Manual transmission failure?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BroDameron, Mar 6, 2020.
  1. Mar 7, 2020 at 2:34 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    a- how many total orig miles on vehicle
    b-what parts were replaced
    one could frag a trans ..... that would NOT result in a slipping clutch
    no less listening for gear whine does Not indicate clutch issues
    main components are
    1- clutch plate itself
    2- pressure plate
    NOT worn/ warped / contaminated
    3- flywheel ...............
    NOT contaminated
    NOT distorted / warped
    NOT Worn
    Always helps to use OEM parts as sometimes aftermarkets are just c l o s e ???????
    even if the slave cylinder is weak that actually raises its ugly head on disengaging
    seldom does that become an issue on engagement
    this may be the 3rd attempt on a the clutch
    no less previously bad clutch use can foul the major components..............may not have been YOU
    maybe the prev owners
    new pressure plate
    new throw out bearing
    new clutch plate
  2. Mar 7, 2020 at 9:08 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Be nice to clear this up as a shop has actually told PO it was possibly done....what? Tens of thousands of miles ago? and worked when he bought it?
    So Slander, when it's on backwards, what tipped you off to turn it around?
  3. Mar 7, 2020 at 9:13 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    The notice stamped on the clutch disc which way to oremient it and the warnings in the FSM. I have also read online you can put it in the wrong way. Again I have never installed it backwards, I have read multiple warnings that you can and heeded those warnings. The only thing that can slip in a manual trans is the clutch, flywheel or pressure plate.
    And check the clutch pedal. I burnt a clutch up on a ford f550 because the clutch pedal didnt come all the way up and the clutch would stay half engaged. You had to lift the pedal up with your foot the last few inches. I forgot to on a shift and drove it on the highway for a while, when we got off it slipped bad!! We drove it back home 6hrs feathering the throttle because if you hit the gas too hard the trans would slip.
    GQ7227 likes this.
  4. Mar 7, 2020 at 9:19 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I'm going with 'won't work'. I've done it on others. If it worked even slightly, they would've designed it not to bolt together all the way. that's how everyone else does it.
  5. Mar 7, 2020 at 9:27 AM
    slander
    Hickory, NC
    Hamer95USA and cruiserguy like this.
  6. Mar 7, 2020 at 9:39 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    man. First one Ive ever seen that would work at all. That's a foul up on Toyota to not only make it work, but make it CORRECT to be backward, (raised portion towards flywheel). Strange. I even did mine about 100K miles ago and don't remember it being backwards.
    cruiserguy and slander[QUOTED] like this.
  7. Mar 7, 2020 at 8:16 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I would be surprised your trans has gone in just 160,000 miles. Also sounds strange that "per you mechanic" your clutch was installed backwards? I would take it to a mechanic that you are sure is qualified and have it checked out.
    I would also advise to use a "new" clutch as opposed to a relined/re-man one.
  8. Mar 8, 2020 at 10:32 AM
    BroDameron
    BroDameron [OP] Well-Known Member
    '98 3.4L 4WD 5MT Extracab
    Yeah I thought about the pedal being not adjusted since it had a bad squeak when I bought it, when depressing or releasing it. Seems to be correct? I can't force it higher and the clutch engagement starts a few inches down and is fully engaged a couple inches from fully depressed
  9. Apr 22, 2020 at 11:45 AM
    BroDameron
    So just as an update, it does sound as if the pilot or input shaft bearing (not sure of the name) is making a bit of noise. I can hear the difference when in neutral pushing the clutch in, but its barely noticeable. I haven't had any slipping or weird transmission issues since the clutch was replaced under warranty. Although now I seem to be leaking oil... but my oil level isn't going down and it doesn't look contaminated. My truck has been non stop problem chasing...
    cruiserguy likes this.
  10. Apr 22, 2020 at 5:30 PM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    Yeah I feel for you OP. If at all possible I encourage you to learn more about the required maintenance and performing as much yourself as absolutely possible. There is nothing better than the peace of mind knowing a job is done right because you did it. This has so many benefits especially when considering being off-road / away from other people to fix your truck. I think these are the reasons so many folks on here do their own work, that and saving a ton of coin.
