Manual trans issues 2nd gen SR5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JRDTaco2011, Dec 19, 2020.
  1. Dec 19, 2020 at 8:12 AM
    JRDTaco2011
    JRDTaco2011 [OP] Member
    2011 Red Tacoma SR5
    Fenders. Grill. Rainguards. Towing harness. Bed liner. Fuel door.
    Hey!
    2011 SR5 here. Manual trans.
    Let me start by stipulating that I have 218k miles so I know this is a huge factor, but...
    Recently, about a week ago, I started experiencing some very odd trans behavior.
    From dead stop, I take off and 1st gear will get me to about 15mph. Shift to 2nd, fine. 3rd, ok. 4th and 5th gears... no. It will shift into gear, BUT if I depress the accelerator all the way, or even 1/2-3/4, the engine will want to rev over 3-4K rpm. Yet it will still increase in speed. Just extremely slowly. Also I’m not able to feel 4th and 5th gear hit when I shift. I don’t know if my trans is slipping or what. Also, my speedometer is now inaccurate. As I shift between gears, it will continue to rise. By the time I hit 3rd, it’s showing 40-45 mph. About 10mph faster than I’m traveling. I know that’s probably my vehicle speed sensor. But would that have anything to do with my transmission acting weird? They happened at the same time.
    Time for a trans fluid change? Lol
    Thx for any suggestions.
  2. Dec 19, 2020 at 8:39 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like your clutch is slipping, probably time for a new clutch.
  3. Dec 19, 2020 at 8:59 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    100% sounds like what it is.
    BassAckwards and EatSleepTacos like this.
  4. Dec 19, 2020 at 9:01 AM
    JRDTaco2011
    2011 Red Tacoma SR5
    Ok that would make sense. Slipping clutch. Every now and again, it will be difficult to shift into 1st. Like it’s locked up. Quick shift to 2nd then back to first is usually the answer.
    Thanks
  5. Dec 19, 2020 at 9:02 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    As stated, sounds like a slipping clutch.
  6. Dec 19, 2020 at 9:02 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Time for a new clutch and a tranny fluid replacement!
  7. Dec 19, 2020 at 10:24 AM
    JRDTaco2011
    2011 Red Tacoma SR5
    These are the answers I’m looking for. Thank you guys!
    Clutch and fluid = no problem!
    New trans = big problem lol
    I appreciate it
    TodayWasTHeDaY likes this.
  8. Dec 19, 2020 at 10:25 AM
    JRDTaco2011
    2011 Red Tacoma SR5
    If I had the $, I would just spring for a new TRD Pro! Lol
  9. Dec 19, 2020 at 10:28 AM
    Sharpish
    Brian
    Drive it into the ground!
  10. Dec 19, 2020 at 10:39 AM
    JRDTaco2011
    2011 Red Tacoma SR5
    Exactly my intent!!!
    218k miles, no major issues... payments finished long ago. I’ll get another 100k easy!
    Drive it into the ground, yes!
  11. Dec 19, 2020 at 11:37 AM
    TodayWasTHeDaY
    Russ
    Calgary
    It's a Toyota, other than the worn out parts it's just broken in!
  12. Dec 19, 2020 at 11:42 AM
    Sharpish
    Brian
    The problem with driving Toyota’s into the ground is you never get shiny new cars. The fucking things last 25 years.
  13. Dec 19, 2020 at 12:02 PM
    TodayWasTHeDaY
    Russ
    Calgary
    First world Toyota problems :rofl:
  14. Dec 20, 2020 at 2:20 PM
    JRDTaco2011
    2011 Red Tacoma SR5
    My very first vehicle at 16 y/o was an old Toyota pickup. Before they had names haha
    It was factory white and primer grey. 4spd manual trans 4cyl. 2.4L. lol
    I think those old ones got, at most 103HP?
    Rusted through in 3 spots and ran on 14” rims like a champ!
  15. Dec 20, 2020 at 2:22 PM
    JRDTaco2011
    2011 Red Tacoma SR5
    Also... since I’m replacing the clutch, is it recommended to replace the flywheel as well? Or is that necessary?
  16. Dec 20, 2020 at 2:27 PM
    PlatinumCloud
    PlatinumCloud Jameson Drinker
    Sarver
    2015 off-road pkg
    as stated you need a clutch.
    as far as the flywheel, i would have it re-cut for sure, or resurface it. if its just your daily driver good chance its not warped. i would weigh the price. youll need a new throw out bearing as well.
    would also check the teeth where the starter engages...if thats messed up or worn def replace the whole thing. if time is a constraint just do yourself a favor and put the new flywheel in anyway. when your in that deep best to replace anything major. its not the money that is the hassle, its the time and effort in getting to it all!
  17. Dec 20, 2020 at 2:34 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Clutch disc, pressure plate, throw out bearing, pinion bearing, main seals on engine, Tcase and transmission.
    Inspect clutck fork and pivot pin well.
  18. Dec 20, 2020 at 2:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    And ujoint and trans mount inspection / replace if needed.
  19. Dec 20, 2020 at 3:29 PM
    JRDTaco2011
    2011 Red Tacoma SR5
    Will do! Time is of no concern. I’ll just spring for the whole thing and save myself some headaches later on then.
    Thank you all for the replies.
    I can work a mechanical engine up and down but when it comes to transmission, clutch and anything related, I’m lost.
