Manual Transmission Clunk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacobot14, Sep 12, 2022.
  1. Sep 12, 2022 at 11:12 AM
    Tacobot14
    Tacobot14 [OP] Heep Recovery Vehicle
    Ty
    North Carolina
    2015 TRD OR White Tacoma 6MT
    OME BP-51, JBA UCA, SOS Streamline Bumper, SOS Sliders, Toyo AT2 tires, many more.
    Howdy, tried googling this all sorts of ways but couldn't find anything that was similar to my question. Some backstory: for the last 6-7 years, I've had a 2006 Auto Tacoma. No shifting issues or noise. I recently sold that truck and purchased a 2015 Manual Tacoma. No shifting issues other than I'm a little new to manual. Had motorcycles and some basic experience, but never owned a manual vehicle till 2~ months ago.
    So here's the question, I'm getting a bit of a clunk when I start and stop in 1st. It could be happening in other gears but I normally hear it when I'm in a drive through line since my window is down. It sounds just like the noise the shifter makes if I go to neutral and wiggle back and forth. But it's only one clunk. I'm not sure if maybe this is just the shifter/trans making noise from getting loaded up then deloaded as I stop? Not sure. It also could be normal and I'm just worried about nothing. Could also maybe be my driving habits since I'm new to MT?
    TIA
    Edit: 2015 has 130k and clutch seems to be fine. I don't notice any slippage or anything like that. Truck was hardly offroaded, she's a pavement princess.
  2. Mar 23, 2023 at 2:43 PM
    J'sTacoma
    J'sTacoma New Member
    Jay
    2015 Tacoma sport 4x4
    3x2 Ready lift Bilstein suspension
    Sounds like its drive shaft u-joints. This is usually the first indications of these starting to go.
  3. Mar 24, 2023 at 8:25 AM
    Taco'09
    Taco'09 Well-Known Member
    Possibly loading/unloading of the spline shaft on the rear DS where the rubber bellows boot lives. A number of truck makes have experienced this and a problem with Fords required mixing PTFE and moly greases to lube the splined part. I borrowed that fix and applied it to my '14 6-speed. I would also inspect all the ujoints as suggest above, and the carrier bearing/including its mount.
