Manual transmission and or clutch trouble
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slr4x4, Dec 26, 2019.
  1. Dec 26, 2019 at 3:37 PM
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    Nope. From what I see, that's everything you'd need--parts wise--to do it yourself or to have a shop do it.
    BassAckwards and Slr4x4[OP] like this.
  2. Dec 26, 2019 at 3:40 PM
    TuRDLYFE
    2020 AG TRD Pro 6MT
    Don't forget to pull the drums, check the shoes, and tighten the parking brake if the shoes aren't too worn!
  3. Dec 26, 2019 at 4:40 PM
    Slr4x4
    Slr4x4 [OP] Member
    2008 Tacoma
    I just had shoes replaced and that's when i had no e brake.
  4. Dec 26, 2019 at 4:44 PM
    TuRDLYFE
    2020 AG TRD Pro 6MT
    Sounds like they weren't properly adjusted.
    whatstcp and Slr4x4[OP] like this.
  5. Dec 26, 2019 at 4:55 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I would highly recommend a Koyo/OEM throw out bearing. The ones that come in those clutch kits are not as good of quality
    Part# 31230-35071
  6. Dec 26, 2019 at 5:59 PM
    furiousbob
    furiousbob Well-Known Member
    Ron
    Another way to tell if your clutch is going out. From a stand still, stick it in 3rd gear and slowly let off the clutch. If it stalls, clutch is good. If it doesn't, clutch is shot.
  7. Dec 26, 2019 at 6:05 PM
    Slr4x4
    Slr4x4 [OP] Member
    2008 Tacoma
    Yes, the guy that did the brake shoes said my e brake cables were shot. Idk if that's true or not.
  8. Dec 27, 2019 at 7:45 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Just did clutch disc, pressure plate, throw out bearing, and fork.
    180k for me.
    Oem bearing and aisin on the rest mine was aisin stock.
    We also replaced the rear main seal while we were there.
    If you grab your brake cables where they go thru the backing plate they shouldn’t pull away from the plate.
    Slr4x4[OP] likes this.
  9. Dec 27, 2019 at 8:26 AM
    Slr4x4
    Slr4x4 [OP] Member
    2008 Tacoma
    Did you change transmission fluid? Used all aisin parts? Just want it done right.
  10. Dec 27, 2019 at 8:41 AM
    furiousbob
    Ron
    How difficult is it to do a clutch job? I imagine it's just like any other RWD/4WD truck/car?
  11. Dec 27, 2019 at 8:43 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Can’t say right or wrong.
    I changed fluid also.
    There are so fn many clutch kits etc.
    I figured stock went the 180k and wasn’t slipping.
    Some say luk isn’t any good others say all oem sucks.
    I could see markings /design of the pressure plate thru the inspection window and could tell it was aisin so that’s what I got.
    But yes I went back oem.
    The rear main I used fel-pro.
    I had my flywheel resurfaced.
    Our trucks came with either luk or aisin clutch’s.
  12. Dec 27, 2019 at 8:43 AM
    BassAckwards
  13. Dec 27, 2019 at 8:51 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    It wasn’t bad.
    I was gonna do it on my garage floor with floor jacks.
    Lack of help and ambition,
    I did it at at local shop where I’m allowed to help.
    The lift and proper tools made it pretty easy actually.
    It has also had a recent frame replacement so all the mounts weren’t rusted up.
  14. Dec 27, 2019 at 10:41 AM
    Slr4x4
    Slr4x4 [OP] Member
    2008 Tacoma
    So i tried both tests suggested and it seems maybe not the clutch? Would it be the transmission then? Truck is still slipping especially going uphill or accelerating.
  15. Dec 27, 2019 at 10:57 AM
    #35
    TuRDLYFE
    2020 AG TRD Pro 6MT
    The biggest thing you say is it slips going uphill in particular. That's an obvious sign of a bad clutch. If you're that concerned, bring it to a transmission shop or a mechanic and ask for a courtesy diagnosis. A Toyota dealer would likely do a free diagnosis and let you know what the issue is.
    Slr4x4[QUOTED][OP] likes this.
  16. Dec 27, 2019 at 11:06 AM
    #36
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Are you losing any oil between oil changes?
    Wouldn’t hurt to pull the inspection cover and look for either oil or clutch disc dust.
    No expert but I don’t think it would be the trans.
    A older mechanic suggested that at speed and in high gear and coasting push in the clutch then dump it.
    Does it lock right back in or seem to ease back in.
    May want to look for the smoke in the rear at this time also.
  17. Dec 27, 2019 at 11:08 AM
    #37
    TuRDLYFE
    2020 AG TRD Pro 6MT
    Jeff brings up a good point that the rear main could be leaking and if that oil gets on the friction surface, it could cause smoke and slippage. Either way, the clutch would need to be replaced but with the addition of a rear main or galley plug depending on where the leak stemmed from.
  18. Dec 27, 2019 at 12:24 PM
    #38
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Manual transmissions don't/can't slip internally. It's the clutch if there's slippage under load- engine RPMs increasing, but no increase in vehicle speed. And burning clutch is nasty smelling as noted.
    I put the Aisin clutch kit from Rock Auto in my 2.7L- very nice, no issues, came with everything you need.
    no Ebrake- maybe the cables are rusted, or the adjuster behind the drum needs manual adjusting. That will be easy to diagnose when you pull the drums
  19. Dec 27, 2019 at 12:49 PM
    #39
    Slr4x4
    Slr4x4 [OP] Member
    2008 Tacoma
    Ok great! Thanks everyone. And it is losing some oil between changes.
