Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Mar 19, 2017 at 1:14 PM
    #3921
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Hitting the gas while you have the transmission disengaged damages nothing during a shift. I 100% guarantee you rev matching/heel toe'ing (which is rev matching too) is the right way to do it. It puts way less stress on your clutch and drivetrain overall.
    If you were to go to neutral and floor it to redline and then shift to the next gear and slip the clutch back down every shift yes that would be bad. But rev matching to roughly the correct rpm is guaranteed the proper and least amount of wear way to do it. You don't NEED to rev match with synchro's but it most definitely prolongs the life of your clutch and the synchros as well. There is less of a difference the system needs to make up for if the RPMs are in line.
    There is no need to double clutch a synchro'd transmission. I only do it going into 1st (and also rev match 1st) because 1st gear is the only one that has gotten stuck for me, even at a dead stop.
    shakerhood and Dannyblues like this.
  2. Mar 19, 2017 at 2:18 PM
    #3922
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    I hate to repeat myself but as long as @Dannyblues does, so will I.
    "Please ignore @Dannyblues I think he is living in a different century than the rest of us. he is incorrect in just about everything he has said about driving a modern stick shift. If we're talking a 60's era Mack truck it is probably good info, but is totally irrelevant to a 3rd Gen Taco."
    I'm sure you are a nice guy and we are close to the same age, but you are simply wrong. Our transmissions are full syncro, there is no need to double clutch them, and it does not hurt anything to blip the throttle on a downshift (in fact it reduces clutch wear as the trans and engine rpms are matched).
    Dannyblues and VolcomTacoma like this.
  3. Mar 19, 2017 at 2:23 PM
    #3923
    Dannyblues
    Dannyblues Well-Known Member
    Danny
    New Milford Connecticut
    2016 Tacoma TRD sport 4x4 double cab black
    weather tech mats, mud flaps, black side rail step, cargo bed liner, roll up cargo bed cover, wheel locks towing package
  4. Mar 19, 2017 at 2:26 PM
    #3924
    Dannyblues
    Danny
    Ok. I think that's what I learned many years ago when beginning to learn to drive manual trannys. I'm sure though that the reason you pull the vehicle into neutral while at a long stop light isn't just to give your leg a rest as opposed to waiting out the long light in first with the clutch depressed. So the same logic would apply to revving the engine with the clutch depressed, no???
  5. Mar 19, 2017 at 2:28 PM
    #3925
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Welcome to 2017
    Dannyblues likes this.
  6. Mar 19, 2017 at 2:31 PM
    #3926
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    Not taking any sides, but why over analyze the MT? If you need to have this much discussion on how to drive the manual you probably should have got the automatic.
    bls82261, shakerhood and Dannyblues like this.
  7. Mar 19, 2017 at 2:34 PM
    #3927
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    You are correct about releasing the clutch in neutral at stops. However, a blip of the throttle (blip not revving it to high heaven) doesn't add anything to the time the throw out is under stress and there is little RPM difference between revving the engine a bit just before you release the clutch. you really aren't so much matching the revs as you are getting the engine RPMS moving in the right direction for a smooth downshift.
  8. Mar 19, 2017 at 2:36 PM
    #3928
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    I just wanted to make sure I'm downshifting properly having never towed with a stick. Now I'm all like 200_s.gif
  9. Mar 19, 2017 at 2:38 PM
    #3929
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    This kid grew up
  10. Mar 19, 2017 at 2:45 PM
    #3930
    schmack b
    schmack b Well-Known Member
    Clarksdale, Mississippi
    2016 DCSB TRD OR M/T
    Like I said earlier when u asked, I just don't use overdrive gears when I'm towing. If it's flat for a long time I will but that's it.
    Have u tried to back a trailer up any kind of incline yet? If not, that's some tricky shit with this transmission.
  11. Mar 19, 2017 at 2:47 PM
    #3931
    schmack b
    All this rev matching talk makes me think of the newer cars that have the auto rev match feature. Anyone have any experience in one of these? If so how did u like it?
  12. Mar 19, 2017 at 2:48 PM
    #3932
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    I back into my garage every night. Long story. It's a pain in the butt but I take it slow.
  13. Mar 19, 2017 at 2:50 PM
    #3933
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    My trailer is a 6x12 enclosed that's never loaded with more than 500lbs. It takes it in 6th just fine on my usual route, but I haven't towed it to Kansas City yet... that's where I'll need downshifting
  14. Mar 19, 2017 at 3:02 PM
    #3934
    75z28
    75z28 Well-Known Member
    Homer
    2017 OR 4x4 DCLB SSM
    This, the time doesn't change which means it won't hurt anything. Honestly with these transmissions, I only rev match or double clutch if shifting down one or more gears OR I am needing to take off quickly on an onramp. Otherwise it's a waste of effort.
  15. Mar 19, 2017 at 5:26 PM
    #3935
    Dannyblues
    Danny
    I like that!!!! Thank you. I'm still wearing bell bottoms, tie dye tshirt and Neru jacket ( look that one up! ).
    Holloman likes this.
  16. Mar 19, 2017 at 5:40 PM
    #3936
    Dannyblues
    Danny
    All this shifting technique stuff began when a newbie to the world of manual transmissions asked about shifting. I personally discussed all the different methods used over the years from about the 1950's to present including a variety of vehicles including semi trucks.
    Is it really 2017 already!!!
    I'm still not satisfied with the concept of revving the engine with the clutch depressed even in modern vehicles. I've always heard it was bad for the drivetrain ( I think it damages the throw out bearing ). I've received so much flack and opposition regarding this I'll have to research it further. I personally occasionally double clutch when going down a steep decline in third then double clutch to second with a good blip in neutral in between. I have a steep downhill just down the road from my house in a 30 mph zone that includes a sharp curve. It enables me to slow safely without using the brakes.
    If and when I get the issue of revving with the clutch depressed cleared up I'll report back. At this point I feel an apology may be in order and I'm wrong due to so much negative response. Either that or many of you don't know squat. Ill get back one way or the other.
    In the meantime I appreciate all your responses even the contradictions. Dannyblues
  17. Mar 19, 2017 at 6:38 PM
    #3937
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Page 200!
    su.b.rat and schmack b like this.
  18. Mar 19, 2017 at 6:38 PM
    #3938
    nevadabugle
    Elko, NV
    Page 200! And again...
    schmack b likes this.
  19. Mar 19, 2017 at 6:39 PM
    #3939
    nevadabugle
    Elko, NV
    AHHHHH....Page 200! THIS ONE WILL MAKE IT...
    Holloman and schmack b like this.
  20. Mar 19, 2017 at 6:41 PM
    #3940
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
