Manual trans weight (R150F)?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hansolex, Dec 21, 2016.
  1. Dec 21, 2016 at 2:55 PM
    hansolex
    hansolex [OP] Scoundrel
    Kent, WA
    1998 Tacoma 4WD 5VZ-FE 5-sp.
    Quick question that I can't seem to find an answer to: what's the R150F weigh, for the purposes of dropping it out of the truck for a clutch job?
    Chilton manual says to drop it out with the transfer case still mated, but drained of fluid. That all makes sense. Anyone got a ballpark figure for what the transmission, bellhousing, and transfer case combo is going to weigh in this situation?
    Just trying to figure out if I am going to need a trans jack for this job. Looks like a big sucker. Last trans I dropped was the Volvo M40, size of a shoebox, weighed maybe 30 lbs. Never messed with anything this large before.
    Thanks!
  2. Dec 21, 2016 at 3:04 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Not something you want to do without some sort of Jack
    Is this going to be on a lift or on the floor ??
    I have never had a transmission jack that would work just the odd combination of the Trans and Transfer case
    Keep saying I am going to build an adapter but after it is back in I forget
  3. Dec 21, 2016 at 3:07 PM
    hansolex
    Kent, WA
    Well I have a floor jack, but the round plate isn't much support. If it's as heavy as it looks, I don't want to try and balance it on a floor jack. Ideally I'd ratchet-strap it to a cradle, but I don't have one handy. Anyways, knowing how much it's going to weigh will help me figure out what to do.
    I'm definitely not going to try and bench-press it.
  4. Dec 21, 2016 at 3:16 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I put a piece of square tubing across the hole in the floor then put a 1" ratchet strap around that. Holding things.
    The best is 3 people one on each side one to pull the jack back
    Know as it comes out of the splines it will spin toward the front drive shaft output
    I have done it alone never again
  5. Dec 21, 2016 at 4:51 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Did my clutch about 600 miles ago, we didn't drain fluid and dropped the trans with the t case still attached. We were spoiled though, had it on a lift with a trans jack under it. It wouldn't balance right so we ratchet strapped it so it would stay still, it was very tail heavy.
    Just make sure when you're putting the strap over it that you don't pinch any wires or connectors on top of the tranny.
    Also, I'm sure your chilton will tell you this, but we couldn't get the tranny to slide out until we took the dust cover off the front, only 4 bolts holding it on, but they were a PITA.
    Not a super hard job over all though, just time consuming
    hansolex[OP] likes this.
  6. Jan 6, 2017 at 10:31 AM
    hansolex
    Kent, WA
    Appreciate the help. I've decided I'm going to make an adapter for my jack out of plate steel. I'll let you know how it goes ... if it works well I'll post the dimensions and so forth. Y'all have saved me the pain of dropping the thing on the ground (or myself) trying to half-ass it.
