Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Nov 2, 2016 at 6:27 AM
    #2781
    Boston10Taco
    Boston10Taco Dented
    MA
    2017 Tundra
    Have there been any issues with the Throw out bearing on the 3rd Gens? I'm on TOB #2, and it's chirping again.
  2. Nov 3, 2016 at 4:26 AM
    #2782
    Schriner13
    Schriner13 Well-Known Member
    Austin
    Perry county, OH
    2016 Quicksand Tacoma TRD 6-Speed Manual
    Greased u joints. Haven't checked u bolts, dealer had no clue at my 5k service. Taking it in this weekend with a traitor and having every tech in there drive it till someone figures it out. Going to mount my go pro under there to to see if I see and abnormal shaking. I also noticed some decent clutch chattering sitting at a stop the other day. Sounded like a south bend:frusty:
  3. Nov 4, 2016 at 10:33 AM
    #2783
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
  4. Nov 5, 2016 at 2:14 PM
    #2784
    marshwater
    marshwater Member
    2016 TRD OR 6MT
    Has anyone else experienced surging/lunging at low rpm's in first and second gear? A kind of studder.
  5. Nov 5, 2016 at 2:22 PM
    #2785
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    How low?
  6. Nov 5, 2016 at 2:40 PM
    #2786
    marshwater
    marshwater Member
    2016 TRD OR 6MT
    1300 - 1500 rpm or so.
  7. Nov 5, 2016 at 4:34 PM
    #2787
    Doggman
    Alabama
    2017 TRD OR MT
    That could be the AC compressor kicking on. I feel it all the time and its especially notieable in those low gears where that dip in rpms kind of bucks the truck.
  8. Nov 6, 2016 at 9:12 AM
    #2788
    offthewallsurfer
    offthewallsurfer Well-Known Member
    Yes! For me it happens while pushing the throttle to the floor in 2nd gear.. the truck tends to bog down for a moment or stutters and then once 3500 rpms come BOOM it's like the Millennium Falcon going into hyperspace (sort of ). I guess it's normal.
    stealthmode likes this.
  9. Nov 6, 2016 at 12:24 PM
    #2789
    su.b.rat
    su.b.rat broken truck
    could this also be cycle transition? atkinson --> otto?
  10. Nov 6, 2016 at 8:43 PM
    #2790
    Kingair84
    Kingair84 Well-Known Member
    Wisconsin
    2016 Double Cab TRD Off Road 6 speed MT
    Rad Industries skid plate, trd pro grill, rigid DOT Fogs
    So I was driving my truck on the interstate the other day and I slow down and the speedometer gets all jerky and hangs up at like 70mph then drops right down to 60mph my actual speed confirmed by the digital speedometer in the center display in a non fluid motion. It did this on and off for about 5min while accelerating and decelerating then stopped and didn't come back. Anyone else have this happen or know what it could be from? I wasn't down shifting at all just letting off the gas or getting back on it.
    stevotivo12 likes this.
  11. Nov 6, 2016 at 8:53 PM
    #2791
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Mine does this occasionally . seems hit and miss.
  12. Nov 7, 2016 at 5:56 AM
    #2792
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    mine as well... and same with the jerky movements at low rpm. I find my truck also bucks at low rpm if i press the throttle down and let off as well, even if i don't press it down hardly at all, not more than a few degrees tops. AC compressor makes sense. For the longest time I was thinking its something driveline related, maybe too much free play between the two driveshaft pieces or backlash on the rear diff set improperly. Could be wrong though, ill see when I swap in an Eaton DTT and do all the proper measurements to be sure :devil:
  13. Nov 7, 2016 at 8:59 AM
    #2793
    wxm8562
    wxm8562 Well-Known Member
    How's acceleration and overall fell on the 16' V6 M/T? I hear a lot of negative opinions on the auto trans. Wondering if the M/T lacks any of these types of complaints. I'm currently in a 2012 RAM 1500, but I love an M/T and I'm thinking about trading.
  14. Nov 7, 2016 at 12:07 PM
    #2794
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    This is true
  15. Nov 7, 2016 at 1:01 PM
    #2795
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    I experience this as well. Along with no power or acceleration whatosever below 2100 rpms or so.
  16. Nov 7, 2016 at 1:56 PM
    #2796
    wxm8562
    I guess that's the benefit of having the manual. You can keep in any gear you want to maximize the power.
    offthewallsurfer likes this.
  17. Nov 8, 2016 at 12:14 AM
    #2797
    rockguitar316
    rockguitar316 Well-Known Member
    Adam
    Dayton Ohio Area
    Now: 2016 WRX stage 2 377hp/350tq. Then: 2016 TRD Sport DCSB 6MT (don't kick me!)
    It's so so. It's a truck. It takes some time before it the acceleration starts to set in. Until about 3000 rpms it feels substandard as far as power and acceleration to me. Then again I came from a Civic Si and those things were quick.
  18. Nov 8, 2016 at 3:58 AM
    #2798
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    No you're not feeling a difference because you're coming from a Civic. I've owned 3 Taco's: 06 Sport DCSB A/T, 10 OR DCSB A/T, and now a 17 OR DCSB M/T. Both my previous Tacos had some "pep" in the throttle right from a standstill. The manual is very much substandard in throttle response/acceleration below that RPM.
    offthewallsurfer and Kingair84 like this.
  19. Nov 8, 2016 at 7:33 AM
    #2799
    stevotivo12
    Stephen
    I don't think blaming the transmission is wise here, gents. Remember that the biggest difference between the 3.5 and the 4 liter is going to be the rotating mass of the pistons. More rotating mass= more torque or 'power from standstill'. So basically if you want to get all the power the 2GR claims, you have to keep it in the rev range where it makes those claims, i.e. 3500 and beyond. Otherwise, expect better fuel economy with no get up and go from a standstill.
    wxm8562 likes this.
  20. Nov 8, 2016 at 8:24 AM
    #2800
    Kingair84
    Wisconsin
    I honestly shift at 3500rpm and above, at this rpm It's comparable to my '15 4.0. The 4.0 I feel was a more peppy engine. This engine isn't bad and the trade off is mpg I average over 20mpg even shifting as high as I do where as the '15 averaged 17mpg. In a perfect world I'd like to have both trucks. I really liked my '15 and I really like my '16. Each was better at certain things I wouldn't really say one is better than the other. Just my opinion.
