Manual transmission clutch pedal too low?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Edslittleworld, Sep 18, 2022.
  1. Sep 18, 2022 at 10:03 AM
    Edslittleworld
    Edslittleworld [OP] Well-Known Member
    Tucson
    2011 Tacoma TRD/OR (6MT)
    None
    I came from a Jeep Wranger with a manual transmission and now I find my Tacoma's clutch pedal to be too low. My left heel bottoms out on the floorboard when I push the clutch pedal in. So, I have to either stretch my foot forward at the ankle or I won't get full pedal travel. My shoe size is only a 9.5M and I don't have this issue on my Miata. Anyone else have this issue?
  2. Sep 18, 2022 at 10:05 AM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Every vehicle is different. I test drove manual Tacoma’s and no matter how hard I tried, just couldn’t get behind it.
    You will get used to it. Or hate it so much that you sell the truck.
  3. Sep 18, 2022 at 10:08 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    You can adjust the clutch pedal height by screwing out the master cylinder rod end.
    whatstcp and Edslittleworld[OP] like this.
  4. Sep 18, 2022 at 10:13 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I noticed the same. Definitely puts my foot at an awkward angle but I got used to it and it doesn’t bother me now. I have had a YJ, a manual Ranger, and a manual Frontier. They’re all different and I’ve driven many other different setups as well. Tacoma is not my favorite but it works.
  5. Sep 19, 2022 at 5:58 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Why are you guys buying Tacos with MT if you gonna bitch about it. Buy something else just saying.
    whatstcp, Borracho Loco and hiPSI like this.
  6. Sep 19, 2022 at 6:17 AM
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    I find that I don't need to push the clutch peddle very far and then the clutch engages. The only time I every push the peddle all the way to the floor is to engage 4 Lo. I always start in neutral and use the clutch cancel button.
  7. Sep 19, 2022 at 7:13 AM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    I used the ball of my foot and calf muscles to push the clutch down, so my heel is not parallel to the pedal meaning I don't have that issue. I DO have that issue if I wear thick boots, where there isn't much much flex in the sole. My clutch bite point is pretty high up, so I don't even need to push the pedal down that far.
  8. Sep 19, 2022 at 12:06 PM
    Briavael
    Briavael Well-Known Member
    Som
    Albany, NY
    2022 Wind Chill Pearl TRD Sport ACMT / RIP – '16 DCMT
    Toyota truck clutches have been remarkably similar for me over the generations I've owned or driven from the 3rd gen Tacomas, my old '95 4Runner and the 4th or 5th gen old Toyota pickup I first learned standard with.
    You'll get used to it as long as you don't compare it to other vehicles. My technique on the truck is to use a higher leverage point using my thigh when clutching in, rather than bearing down using my knee like I do when driving my STI or wife's Mazda3.
    Then again the STI demands way more precision for a smooth shift than anything else I've ever driven, so I would probably tell you my wife's car is the simplest to row...
  9. Sep 19, 2022 at 12:16 PM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    This. Or you can change the pedals.. you can get aftermarket pedals at any auto store near you. I mean they have long pedal. Something like that.
    Edslittleworld[OP] likes this.
  10. Sep 19, 2022 at 12:35 PM
    Key-Rei
    Key
    Florida
    I did the FJ cruiser steel pedal mod.
  11. Sep 19, 2022 at 2:40 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I have size 11.5 shoes and I don’t have this problem except occasionally when I misplace my foot on the pedal. I think you will adjust and be fine.
    I owned a Subaru in the past and the carpet floor liner would sometimes slide forward and get in the way the of the clutch pedal. It was slightly annoying.
    Briavael likes this.
  12. Sep 24, 2022 at 3:41 AM
    Edslittleworld
    Tucson
    None
    Interesting! Will investigate.
