Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Feb 16, 2017 at 2:59 PM
    #3581
    Sprouty115
    Sprouty115 Well-Known Member
    RI
    2017 Tacoma Sport 6MT
    Not being critical, but 1K rpm is really pretty low to driving around at. I'm wondering if it's partially stalling?
  2. Feb 16, 2017 at 3:13 PM
    #3582
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    No it happens above 1k rpm, and after the single buck/jump it moves along fine after. It is only a single buck. It happens above the point where the engine would want to stall (I never take 2nd gear below 9 mph, i think that is right around 1k rpm? because the engine gets stuttery around there).
    I typically cruise 2k+ rpm, usually around 2.5k. So I only experience this issue when coming to a stop or slowing down into that range.
  3. Feb 16, 2017 at 6:34 PM
    #3583
    jkm25
    jkm25 Well-Known Member
    2016 QS DCSB OR MT
    I've experienced what you're talking about and I think its just a function of the super computerized engine. At low RPM it feels like the engine braking just stops, so it feels like it's lunging because the truck all of a sudden isn't being slowed by anything. Its annoying but you get used to it.
  4. Feb 16, 2017 at 6:37 PM
    #3584
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
  5. Feb 17, 2017 at 5:06 AM
    #3585
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
  6. Feb 17, 2017 at 6:52 AM
    #3586
    aero90
    Ok thank you, that is exactly what I'm talking about! Good to know it is happening to others as well.
  7. Feb 17, 2017 at 8:57 AM
    #3587
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I get a bucking in the driveline every so often. Probably just motor mount bushings already getting trashed, I need to swap in the solid mounts sitting on my desk one of these days. In 5th or 6th sometimes if I let off the throttle quickly I'll feel the driveline buck from the power loss and then if I give it throttle again I'll feel it buck again. So something has a hair of slack in it somewhere that's causing that. Could just be axle wrap, but usually don't feel it like that at highway speeds
  8. Feb 17, 2017 at 11:00 AM
    #3588
    aero90
    Yes I get the same as well, the bucking when applying the throttle or coming off of it quickly (happens in multiple gears). Have to be real sensitive on the throttle to avoid it.
  9. Feb 17, 2017 at 11:45 AM
    #3589
    wxm8562
    wxm8562 Well-Known Member
    Happens to me as well. Quick acceleration will cause it to jerk or seem like it dips in power and then kick in. I don't really notice it when the truck is warmed up though. Ususally just for a few minutes after I start it.
  10. Feb 20, 2017 at 7:45 AM
    #3590
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Did my part....
    Initial quality survey came in the mail. Aside from the typical questions about broken stuff at delivery, there was a question on what the primary reason was for my purchase decisions. I said "Availability of manual transmission."
    Dinged them for dash rattle, rear end howl and steering wheel vibration @ 60-65mph.
    shakerhood and Sprouty115 like this.
  11. Feb 21, 2017 at 10:23 AM
    #3591
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    Mine does
  12. Feb 21, 2017 at 1:29 PM
    #3592
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    The TRDs come with cruise. SR doesn't but I'm pretty sure Corey/sloemoe has instructions on adding cruise to the SR 5MT.
  13. Feb 22, 2017 at 6:56 AM
    #3593
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I added to mine. It is just a little bit more involved than adding to an auto, but still pretty easy. The only additional step is adding an upper clutch switch. If you do this just get that switch through your dealer. It's a tight spot and being plug and play helps a lot.
  14. Feb 22, 2017 at 7:05 AM
    #3594
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Cruise comes with the SR Convenience Package, but not with the Utility Package.
  15. Feb 22, 2017 at 9:36 AM
    #3595
    TBV
    Oakland CA
    2017 TRDOR 6MT
    Man, I am really starting to love my truck. Haven't even gotten out of town yet. Hopefully will get up to the snow this weekend. It's such a blast to drive. And so far - knock on wood - zero issues with vibration, rattles, howls, etc.
    3rd gen is king. It's just fucking fun. Comfortable inside too. Coming from a 1995 standard Taco - holy moly. I feel really bad for folks who aren't happy with theirs. I'm glad I got the manual. I know I can trust it. The risk of being unhappy with the Auto was too high.
    Only minor thing is that the standard exhaust seems kind of strained or pinched. I might look at doing TRD exhaust/intake at some point. Seems like the 3.5L wants a little more room to breathe.
    TroutBum and su.b.rat like this.
  16. Feb 22, 2017 at 4:11 PM
    #3596
    su.b.rat
    su.b.rat broken truck
    how many miles you got?
  17. Feb 22, 2017 at 4:16 PM
    #3597
    TBV
    Oakland CA
    2017 TRDOR 6MT
    I think around 200! Mostly just been cruising around town. Making up excuses to run errands, even.
    su.b.rat[QUOTED] likes this.
  18. Feb 22, 2017 at 5:16 PM
    #3598
    aero90
    Just want to let you guys know there is a new TSB out (as in last couple of days) specifically for whining/howling in 5th and 6th gear in the manual transmissions. It involves replacing a heat insulator and 4 bolts. So check to see if you notice any whining.
    TSB-0186-17
    shakerhood, TBV and nevadabugle[OP] like this.
  19. Feb 22, 2017 at 6:04 PM
    #3599
    VolcomTacoma
    Jeff
    NorCal
    Mine whines! Maybe I should get it checked out....only happens when I give it alot of throttle though
    shakerhood and def67 like this.
  20. Feb 22, 2017 at 6:06 PM
    #3600
    aero90
    Get out of here with your supercharged nut flexing, this is for us owners that are stuck with the snail edition ;)
