Manual transmission - bearing whining noise??!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, Aug 13, 2017.
  1. Aug 13, 2017 at 10:32 PM
    vijay
    vijay [OP] Well-Known Member
    I hear a light (very faint) whining noise from the transmission at 40MPH(My truck reads 44.5K miles as it sits). It was fine until 40K miles and it started this noise recently. I went to inspect the oil level and found out that Toyota in their infinite wisdom decided to not put a dip stick. Anyway, the oil level seems fine. I changed transmission to synthetic oil (Redline MT 90) at around 35K miles.
    My truck: 44.5K miles, 6 Speed manual, 6 cylinder.
    Any thoughts?
  2. Aug 14, 2017 at 12:39 PM
    wicycletester
    wicycletester Well-Known Member
    se wisconsin
    several
    Does it make the same noise in several gears at 40mph or just one gear? Any change in sound if switch to 4wd?
    My 6 speed is noisy in 6th. Never noticed until I put in the core shifter. Put the stock rubber shifter back in can still faintly hear it. Pretty sure it was always there but now that I've identified it I can always hear it.
  3. Aug 14, 2017 at 3:28 PM
    crdnlplt
    crdnlplt Well-Known Member
    SE PA
    17 dcsb trd or
    Does having the clutch in make a difference? My throw out bearing was replaced under warranty about that many miles.
  4. Aug 14, 2017 at 3:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    Very few manual transmissions ever had a dipstick. I can't even think of any off the top of my head.
    I've had/seen a couple of manual transaxle vehicles with a dipstick, but even that's been a while. Maybe they still exist?
    The only way to check your fluid level is very similar to checking the diffs. Have it level F/R and L/R, then pull the fill plug. If fluid trickles out just a bit, or you can touch it with your little finger it's full.
  5. Aug 14, 2017 at 4:52 PM
    vijay
    I would say 6th gear, mostly.
  6. Aug 15, 2017 at 4:58 AM
    wicycletester
    se wisconsin
    several
    Well you have already changed the fluid and put in the good stuff (MT90) so I would say monitor for awhile and make sure you don't tow anything in 6th. If its a higher frequently wine then likely a bearing slowly getting worn. If a fast tick-tick-tick then likely a chipped tooth and will progress quickly and need attention.
  7. Aug 15, 2017 at 5:03 AM
    wicycletester
    se wisconsin
    several
    By the way, 40 mph is too low for 6th unless you're slowing down. I usually don't shift to 6th untill at least 50 mph. Lugging can be hard on clutches and transmission
