Manual trans questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by RustyVT, Dec 5, 2015.
  1. Dec 5, 2015 at 12:26 AM
    RustyVT
    RustyVT [OP] Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Hey guys, just curious about how your trucks shift. Because mine has always been sort of picky about the clutch. I've owned 6 manual rigs and this is the first one that I can't figure out what the trans likes for the life of me. I buck this thing more than all of my other cars combined.
    It just seems like no matter how slow or fast I let the clutch out after a shift it always wants to buck. If I'm really thinking about it I can shift it smoothly, or if I shift and stay off the gas for 2 or 3 seconds it's fine too. But it just seems like the trans is never happy with how fast or slow I let the clutch out with how I normally drive. I think this has a lot to do with the fact that it stays at the same RPM as when I was driving for a few seconds after I push the clutch in, it just hangs there. And I get that it isn't a sports car so I'm not gonna be speed shifting it, but I had an 87 f150 that shifted way smoother than this truck. My rav4 shifted kinda shitty though, so I'm wondering if it's just a Toyota thing. Synchros are good because it goes in and out of gears fine, occasionally have minor trouble getting in reverse but every manual car I've had has had that issue. Another thing it does is when I'm doing 40-70 and let off the gas completely, it thuds / clunks when I get back on the gas again, most noticable in 5th gear. It isn't severe but very noticeable. I don't think axle wrap could cause anything that noticable, possible bad carrier bearing or trans mount?
    I just hope it isn't the trans internals. Only thing I know for sure is that the slave cyl desperately needs a flush. But as always any advice or info is appreciated!
  2. Dec 5, 2015 at 1:15 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    How old is your clutch?
  3. Dec 5, 2015 at 1:26 AM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    My shifting improved with synthetic oil. As for the sound, i would definitly check the mount and the bearing. I would also look at the drive shaft joints and check for play. I would flush the fluid in the clutch and make sure it adjusted at the pedal. There is a write up some where on taking up the slack or something. There is also a bushing on the shifter that can go bad causing it to be sloppy at the stick.
    I added a bigger shift knob and a longer stick also made it feel more positive, but it might also have slowed the action down do to a longer throw.
  4. Dec 5, 2015 at 2:34 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Sounds almost like a bad Transmission mount or carrier bearing .
    Maybe even a Engine mount .
    Could be water in the fluid over time from condensation has caused things to rust making the return slower then it should be.
    With the swings in temperature in Vermint
  5. Dec 5, 2015 at 8:11 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    I replaced my clutch line with stainless steel line, brand new clutch, brand new flywheel, brand new slave and master, and a urd short shifter all about 1,000 miles ago..Trans still bucks i think its just a tacoma thing.
  6. Dec 5, 2015 at 8:31 AM
    RustyVT
    Vermont
    It's a 180k original as far as I know, PO may have replaced it but I couldn't tell ya.
  7. Dec 5, 2015 at 8:35 AM
    RustyVT
    Vermont
    No doubt about water in the lines, the fluid is pitch black. You might be onto something with the engine mount, because when it idles down to 6-700 rpm the whole truck shakes. I had a Volvo 240 that did the same and it was an engine mount. I'm sure my carrier is shot too, after I lifted it I heard a constant squeak with every rotation of the driveshaft, sounded like rubber on metal, and it came from the middle of the truck.
  8. Dec 5, 2015 at 8:37 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    My truck does the same thing. You just have to be easy on the clutch. As for the clunking, mine also does that too. It's probably a mount somewhere. Maybe driveline or trans.
  9. Dec 5, 2015 at 8:39 AM
    RustyVT
    Vermont
    I'll definitely check out how to adjust the pedal, plan to flush the fluid today if I can get the bleeder open. I wouldn't be opposed to a longer shifter, I miss my f150s 3 foot throw to be honest, I thought it was fun. My other car has a short shifter and I hate it.
  10. Dec 5, 2015 at 8:41 AM
    RustyVT
    Vermont
    Hmm, guess its just another taco quirk. Never find out about this stuff till you join a forum lol.
    DustStorm4x4[QUOTED] likes this.
  11. Dec 5, 2015 at 8:43 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Maybe a quirk, or maybe we both have actual problems lol :notsure:
  12. Dec 5, 2015 at 8:50 AM
    RustyVT
    Vermont
    Well mines done it for 20k miles and I'm sure it did it when the PO owned it, so can't be too big of an issue haha
  13. Dec 5, 2015 at 1:15 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I don`t have any issues No clunks no bucking .
    I would guess about 40 Thousand on a all new clutch and hydraulics .
    New Transmission mount from 4X Innovations that does cause some vibration at idle but one gets used to it.
