Manual Trans Shift Lever Bushing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fatmonk8, Jun 21, 2018.
  1. Jun 21, 2018 at 5:01 AM
    Fatmonk8
    Fatmonk8 [OP] Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    Does anyone have any experience replacing the bushing for the shift lever in our trucks?
    I need to replace mine from what I read online but I can not find any info on 2nd gens, all i see are videos and part numbers for 1st gens.
  2. Jun 21, 2018 at 5:38 AM
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    Hit up @Coupe he did my shifter, TRD short throw. Was super sloppy,and now nice and firm. He replaces the bushing mid shifter with an poly resin, super good work, and reasonable price!!! Maybe the slightest more noise, but well worth it imo. He also has other options available!!
    Edit: Are you referring to the bushing inside the stick? Or the bushing that the shifter rides in the top of the trans??
  3. Jun 21, 2018 at 6:01 AM
    Fatmonk8
    Paul
    Delco, PA
    Seat bushing and Shift Lever Bushing
  4. Jun 21, 2018 at 6:02 AM
    Fatmonk8
    Paul
    Delco, PA
  5. Jun 21, 2018 at 6:07 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Yeah those will do for the bottom, super easy to replace those. Suposidly marlin crawler makes the best ones. If the bushing inside your stick is toast, hit up the guy I mentioned before!!!
    How to replace those is very similar to all gens, once you get to it, it'll make sense
  6. Jun 21, 2018 at 6:08 AM
    Fatmonk8
    Paul
    Delco, PA
    Thanks!
    abqnurse80 likes this.
  7. Jun 21, 2018 at 6:13 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    No problem!!
    scottalot likes this.
  8. Jun 21, 2018 at 6:20 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
  9. Jun 21, 2018 at 6:23 AM
    Fatmonk8
    Paul
    Delco, PA
    abqnurse80[QUOTED] likes this.
  10. Jun 21, 2018 at 6:23 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
  11. Jun 21, 2018 at 6:26 AM
    Fatmonk8
    Paul
    Delco, PA
    This look more promising. I see the same thing on Amazon and it says it will not fit my truck. weird.
  12. Jun 21, 2018 at 6:27 AM
    Fatmonk8
    Paul
    Delco, PA
  13. Jun 21, 2018 at 6:28 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Yeah, got mine there, just had to dig through email. They work great, still tight.
  14. Jun 21, 2018 at 6:30 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
  15. Jun 21, 2018 at 6:31 AM
    Fatmonk8
    Paul
    Delco, PA
    Well worst case is it does not fit, wont break the bank. I think this will work tho. Thank you for the help!
  16. Jun 21, 2018 at 6:32 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    True, either way, easy to get to if you do have to do it again!
    Fatmonk8[OP] likes this.
  17. Jun 21, 2018 at 6:33 AM
    Fatmonk8
    Paul
    Delco, PA
  18. Jun 21, 2018 at 6:36 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    When you have your shifter out, check the play in the midshifter bushing as well, mine was slippy, and that's why I sent it out to @Coupe you be able to tell if it's bad.
  19. Jun 21, 2018 at 6:39 AM
    Fatmonk8
    Paul
    Delco, PA
    What is the middle shifter located? Iv never pulled one before.
  20. Jun 21, 2018 at 6:40 AM
    Fatmonk8
    Paul
    Delco, PA
    You are probably still good then, I'm at 178k and just now noticing it.
    abqnurse80 and scottalot[QUOTED] like this.
