Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Mar 8, 2017 at 6:33 PM
    #3721
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    If you encounter this, just pull back to neutral and clutch out and in and then try to put it in 1st again and it should go. Or you can keep the clutch in and row down to second and then try back up to 1st and it should work.
    If the second method doesn't work, the clutch out and in while in neutral will.
    TeecoTaco likes this.
  2. Mar 8, 2017 at 6:33 PM
    #3722
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I'm at 99 miles! Haha picked it up Monday.
    Holloman likes this.
  3. Mar 8, 2017 at 6:35 PM
    #3723
    Tacowin1013
    Yep, that's exactly what I found does the trick. Thanks!
  4. Mar 8, 2017 at 6:45 PM
    #3724
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Mine was definitely a bit more catchy when new, now with 77k miles on my 2014 it's smoother. Still not like some of the car MT's I've driven but it's decent enough.
  5. Mar 8, 2017 at 7:41 PM
    #3725
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Yup...don't even have to put into full 2nd...just put in it a little way (that's what SHE said) then slide into first...butter
    Holloman and Tacowin1013 like this.
  6. Mar 8, 2017 at 7:57 PM
    #3726
    Tacowin1013
    How many people are on their first clutch? Or how many miles did you have when replaced...just a quick poll to see how durable the taco clutches are. This is my first taco (and truck) so not sure if it differs much from the other manuals I've had.
  7. Mar 8, 2017 at 7:59 PM
    #3727
    TeecoTaco
    SW Ontario
    Pretty darn ironic tho when ya boil it down...we got the MT to DRIVE the truck, yet they have an electronic accelerator instead of cable. Allegedly a 'learning algorithm' on your past driving habits. Wife's Rav4 same...I mostly drive it, but after she drives for a spell, it reacts differently when I step on the pedal. Doesn't make sense in a MT tho IMHO...so, I to afford a twist from my aviation experience...better to have more RPM behind ya (altitude below ya) when shit gets serious, so lowest gear is best when things get mysterious.
    nevadabugle[OP] likes this.
  8. Mar 8, 2017 at 8:00 PM
    #3728
    Tacowin1013
    That sounds about right.
  9. Mar 8, 2017 at 8:08 PM
    #3729
    TeecoTaco
    SW Ontario
    Ah, the trusty old double clutch...This gentleman knows how to finesse a tranny!
  10. Mar 8, 2017 at 8:47 PM
    #3730
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Ill tell you what, regearing to 4.56 with 295/75/16s made this truck alot more fun. I can roll it in 1st with no throttle again. Haven't dumped it in 1st yet to see if it stalls, but I can let up without to much slip and itll start rolling. 1st to 2nd has smoothed out a bit, although 1st is still to short and 2nd is still to tall. Basically have to take 1st up to about 4k rpms and then let it settle to about 2k before I can let go in 2nd. Everything else feels really good and I got ALOT of power back (just cant use it for 500 miles while the gears break in). Gotta solid mount the power trail, install headers, and get some tuning done and I think I'll be set!
  11. Mar 8, 2017 at 8:53 PM
    #3731
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    I second the re-gearing with 285s, I went from 4.30 to 4.88 and it rolls in 1st no problem, and the engine feels like it has some torque!! Also I don't shift on freeways to pass people now its 6th all time time after 65+mph
    Diablo169 likes this.
  12. Mar 9, 2017 at 7:59 AM
    #3732
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Am I the only one that has a temperamental 3rd gear? I find that it's quite easy to catch it going between 2 and 3. Yesterday I swore it felt like a grind. I guess I"ll have to be even more deliberate when I shift. I also notice if you hit a bump mid-shift you can get a not so awesome feeling from the gearbox.
    I don't think there's anything wrong, as I've driven cars with bad synchros, but a sports car gear box it is not.
  13. Mar 9, 2017 at 8:02 AM
    #3733
    Timmystaco
    Timmystaco Active Member
    Timmy
    Taco X Runner
    K&N air intake system
    My wife and I both drive 6 speed rear wheel drive vehicles!
    ninjastar808 likes this.
  14. Mar 9, 2017 at 8:02 AM
    #3734
    Tacowin1013
    Yeah my 3rd gear is a little notchy as well. But you said it yourself--- a sports car it is not! I'm still very happy with the way it shifts. Very very similar to my S5 except the longer throws
  15. Mar 9, 2017 at 8:21 AM
    #3735
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    I too get a little extra bump when I engage third, like the fork is bumping into something. No grinding though and otherwise it's pretty smooth.
    My problem is trying to let out the clutch smoothly into 5th and 6th. I feel like I have to have a little more hang time in those gears to avoid a "clunk" in the driveline.
    My last MT was a 95 reg cab short bed S-10 with a 4.3 vortec. Granted it's been 12 years, but I don't remember that thing being this "picky."
  16. Mar 9, 2017 at 8:41 AM
    #3736
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    I definitely feel the notch. The grindy feeling threw me as it was only one shift the other day that threw me. I suppose I can explain away in my mind hitting a bump mid-shift causing issues. I definitely have the 5th and 6th clunk. Still trying to figure out what's up there as none of my other manuals over the years had done that.
  17. Mar 9, 2017 at 10:10 AM
    #3737
    Timmystaco
    Timmy
    Taco X Runner
    My truck keeps the revs up between shifts after I lift off the gas. It's a little annoying but maybe they do that to prevent stalling??
  18. Mar 9, 2017 at 10:54 AM
    #3738
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    ‘24 LC250 First Edition, ‘25 TRDOR 6MT, 2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    Question for you guys who replaced your stock shifters with aftermarket knobs...
    How do you remove the chrome bezel so you can put a grommet there to keep the boot down? It's attached to the leather by something isn't it? I want to upgrade to the FJ Cruiser TRD shift knob and need to figure that out...
    Thanks
    Masterofnone likes this.
  19. Mar 9, 2017 at 11:03 AM
    #3739
    aero90
    It's rev hang, a modern day engine management/emissions thing.
    I've found in this truck if you fully release from the gas and then clutch in you can get some nasty rev hang. Either wait a little longer or push the clutch in a little quicker, or my preference, ease off on the gas almost off but do not fully release, until you have pushed the clutch past the biting point. This will also give you a smoother, quicker shift between lower number gears like 1-2.
  20. Mar 9, 2017 at 11:07 AM
    #3740
    Timmystaco
    Timmy
    Taco X Runner
    It's hard to get used to
