Manual Trans will I fit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SuperDutyDave, Jun 28, 2014.
  1. Jun 28, 2014 at 7:25 PM
    SuperDutyDave
    SuperDutyDave [OP] Active Member
    Dave
    People's Republic of VT
    ToyTec Boss Syspsension 3"
    Hey guys potential newbie here.....always have owned full size trucks but really have admired Tacomas.
    My last truck was a tuned Ram Cummmins 6 Speed and I prefer a manual transmissions. Tacoma has that option though limited availability
    So here's the question I will have to travel a long distance to find a manual trans Tacoma. Prior to making journey I'm wondering if at my size. ( 6'4" 240lbs ) will I be able to comfortably drive the truck???
    Opinions??
    Thanks
    Dave
  2. Jun 28, 2014 at 7:31 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Im 6'1 and have a reg cab, i have to slide the seat up a notch or two to push the clutch to the floor, find an auto for sale in your area and take a test drive just to make sure
  3. Jun 28, 2014 at 7:33 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Sit in an auto trans Tacoma and see what you think. The room should be the same. FWIW I am 6'2" and don't even use the seat all the way back in my AC.
  4. Jun 28, 2014 at 7:52 PM
    ElBlancoTaco
    ElBlancoTaco Well-Known Member
    Ron
    Scottsdale, AZ
    2014 SR5 DCSB 4x4
    Dave,
    Auto or manual, you should fit fine but there is one review of "worst/best" that I read that said the Tacoma was a worst for tall people.
    I'm 6'3" and 275 and I'm very comfortable IN my 2014 DCSB. My seat is all the way back, though. I'd like to go back another click. Getting in does require a flex of the neck that can be a pain when my C5 disk is giving me trouble. Once inside headroom is terrific.
  5. Jun 28, 2014 at 8:16 PM
    Fiddy
    Fiddy Well-Known Member
    Justin
    Phoenix
    stock
    as long as its access cab or dbl cab i see no problem fitting you in there comfortably
    im 6' and i can move my seat back a good amount in my access cab
  6. Jun 29, 2014 at 4:17 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    At 6'3" and 225 lbs, I am very comfortable in my reg cab w/auto with headroom to spare.
  7. Jun 29, 2014 at 4:26 AM
    SuperDutyDave
    Dave
    Thanks guys....I'm planning on a double cab. Sure headroom will be ok but more worried about sufficent space to stretch legs and shift easily hate being cramped up in order to drive. Particular if wearing boots.
    Had a Jeep wrangler unlimited and even though I could shift it was too narrow and the seat didn't go back far enough for comfort. I could operate but not comfortably Conversely my Ram had tons of space
  8. Jun 29, 2014 at 4:43 AM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    I'm 6'4" 240lbs and I found it fun to drive the manual.
    Although it doesn't have the leg room my Camry has it still was comfortable.
  9. Jun 29, 2014 at 7:21 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Yes you will be able to comfortably drive the vehicle but getting in and out will be a pain. I am not as tall as you and getting in and out of these things without banging your head on the upper door panel is a chore. Stiff neck or bad back forget it.
