections with a dog bone. Dog bone with two ball and cup joints on either end made of steel. The pedal would definitely have to be modified though.
  14. Aug 23, 2012 at 4:23 PM
    #154
    Plannerman99
    Plannerman99 [OP] Well-Known Member
    So Cal
    Our Adventure Vehicle
    I don't think this is actually the problem. There isn't any inherent characteristic of the plastic that indicates that plastic on plastic should squeak, especially given the relative amount of slack available in the seat in the back of the pedal.
    I believe the problem is that the bushing (or whatever) that the piston runs through has enough friction that it causes the piston, an by default the end cap, to twist in the seat in the back of the pedal (right hand rule of physics). With enough twisting, tension is created between the end cap and the seat, causing squeaking. Conceptually, grease should relieve some of this friction, but it doesn't always last and seems to drip onto feet. I no longer have my manual Taco, but still wonder whether modification to the dimensions of the end cap or the pedal to prevent the minor binding of the end cap or shims of some sort on either side of the end cap would have fixed the problem. The dog bone idea seems like it would accomplish a similar outcome.
  15. Aug 23, 2012 at 4:28 PM
    #155
    tacohound
    tacohound Well-Known Member
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    Smitty built light bar, 4 Hella 550's, Tan HLM and badges, Black sport rims
    I used white lithium greese on the plastic plate the crutch slides against to stop the creeks, I havent had a creek since but I prolly just jinxed myself soooo FML lol
  16. Aug 24, 2012 at 7:16 AM
    #156
    shemp
    It isn't just pressure. There is lateral motion between the two pieces of plastic, when there is nothing to lubricate them, they stick and squeak.
    The piston has nothing to do with it. The noise comes from the friction between the plastic end cap of the master cylinder rod and the "cup" that it sits in, which is moulded into the lever itself. It is essentially a 100% plastic ball-and-cup joint. When there is no grease to lubricate the point of contact, the ball (which isn't even round) scrapes in the cup.
    Consider what happens to front end ball joints when they run dry. They start making creaking noises, don't they? That is precisely what is happening, except that the ball joint in this case, is made of plastic.
  17. Aug 24, 2012 at 12:11 PM
    #157
    Plannerman99
    So Cal
    Well, we'll just have to agree to disagree, then. Please understand where my experience is coming from: this happened to my 2009 and we could see the wear at the corners of the end cap where it was binding in the back of the pedal. You are right that the noise isn't coming from the piston. It is the friction of the piston moving against a bushing or seal that causes the piston to twist, in turn causing the end cap to bind in the back of the pedal. If the pedal were steel, the end cap would probably be unable to spin as much as it does. The lithium grease reduces the friction of the twisted end cap, reducing the squeak. Until it drips out or wears away. Also, this is not really the same as a ball joint. There is far less movement, heat, and pressure occurring with this joint. But obviously enough to create the crazy-making squeak.
  18. Aug 24, 2012 at 5:21 PM
    #158
    Toytruckmike
    Toytruckmike Well-Known Member
    Michael
    Amarillo, Texas
    07 TRD Sport AC 6sp 4x4 Gone:18 TRD Sport 4x4 double cab. Cement
    Not much on the 07 yet. 18 is gone, but was a greata truck. TRD Pro grill, Gator FX3, Homelink mirror, Black out badges & exhaust tip, Remote start. Future TRD exhaust, skid plate.
    Ok. How did you get the grease on the plate? I tried and got grease everywhere but. Can u give more details?
  19. Aug 24, 2012 at 6:13 PM
    #159
    Palooka
    Palooka Well-Known Member
    Brett
    Crescent Valley, BC
    09 TRD Sport
    Mine does, but only when it's hot out.
  20. Aug 25, 2012 at 1:22 PM
    #160
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    I just used the straw tube it comes with and very carefully put it on the white plastic plate that rubs against the clutch. Don't really know how to explain it. I'll take a picture for you and post it.
