Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Jul 23, 2016 at 3:49 AM
    #2241
    ToyOdie
    ToyOdie Well-Known Member
    Dennis
    MD
    None yet
    ok, I figured if anyone had one it would be on this forum, but looks like it was not meant to be.
  2. Jul 23, 2016 at 7:26 AM
    #2242
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    What about rev match and dropping into second from third to chirp the tires ???:burnrubber:
    nevadabugle[OP] likes this.
  3. Jul 23, 2016 at 7:34 AM
    #2243
    stealthmode
    Alberta
    Is it me or is the truck a complete slug off the line or a monster.... lol. I can't seem to find an in between way of driving it-that is unless i dont mind the rev overhang.
  4. Jul 23, 2016 at 9:41 PM
    #2244
    e3slim
    e3slim New Member
    NC
    04 Tundra SR5 4x4 5MT
  5. Jul 23, 2016 at 10:03 PM
    #2245
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
  6. Jul 23, 2016 at 10:06 PM
    #2246
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
  7. Jul 23, 2016 at 10:09 PM
    #2247
    tomz3rdtoy
    tomz3rdtoy Well-Known Member
    Tucson
    '16 White DBL Cab ORSB 6MT
    Icon f/r, add-a-leaf, SR8 w/285/75-16 BFG KO2
    More likely a misrepresentation of the truth...data entry error. I'm not buying it...
  8. Jul 23, 2016 at 10:10 PM
    #2248
    nevadabugle
    Elko, NV
    I'm not sure what I am looking at... everything I have read and researched has said these trucks do not exist. I would have bought this if they did.
  9. Jul 23, 2016 at 10:11 PM
    #2249
    nevadabugle
    Elko, NV
    That is what I thought as well but the photos shows a stick shift.
  10. Jul 23, 2016 at 10:12 PM
    #2250
    RedBeard1
    Red
    Pretty sure they are flukes... Left over parts on the end of a manual production run. Posted the vin for the truck for future naysayers.
  11. Jul 23, 2016 at 10:13 PM
    #2251
    RedBeard1
    Red
    Some one run the vin and see if it is real.
  12. Jul 23, 2016 at 10:14 PM
    #2252
    tomz3rdtoy
    Tucson
    What was the 9th digit in the VIN again?
    Mine is a "0" ...this one has a "6"
  13. Jul 23, 2016 at 10:15 PM
    #2253
    RedBeard1
    Red
    6
  14. Jul 23, 2016 at 10:17 PM
    #2254
    tomz3rdtoy
    Tucson
    Sorry, meant what does it indicate...☺️
    9th digit is a check code...VIN doesn't indicate which trans it has, much to my surprise. So much for that idea
  15. Jul 24, 2016 at 1:38 AM
    #2255
    chightower
    chightower Active Member
    Bryan
    07 PreRunner, Cab and 1/2, TRD, 6 Speed manual transmission, 2WD, V6, 65k miles, sick AF.
    Not much yet, but do have Flowmaster exhaust, with Rockford Fosgate P600.1Bd 600 RMS Mono amp for my 12" P3 with custom box and a Punch P400-4 Four Channel amp for my mids and highs running 100 watts per channel and have two speakers on each channel, not to mention 6 more hooked to the 4 channels from the headunit as well....Hopefully soon will be a body lift with new tires, and eventually the actual suspension...
    Hey everyone, I don't really know where to post the questions that I have but since I have a 6 speed MT 2007 PreRunner Access Cab and I'm in the bs'n mood, I figured this would be a good place to start and maybe you guys would have some other threads in mind I could check out....So basically, I have a bunch of questions, but I'll start with what I am actually in the process of right now. I just purchased 8 ft of 1/0 gauge OFC wire with Tinned lugs, some shrink wrap, techflex, terminals, and some extra nuts and bolts to do the big 3, 4, or 5 or whatever it is on our trucks lol. I keep hearing different things and I'm not the greatest with all of this, but I'm a super quick learner and so far I've done everything myself and have figured everything out...So I took a look today, and until I start getting my hands in there, I probably won't figure this one out either, but I would rather go in knowing what I'm doing so I don't mess anything up...So here goes....I know I need to do the small ground wire from the battery to the frame, ok that's easy, got that....Then I also need one from that same negative battery post to the engine block...Ok, is that the black 4 awg wire with a gry stripe that runs all the way down looks like it's under the engine...maybe a 4 ft length of wire? Should I remove that wire or should I leave it when I put the new one in? I guess with all of em, actually? Ok, next is the positive power wire from the Alternator to the positive post of the battery...So that's the bigger (looks 2 awg? maybe) black wire with red line right? It has the gry top connector thing on the alt right next to the clip-like connector...do I do anything with that grn clip like connector or just leave it? Also, on that positive wire, I'll add an ANL in line fuse of 100Amps...But there is also a small like 10 awg wire running from the positive post into the fuse block...do I need to do anything with that? Or should I replace that one too? Then I'm going to add a ground wire from the alternator, that big bolt that you can see the most when you're looking down at the alternator, the one right to the left of the power wire we just put in...But i've also heard that I'm supposed to run another positive power line from the battery to the starter and also a ground to the starter to the battery too? Is this true? Or do people just do that because that harness that all the other wires are connected to also includes the starter so inorder to remove that whole harness the starter wires need to be replaced too?
    So I'm sorry for all the questions, but do you guys know of a step by step guide or anything or does it sound like I'm on the right track? It's like all the info I've found are all a little different and some people just have different opinions lol....Thanks everyone and appreciate in advance all the help! !
  16. Jul 24, 2016 at 3:51 AM
    #2256
    nevadabugle
    Elko, NV
    I'm not sure from your post what you are trying to do? I think you are installing an auxiliary fuse block? If so, type that term into the search in the upper right. Tons of info on this site regarding that.
  17. Jul 24, 2016 at 5:52 AM
    #2257
    schmack b
    schmack b Well-Known Member
    Clarksdale, Mississippi
    2016 DCSB TRD OR M/T
  18. Jul 24, 2016 at 6:18 AM
    #2258
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Just bought a new shifter knob,AJT Designs,5spd logo,stainless bolts,black. More horsepower I'm sure
  19. Jul 24, 2016 at 6:42 AM
    #2259
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
  20. Jul 24, 2016 at 12:17 PM
    #2260
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    my little 5 speed
    Plain Jane Taco likes this.