    Can you get around underneath and follow the oil to see where it might leaking? A small oil or fluid leak can look a lot worse due to splatter patterns and stuff. If it's really bad, take it and pressure wash it underneath careful to not full blast important items like CV boots, electrical connections etc. Then drive it around and see if you can find the source. Even if you have to have someone else do the work, being able to have more info going in is always a plus.
    Sending you good vibes on getting it sorted ~=
  11. Apr 23, 2020 at 7:00 PM
    BroDameron
    Most of the maintenance I can do myself. But dropping a transmission is a bit above my pay grade and I don't have a garage I can use for multiple days. I'm pretty sure its the same valve cover leak, but its been getting worse. That or now that I'm in warmer weather the oil and crud from living in the mountains is melting off. I have plans to wash it soon and go from there. Just a pain since this would be the third $1000+ job on this truck and I've only had it a year. Had a drive shaft fail, two clutches have burnt out on me, and now the water pump and probably transmission are having issues. I'm just going to clean it up and get it inspected, find out whats all wrong and then decide from there if its worth saving. Its a bummer that I've dumped this much money into it, each time seeming like I've caught up and should just need regular maintenance, and then another big issue pops up.
  12. Apr 23, 2020 at 8:05 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Well, it is 22 yrs. old..mine makes the low whine with clutch out too. It's kind of normal.
  13. Apr 24, 2020 at 5:27 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    That is the way it goes at times I think we all have a $$$ point and say that is enough.
    I have been lucky in that respect a friend had a 4Runner spent lots of money an easy $5000.00 in just parts I helped with lots of the labor.
    For some reason clutch hydraulics got over looked the rubber hose failed that was his last straw .
    Dumped the 4Runner for the $1000.00 in tires and wheels.
    Someone Got a nice 4Runner for the cost of Clutch Hydraulics and the $1000.00
  14. Apr 24, 2020 at 5:48 AM
    Running Board Man
    Running Board Man Well-Known Member
    It stopped being named the hilux in 85 when the solid axle was dropped North America got ifs and the "pickup"
  15. Apr 24, 2020 at 5:53 AM
    #35
    Running Board Man
    Like everyone else my money is on the trans being fine and the clutch being worn again
  16. Apr 24, 2020 at 7:03 AM
    #36
    BroDameron
    Possible, but I literally have less than 1000 miles on it at this point. And I'm not feeling clutch slip or anything like that, but noticing new noises coming from near the transmission. I'll probably drain some more fluid and check it out when I get the chance.
  17. Jun 26, 2020 at 8:47 PM
    #37
    BroDameron
    Well I don't feel like starting a new thread, and IDK if anyone is still interested, but today (6k miles after the clutch was replaced again under warranty) the same slipping symptoms were felt. Right at about 2500-3000rpm in 4th gear I gave it some gas and it revved up without any increase in speed. I have started to hear a ticking as well. (usually at all RPMs besides 2200-2800ish for whatever reason) Could a cracked flex plate be causing this?
  18. Jun 26, 2020 at 9:13 PM
    #38
    cruxofthebisquit
    Orange Texas
    2000 TRD
    flex plates are on automatic transmission vehicles.
    who adjusted the clutch pedal free play if done?
    I changed a clutch once and it had a slight slip once in a while 'til free play was set correctly.
  19. Jun 26, 2020 at 9:38 PM
    #39
    BroDameron
    I meant flywheel :rolleyes:
    The shop said they did. Might swing by my local guy here and see if he can confirm is correct. Just seems weird that it would be the free play if it only starts slipping after 6k of driving. also it hasn't even been as loaded up, and I'm not in elevation anymore so the truck has had it easier lately.
  20. Jun 26, 2020 at 9:55 PM
    #40
    gtrotter07
    gtrotter07 Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    Has the pressure plate been replaced as well? I had to put a clutch in my 87 Toyota at 190,000 miles. It was original, as well as the pressure plate, etc. Clutch still had plenty left in it, but pressure plate was allowing it to slip.
