Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Oct 10, 2016 at 11:39 AM
    #2641
    csmacomber
    csmacomber Well-Known Member
    Arizona
    2017 Inferno DCSB OR MT 4x4
    I figure if I'm ever towing or starting on a hill I will use 1. 2 is good enough for my normal driving however. Also, I had to put a deposit down to get one in (refundable) so I could test drive it. I never found one at a dealership when I was looking.
    I did drive several automatics when shopping, and I hated the transmission on them. Very happy with the manual though.
  2. Oct 10, 2016 at 12:20 PM
    #2642
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    How are you starting in second? I have to be rolling or on a downward slope to start in second.
  3. Oct 10, 2016 at 12:48 PM
    #2643
    BallsDeep09
    BallsDeep09 Well-Known Member
    '16 DCSB TRDOR 6 spd.
    It's possible to start in second, I've done a few times. You have to slip the clutch a bit to make it happen though. I would think you would wear out your clutch faster starting in second all the time.
  4. Oct 10, 2016 at 1:37 PM
    #2644
    csmacomber
    Arizona
    Starting in 2nd on my truck feels like starting in first on the car I owned previously (never had to replace a clutch in 22 years of driving a manual, and all of the vehicles were 100k + miles, 2 of them over 300k miles). It actually feels just about right in most cases where I drive. If there is any uphill, I use first, but a lot of the time I am starting in 2nd without any change to how I release the clutch.
  5. Oct 10, 2016 at 1:51 PM
    #2645
    rockguitar316
    rockguitar316 Well-Known Member
    Adam
    Dayton Ohio Area
    Now: 2016 WRX stage 2 377hp/350tq. Then: 2016 TRD Sport DCSB 6MT (don't kick me!)
    Start in 2nd just give it more gas.
  6. Oct 10, 2016 at 1:59 PM
    #2646
    eon_blue
    Azusa, CA
    Starting in 2nd gear is hard on the clutch, I wouldn't do it unless you have to.
  7. Oct 10, 2016 at 2:58 PM
    #2647
    nevadabugle
    Elko, NV
    The amount I have to slip the clutch just feels wrong. Again, on rolling starts or downhill starts no problem but flat just feels bad to me.
  8. Oct 10, 2016 at 3:24 PM
    #2648
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Sometimes I can't for the life of me get going in second without a lot of slipping, and sometimes I'll get going from a stop and realize I was in second or even third and it worked perfectly...
  9. Oct 10, 2016 at 3:48 PM
    #2649
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Mixed drive through 3 towns.
  10. Oct 10, 2016 at 3:59 PM
    #2650
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I fondly remember the old days of the 4 speed granny gear transmission. You could start in 2nd gear without a load with no extra clutch slipping. It was really a 3 speed transmission with a low gear like low range.
    MitchK and nevadabugle[OP] like this.
  11. Oct 10, 2016 at 4:46 PM
    #2651
    Trips222
    Trips222 Well-Known Member
    Tim
    Baltimore MD
    '16 DCSB OR MT
    3 Kid Seats
    An easy way I used to see what stock was where, was to use online apps like cars.com with search terms. It helped to find where some of these trucks were instead of searching their dealer websites or calling.
  12. Oct 10, 2016 at 5:24 PM
    #2652
    bbrown
    bbrown Well-Known Member
    Buster
    Geauga County Ohio
    '17 Super White TRD-OR DCSB 6-SPD
    255/85R16 ST MAXX
    Picked up my '17 Off Road two weeks ago - loving it! Manual was the only option - so I had to order it. Manual for life or until I can no longer shift. Mileage isn't bad. 20 mpg mixed and 22-24 on country roads.
    JonWon and su.b.rat like this.
  13. Oct 10, 2016 at 5:33 PM
    #2653
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Yes please, I'll take a FJ60 with an H42 any day...
    nevadabugle[OP] likes this.
  14. Oct 10, 2016 at 6:15 PM
    #2654
    BeerGuy
    BeerGuy Active Member
    Los Angeles
    '16 TRD OR DCSB Manual 4WD
    I have a '16 TRD OR 4x4 and I feel like I am some issues with my drivetrain. I was hoping that someone here can shed some light for me. I scanned this thread and I couldn't find anybody with this specific problem.
    I would describe the feel as there being some type of slack in the drivetrain (tranny, transfer case, or diff). When I go from no throttle to easing on the throttle (any gear) I feel a slight delay and then clunk before the wheels get the power. Like there was "slack" in the gears.
    Also, when I go real slow in 1st, like driving over a speed bump, I get a shudder that feels like the wheels are bouncing on and off of the "slack" in the gears. If that makes sense.
    I have driven manual cars my whole life and I have never experienced such a loose and clunky feeling vehicle. My last vehicle was a '09 Tacoma 5 speed (2wd). It was much smoother.
    I will add....this is my first 4wd. Could the loose "slacky" feeling be a normal thing with a 4wd (having a transfer case)? If so, that's fine. I would just like to know if it is normal.
    I am asking because I am trying to decide how to approach toyota about the problem, and how to accurately describe the problem.
    Any insight and advice is greatly appreciated. Cheers! :cheers:
    offthewallsurfer likes this.
  15. Oct 10, 2016 at 6:42 PM
    #2655
    cosmicfires
    David
    Everett, WA
    I've never driven a 4x4 that felt "loose and clunky" as you describe. The 4x4 drive train won't do that. My 2009 regular cab 5 speed feels tight under the conditions you describe.
  16. Oct 10, 2016 at 7:09 PM
    #2656
    nevadabugle
    Elko, NV
    Mine does this a bit if I do not ease into the throttle. Seems normal to me, but what do I know.
  17. Oct 11, 2016 at 5:14 AM
    #2657
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Mine does it too. I crawled under the truck and tried to rotate the rear driveshaft back and forth expecting there to be noticeable rotational slop, but there wasn't any. I'm not sure where the slop in the driveline is.
    It bothers me, but I don't worry about it. My 95 Tacoma did the same thing but then again that one had 250k miles on it.
  18. Oct 11, 2016 at 9:11 AM
    #2658
    Joes_Taco
    Joes_Taco Member
    Joey
    Downey, CA
    2016 White Tacoma TRD Off-Road 4x4 - 3.5L 6 Speed Manual
    Is it me, or is downshifting completely useless/pointless in this truck? I mean, it doesn't slow down the truck at all.
    In other vehicles, I would use a combination of downshifting + brakes to slow the vehicle down for either stops or cornering (especially corning that way you're in right gear when you come out of the corner).
    Doesn't seem to work as intended in my '16 Tacoma.
  19. Oct 11, 2016 at 9:16 AM
    #2659
    bbrown
    Buster
    Geauga County Ohio
    255/85R16 ST MAXX
    Totally agree. My WRX and Ranger both engine braked really well. Not sure if its the VVT/fo-Atkinson cycle limiting compression, but I bet it has something to do with it.
  20. Oct 11, 2016 at 9:31 AM
    #2660
    Joes_Taco
    Joes_Taco Member
    Joey
    Downey, CA
    Hmm...I'll look inot the Atkison cycle thing. I do remember looking it up once, but then my A.D.D. kicked and went on to something else. I too would engine brake in my Ranger and it worked as intended with the 3.slow.
