Manual trans guys question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GOTSAND?18, Dec 18, 2019.
  1. Dec 18, 2019 at 1:33 PM
    #41
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    No. It's how I feel about people or machines or whatever doing things for me.
    boynoyce likes this.
  2. Dec 18, 2019 at 1:40 PM
    #42
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The beauty is that we still have a choice in that. I can't even say how happy I am with mine, esp after a couple mods.
    I am certain most AT folks feel the same.
    Junkhead, boynoyce and DWD484[QUOTED] like this.
  3. Dec 18, 2019 at 1:40 PM
    #43
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    ADM won't help with rev hang. It's the ECU that's doing it. It's an emissions thing.
    As far as clunking/crunching/grinding/etc mine's actually been pretty good since new (1400 miles now). I get a slightly notchy feel SOMETIMES on 2nd and 3rd upshifts but that's very rare and I feel like it only happens when my shifts get lazy.
  4. Dec 18, 2019 at 1:42 PM
    #44
    Outbound1
    Outbound1 Well-Known Member
    Noah
    Colorado
    I have had my 2006 for 3 years and has 189K miles currently. It doesn't go into 3rd as smooth as the others. What has worked best for me is taking another half second from 2nd to Neutral to 3rd so the gears line up properly, and it works for my truck perfectly and smoothly. If I shift quickly or carelessly then the gears grind a minor amount. Not a big deal each time but multiply years and years and you'll have a problem. Hope yours sorts itself out
  5. Dec 18, 2019 at 1:48 PM
    #45
    su.b.rat
    su.b.rat broken truck
    no time to read all the replies atm, sorry if repetitive...
    1 - it will continue to break in and get a bit easier
    2 - but you should look into a MT fluid change
    3 - and make it a habit of practicing your aim. not a joke, actually practice aiming correctly for 3rd. I bet if you do that and the fluid you'll be gtg.
  6. Dec 18, 2019 at 1:53 PM
    #46
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    Clutch clicking, which is talked about in another question on here. Also my fifth gear sounds liked your third. It's very hard to go smoothly into it, plus there are whines and whistles in fifth gear, mostly when I let off the gas. I did the UCA hole fix, no idea what it could be.
  7. Dec 18, 2019 at 2:24 PM
    #47
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    My third is actually fine. My tranny been a bit notchy when new, but thats expected. Im quite pleased with it as of now, there are some things i would improve of course tho.
    Whines and whistles in 5th? Sounds like the diff whine, no? Is it at speeds between 60-65?
  8. Nov 2, 2020 at 6:42 PM
    #48
    Desert War Eagle
    Desert War Eagle Member
    Simmons
    2021 Cement Tacoma TRD Off-Road 4WD MT
    I have this same issue on mine (with all of like 50 miles now). Annoying but like others hope it corrects a bit. I am having to learn to shift this differently than my VW GTI, not surprisingly. Surprisingly, on the GTI the shifting got less smooth after 10K miles. I always suspected the dealer, because every time I got it back something was off, but that's a different story.
    What is the ADM?
  9. Nov 2, 2020 at 6:52 PM
    #49
    su.b.rat
    https://www.tacomaworld.com/threads/mt-accumulator-delete-mod-adm-and-bs-thread.568303/
  10. Nov 3, 2020 at 12:04 PM
    #50
    Desert War Eagle
    Simmons
    I was paying a bit closer attention to this today, and in my small sampling size of about 5 miles anyway, I noticed that if I shift from 2nd to 3rd with the RPM at least 3K, there is no grinding. I tend to shift about 2.5K RPM from 2nd to 3rd normally in this truck so far, for gas mileage purposes I suppose. But the higher RPM made a real difference in the smoothness of the shift--no more grinding--so I'll make it a habit of shifting at the higher RPM. (Of course, in my GTI I usually shifted well above 3K :D.) There is no grinding between other gears regardless of the RPM when I shift.
  11. Nov 3, 2020 at 12:22 PM
    #51
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Someone told me that TW is only 2% of Tacoma owners and... blah, blah, denial, blah, blah, mine is perfect.... thus lies damn lies.
    DeeKay20 likes this.
  12. Nov 3, 2020 at 12:46 PM
    #52
    DWD484
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    Look who I found! ocoward... I mean, oconnor... You could have just told me how you felt, but we can get it in here too if you want... Now prove me wrong about what I said... I'll wait.
  13. Nov 3, 2020 at 1:12 PM
    #53
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    OP, mine did the same thing off the lot, especially at low RPM 2-3 shifts. It's gotten better now, but I've also learned to give a special little pause on regular around-town driving for that shift. High RPM and fast rowing such as passing or getting on the highway is butter though.
    Desert War Eagle likes this.
  14. Nov 3, 2020 at 4:57 PM
    #54
    oconnor
    oconnor Where am I?
    Midwest
    Ah name calling, I guess you've already given up.
  15. Nov 3, 2020 at 5:02 PM
    #55
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    7c57a022a3cb9b09d5ea4653397a5170_zpsc510645b.jpg Is the Op still on this forum?
    uurx likes this.
  16. Nov 3, 2020 at 8:41 PM
    #56
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Hopefully you can replicate it on command. When these issues are intermittent, it's a bitch to resolve.
    Start documenting all your issues with the clutch. If something goes wrong, they will look to point to abuse, even if the failure happens way before warranty.
    Make them document when you take it in, even if they fail to replicate, etc
  17. Nov 4, 2020 at 3:10 AM
    #57
    jetspeed
    jetspeed Well-Known Member
    MD
    19 TRD Sport DCSB 4x4 Manual Taco
    1500-2000 miles fer clutch break-in IMHO. Good luck!
  18. Nov 4, 2020 at 5:03 AM
    #58
    DWD484
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    Giving up? You mean like running to a different thread to talk shit about someone behind their back? That kind of giving up? Please explain...
  19. Nov 4, 2020 at 7:13 AM
    #59
    dr4g1116
    Just gonna throw this out there that there is an incredibly useful ignore feature on this forum.
    DWD484 likes this.
  20. Nov 4, 2020 at 7:20 AM
    #60
    DWD484
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    Yep. That's the button that people use when they don't want to hear anything that goes against their logic of thinking, even though their logic is flawed. It keeps them from hearing truths that they're unwilling to accept, and makes them feel safe in their dark corner of ignorance.
