Manual Trans: Do All of Our Toyota Clutches Squeak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plannerman99, Jan 24, 2010.
Do All Of Our Clutches Squeak?
  1. I have a manual trans and its squeaks.
    60.5%
  2. I hava manual trans and it has never squeaked.
    27.2%
  3. I have an automatic and I don't have to worry about this.
    12.4%
  1. Aug 26, 2012 at 9:37 AM
    #161
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I think my creak is coming from worn/ cracked plastic bushings. But this is only a theory because I cannot physically see the bushings due to their location. My goal in the near future is to figure out the dimensions of these plastic bushings and machine my own bushings from brass. I think this could eliminate the side to side play in the pedal and hopefully this god-awful squeaking. The hardest part right now is just getting the dimensions because I can't just disassemble my clutch assembly and not have my truck for a week or two.
  2. Aug 26, 2012 at 6:23 PM
    #162
    lovemytoughyota
    lovemytoughyota Member
    jen
    TN
    06 SR5 Back in Black
    3" Suspension lift, blacked out
    Huh... I had a '91 back in the days... No squeak . Have an '06 now... still no squeak . Sounds like I'm lucky.
  3. Aug 27, 2012 at 6:27 AM
    #163
    shemp
    shemp Well-Known Member
    Right, because that is the point where there is rubbing/friction. Lubricate that and there is no more wear or squeak.
    Nothing is twisting. The joint is rubbing along the plan of pedal/piston motion.
    As I mentioned, it isn't spinning.
    It isn't twisting. It is just rubbing.
    The only thing different is that a ball is round and this joint is practically square.
    There is a lot of movement, which is why there is wear and squeak.
  4. Aug 27, 2012 at 6:30 AM
    #164
    shemp
    That's what I thought too for mine. Do yourself a favor and lubricate the point where the master cylinder shaft end cap contacts the back of the pedal lever. If it doesn't work, then you've lost 15 seconds and a tiny drop of grease. If it does work, you've saved yourself from spending hours ripping the pedal out for nothing.
  5. Aug 28, 2012 at 5:25 PM
    #165
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Doesn't work. I've lubed every joint/ pivot inside and outside the cab. The bushings are simply garbage.
  6. Aug 28, 2012 at 5:29 PM
    #166
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    X2 got it with 78000 km on it now have 98000 and it squeaked for the longest time but now it's fine, maybe just give it time replacing it may be the issue
  7. Aug 29, 2012 at 12:59 PM
    #167
    shemp
    It isn't the upper lever pivot, there is no bushing. Half way up the pedal lever, look where the master cylinder points. Lift the pedal, push the pedal down. There is a HOLE in the back of the pedal lever. A big hole. Push grease in there. Lots of grease.
  8. Aug 29, 2012 at 1:04 PM
    #168
    RightCoaster
    RightCoaster Well-Known Member
    Patrick
    Myrtle Beach
    2012 SR5 4CYL 5SPD, 2020 DCSB TRDOR 6SPD, 2023 DCLB SR5
    1300 miles, no squeak...yet I guess
  9. Aug 30, 2012 at 1:10 PM
    #169
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I know exactly what you're talking about. It's called the clevis sub assembly and it fits in the bore in the backside of the pedal arm. The bushings in the top portion of the clevis assembly are shot and it's allowing the clevis assembly to ride against the wall of the bore where it's located. I'm tempted to buy an entire clutch assembly from a junkyard and machine all new components from aluminum/ brass/ stainless/ whatever.
  10. Aug 30, 2012 at 4:32 PM
    #170
    Large
    Large Red
    Don't listen to this guy:cool:
    :stirthepot: :stirthepot: :stirthepot:
  11. Aug 30, 2012 at 11:17 PM
    #171
    Schwinn
    Schwinn Well-Known Member
    Jamie
    Georgina, ON
    2012 TRD Sport with Trail Teams package
    Mine started around 10k km. It's still under warranty, they can fix it.
  12. Sep 2, 2012 at 5:02 PM
    #172
    lodi781
    lodi781 Alexander Supertramp
    shelton CT
    '16 4runner trail
    ARB by-51’s, dobinson springs, Gobi Rack, Black Oak single row LED roof bar
    My throwout bearing went, they fixed it around 35k and no problems with it since and now I have 81k on it. I did have the hydraulic line in the tranny blow which left me stranded and they tried to say that wasn't under the drive train warranty. I said, " does the truck drive without that line functioning?"..." No"........"then it's part of the drive train, fix it." They hemmed amd hawd but they fixed it. Other than that, my truck has been fine.....
  13. Nov 9, 2012 at 7:04 AM
    #173
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I had a 96 Tacoma that squeaked and I replaced the bushing 2x in 5 years.
    Yeah...and Toyota hasn't figured it out yet.
  14. Nov 27, 2012 at 1:50 PM
    #174
    just2wd
    just2wd Well-Known Member
    Dan
    California
    07 PreRunner TRD Off Road
    My chirping sound is alive, when i try to show someone the noise it goes away, and when im all alone with the truck it whines and screams. i can mute it if i press the clutch alittle bit. looking for a throwout bearing to buy but cant decide on which one. any advice?
  15. Nov 27, 2012 at 1:50 PM
    #175
    just2wd
    Dan
    California
    then realized it can be the transmission sleeve!
  16. Nov 27, 2012 at 4:02 PM
    #176
    Foxbat
    Foxbat Member
    Pennsylvania
    06 Tacoma
    Step rails
    Mine squeaks but does not bug me much. With the radio or cd on it is hard to hear anyway. But, now that I read all about this once again it will probably bug me and I will try to quiet it down. If not, more music.
  17. Dec 19, 2012 at 12:31 AM
    #177
    4Bangin
    4Bangin Member
    Alex
    Michigan
    2010 4-cyl 4x4 SR5 5-spd
    There is a recall on it, or so I have heard...
  18. Jan 20, 2013 at 6:33 PM
    #178
    Domreis
    Domreis Well-Known Member
    Pullman
    Not yet, but I only have 5,xxx miles in her.
  19. Jan 21, 2013 at 6:15 AM
    #179
    WThomas1250
    WThomas1250 Well-Known Member
    My first gen squeaks, sometimes its real bad and sometimes its not. It's 15 years old so I just don't care enough to do anything about it
  20. Jan 25, 2013 at 4:09 AM
    #180
    10DC4x4
    10DC4x4 Well-Known Member
    I just took my truck in for the squeak, They said mine was internal transmission failure and had to give me a new one ( Warranty) mine is a 2010 4x4 with 48k miles... so if it squeaks and is under warranty on TAKE it in. Just incase they have a tab any way so shy not get them to fix it. Just my. 02.
